Originally Posted by thegipper
Try disconnecting the shift solenoid harness on the tranny. Take it for a spin and try manually shifting through the gears. If it shifts fine, you need to replace your solenoids.
If it still doesn't shift, your tranny may be on its way out assuming your fluid level/condition is fine.
Ran it several times with the solenoids disconnected and it would shift just fine, so I replaced them and did a filter replacement/fluid swap using the trans cooler line out. Fluid was old, but not burned that I could tell, no major chunks.
Tonight I loosened the shifter connection to the tranny and readjusted it per FSM I saw somewhere... put inside shifter in neutral, put tranny shifter in neutral, retighten to make sure it's aligned.
Also tried readjusting the kickdown cable after reading some stuff... figure it's worth a shot.
I don't think it's my transmission itself, albeit it has a ton of miles (298k), it exhibited no hard, slip or weird shifts until this problem started and I think it came about after I was doinking around with some stuff under the shifter, but I have no idea if it's correlated to that.
Thanks for the suggestions!
