Old 07-31-2019, 12:28 PM #31
mesooohoppy mesooohoppy is offline
mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about
ooooh, thank you for that! i saw that on one write up but totally forgot about it. will for sure purchase those.
99 4runner limited; imperial jade mica
IG: mesooohoppy
mesooohoppy is offline   Reply With QuoteReply With Quote
Old 07-31-2019, 01:20 PM #32
absalom's Avatar
absalom absalom is offline
Real Name: Jordan
absalom has a spectacular aura about absalom has a spectacular aura about
absalom's Avatar
Real Name: Jordan
Originally Posted by mesooohoppy View Post
so did you try to fix the issue, or did you just go back to stock?
I used the following to attempt a fix:
- pressure bleeder
- TechStream cycling the ABS solenoids
- Gravity bleeding
- Traditional 2 person brake bleeding, with engine on and off
I saw some improvement, but never to where I was happy with the feel.
absalom is offline   Reply With QuoteReply With Quote
Old 07-31-2019, 01:42 PM #33
jeech jeech is offline
jeech is on a distinguished road
i have been doing some research and i still need to do more. but from what i have been reading, my take away is that the bleed procedure has a lot of do with the success of your tbu swap. if you stave the MC, it eventually ends up starving the abs unit, which can be a pain to bleed (from what ive read, also common on other toyotas).
a fair amount of the people who arent satisfied with the swap claim they werent happy with the pedal feel and went back to stock; most of these i come across on this forum do not further elaborate.
the measurements on the first link you showed me do in fact confirm the tundra caliper is bigger overall (but not by much). which would likely mean that there is slightly more passage length for the fluid to reach the piston; although i wouldn't think this would require a larger MC. these calipers really arent that much larger and you arent jumping up in pistons either.
sorry for not multi quoting. it doesnt seem to work on this forum.
This. I believe this was the biggest culprit for the crummy brake feel, as I saw the largest improvement after this was done. I've only done some preliminary research on the process to bleed the ABS, but I'm glad I let the shop do it.
jeech is offline   Reply With QuoteReply With Quote
Old 07-31-2019, 02:08 PM #34
I should also note that I started out with terrible brakes. I bought this truck back in January, and the rotors were the most warped of any I've seen. The shudder was unbelievable, especially on a downhill. They were also spongy and slow to engage.
All this to say that the only thing I have to compare their current state against is that, and the 2013 Elantra we have--which if you're familiar with that vehicle, you know that if you just look at the brakes you're in a hard stop. So while I'm pretty dang happy with the upgrade, I can't say if it feels what stock should feel like, as I haven't really experienced well-maintained stock.
Old 09-08-2019, 11:15 PM #35
Snowden's Avatar
Snowden Snowden is offline
Real Name: Ash
Snowden is on a distinguished road
Snowden's Avatar
Real Name: Ash
Originally Posted by absalom View Post
This is why I don't recommend the TBU. I had the same issue on one of our 3rd gens, and could never get the pedal close to stock feel. Braking never gave me the confidence that I had prior to the TBU.
Good luck, OP!
Jordan did you end up going back to original calipers ? I feel a bit the same way with the 199mm TBU I did to my '98. I've never been overly impressed with the mod. I'm contemplating going up to the 231mm but frankly I'm always more concerned with the long brake pedal travel and I'm still going to have that with either 199 or 231. Lately my brakes have been feeling quite a bit worse. So I'm pretty on the fence about what to do. Whatever direction I go in I'm going to switch to braded lines which I hadn't done previously. The expansion pov regarding the rubber lines does make sense and maybe that's contributing to the issue.
1998 SR5 - 3.4/Auto/151k. Toytec, OME, Savage Off-road, Addicted Off-road, 4Crawler, Spidertrax, TBU, ePCK, B&M, ViAir, '00 grill/headlights, Firestone MT, CB mod, RB mod.
Snowden is offline   Reply With QuoteReply With Quote
Old 09-09-2019, 02:36 AM #36
19963.4lsr5 19963.4lsr5 is online now
Recently a member did the TBU and had your issues and he took it to a garage and had them bleed the brakes and ABS unit and it restored his pedal feel. Do not know how to pulse the ABS without braking hard in stones. There might be a way using the test port bolted to the intake.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 09-09-2019, 10:17 AM #37
absalom's Avatar
Real Name: Jordan
absalom's Avatar
Real Name: Jordan
IMO, I don't see how braided lines could be the answer. The poor pedal feel wasn't there prior to the mod, so why would it fix it now?
I sold the vehicle, and have had several 3rd gens since then. None of which had the TBU mod done. Instead, I've maintained the brakes using strictly OEM gear and have been very satisfied with the bog standard brakes.
The TBU attempts to fix an issue that really doesn't exist. Downshift on steep grades, use quality OEM rotors and pads, and high quality fluid and these brakes are great!
Old 10-12-2019, 03:25 PM #38
Supracool03 Supracool03 is offline
Real Name: 1996 4runner SR5
Supracool03 is on a distinguished road
Just completed TBU with 199 calipers on 1996, it stops good but there is a lot of travel on the pedal. If I replace the master cylinder and brake lines, will it make a difference?
1996 4Runner SR5
Supracool03 is offline   Reply With QuoteReply With Quote
abs , brake , flush , system , tbu
Upgrade from 2000 15" wheel calipers to Tundra 231MM Poor brake pedal performance Avwizz 3rd gen T4Rs 8 03-19-2014 12:35 AM
Advice Please: Poor braking performance with TBU 231mm ventureadict 3rd gen T4Rs 6 11-27-2011 08:17 PM
Is this poor mile performance? JuanSJO 3rd gen T4Rs 6 04-22-2008 12:59 PM
Poor de-mister performance on winshield magnumfan 4th Gen T4Rs 6 01-21-2008 11:14 PM
Poor Defroster Performance gapboi210 3rd gen T4Rs 6 01-20-2007 11:50 AM
