Old 07-30-2019, 01:53 PM #16
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Originally Posted by spartacus View Post
Wedge a 2x4x8 or 10 against the frame and a ceiling joist if possible. I vé been reading and admiring your project.
I'm thinking something similar to this, but maybe 4x4 or 6x6 to get less flex out of the wood. Say, 6x6 across frame where engine weight would do the trick, then 6x6 across several rafters to distribute the force, and a floor-to-ceiling pole jack in between to compress...?
thennen is offline   Reply With QuoteReply With Quote
Old 07-30-2019, 05:56 PM #17
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
Originally Posted by HiLife View Post
Would it be possible to get some worn out strut spring combo? Disassemble it, cut off enough coils, reassemble and install.
totally possible I just don't have any laying around.
Originally Posted by St Runner View Post
I like HiLifes idea. Just toss an old set on for now. Yes its ugly compared to the rest of that frame, but sometimes you just have to man up and deal with the ugly. You are going to have to readjust everything later anyways
sure but really torquing the upper is really the only thing left to do, of course alignment but that is a given.
Originally Posted by Hopeless Diamond View Post
Buy a bunch of pizza and beer, invite a bunch of friends over and have them sit on the frame. They can enjoy the pizza and beer as they watch you work.
and his name is bubba, unfortunaly I don't have any bubba in my phone.
Originally Posted by dogtail View Post
If the Egyptians could move 80 ton blocks of rock without machinery you can do this easily. Use leverage where you can. I'm thinking stick a landscaping beam or 2x6 or some other strong enough wood under the frame on other side, tie it back to the frame on other side somehow, cause would lift frame otherwise. Ratchet strap the coil to compress to where want it. I think this would work fine.
Awesome workmanship you're doing there.
dude everybody knows they had help from aliens. I learned this on the internet so it must be true.
Originally Posted by nevada View Post
jack up the OPPOSITE rear corner of the frame. by the frame at the furthest point you can hit. this will help put more pressure against the side you're working on.
yea it's not even close, I have an engine hoist and I can pickup any part of the frame and the coil-overs just laugh in your face.
Originally Posted by repo View Post
I'm probably not understanding the physics of this but cant you just put the UCA bolt in but dont torque it, then install the coilover? Then remember to torque the uca bushiing when the full weight is back together. I've never had to use pry bars or the bottle jack trick or anything to get coilovers in I just loosen the UCA and it drops down.
I have done this several times with a fully assembled truck and yes I agree it has never caused me much issue. sure I have had to use a dead blow to kind of help things line up but... the pre-load is set to compensate for the full weight of the front end so... I have too somehow make up missing weight.
Think about it this way when you install a coil-over you droop the lower arm and then put the top into place, then bolt up to the lower arm. you can then jack up the lower a little until the upper ball joint just slips on.
in this case there is no ufda to compensate for the pre-load on the spring.
I was able to compress the spring with a little help from my coil spring compressors and some spacers. however at full droop I hit the spring and the UCA guessing I will have to undo it and spin the coilover to the next position to clear that at full droop. sigh.
need help from bubba I think
I also ravaged the spring but at this point it felt kind of good to hurt it.
Old 07-31-2019, 03:44 PM #18
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
[QUOTE=sleepydad;3330297] however at full droop I hit the spring and the UCA guessing I will have to undo it and spin the coilover to the next position to clear that at full droop. sigh.
My Tundra springs 5100 Billy's would do same thing hitting coil when on stands. Rotating did not help, limit straps did.
Old 07-31-2019, 05:54 PM #19
phattyduck phattyduck is online now
If you can't get the coilover in there with the pivots and ball joints all in place (pivots loose), your coilover is too long. Get some aftermarket upper arms on there for increased down travel, otherwise you will be stressing that top ball joint every time you top out your suspension travel.
There should be no forcing of things or pry bars, other than to hold the actual weight of components. (ok, I have used a pry bar to droop the suspension to overcome the bushing preload, but that was re-installing the same parts that were on the truck before the work...)
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
phattyduck is online now   Reply With QuoteReply With Quote
Old 07-31-2019, 06:33 PM #20
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
100% agree I hate when I have to pound something into place.
so I drank a beer last night and did a little thinking while giving the project the Sara Sanders stink eye.
this morning I got up early and decided to re-do everything one more time.
the coil over measured 20 1/4" from the top plate to the center of the lower bolt dom mount.
the truck in full droop without a coil over in it gave me 20 1/8" from the bottom inside of the shock tower to the center of the lower arm.
so the coil over is really about 1/8" longer than the available space. I guess in suspension terms it's horse shoes and hand grenades town.
I think maybe I just did not have everything lined up and all the parts are new so they are not worn in? I think you have a point on that one. I still had to use the small ratchet strap to get enough thread on the lower ball joint to get the nut rolling but once I did it seems ok now. was able to estimate the correct position and now it's ok for stock arms 3" front lift.
Old 07-31-2019, 07:16 PM #21
Am I spying a 1/2" top plate spacer on there?!? If that should (somewhat obviously) be your problem. Without an aftermarket upper arm, you can only fit a 3/8" spacer up there without causing the problems you are seeing... At least, that's what I found when I did my suspension last year.
Old 07-31-2019, 08:09 PM #22
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
yes the top plate spacer came with it so I figured it was supposed to go on it, I could leave it off. the instructions said nothing about that, hmm. I'm using all spare parts for this build so these are off my other truck, stock.
not planning on swapping in custom aftermarket uppers, but that does make sense. hmmm dam it.
Old 08-01-2019, 01:51 PM #23
I think that Eibach setup is a 1.5" lift without any extra spacers, which is probably reasonable for what you are looking for. The 1/2" spacer bumps that up around 2.5" lift. You'll find out when the frame is back under a body/engine...
drop , front , guess , ideas , put
**Bubba Rope Group Buy** ramonortiz55 Group Buys 62 12-06-2016 04:16 PM
Bubba rope; a few pics SnowRambler Engines / Suspension / Wheels / Tires / Audio / Accessories 12 11-01-2016 12:01 PM
Bubba Rope Mtssurf1 Off-Roading 5 02-18-2014 08:51 PM
