Old 07-27-2019, 10:11 AM #1
greeney greeney is offline
greeney is on a distinguished road
Gasket Material critical? - master cylinder to brake booster
Is Gasket Material critical for master cylinder to brake booster? I notice the old one is paper thin and the one I cut from a roll I got at Autozone is thicker and a soft material. Not sure if this gasket is there more to stop vacuum leak or brake fluid leak.
greeney is offline   Reply With QuoteReply With Quote
Old 07-27-2019, 10:25 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
That gasket is for vacuum leaks. You do need a gasket there.
Old 07-27-2019, 11:14 AM #3
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
I don't think the gasket seals vacuum, and it definitely does not seal brake fluid. I think it is just to keep moisture out.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 07-27-2019, 09:48 PM #4
HiLife HiLife is offline
You beat me too it.
My thoughts extactly.
brake , cylinder , gasket , master , material
Brake Booster/Accumulator/Master Cylinder Assembly Replacement eng208 4th Gen T4Rs 32 07-25-2021 02:55 AM
Brake booster or master cylinder Wakko 3rd gen T4Rs 5 06-26-2019 07:56 PM
Electric Brake Booster or Master Cylinder going bad? judogti 4th Gen T4Rs 8 04-28-2017 05:07 AM
3rd Gen Brake Booster/ Master Cylinder Question. UnderFire 3rd gen T4Rs 15 03-02-2015 06:58 PM
brake booster or master cylinder oaknapa098 3rd gen T4Rs 4 11-27-2011 07:42 PM
