Originally Posted by 96RedRunner
Ratchet strap from LCA to strut tower around top hat bolts.
Damn that frame looks sexy. Lol
Originally Posted by Hopeless Diamond
Anyway to run a strap (strong enough of course) from the axle of the floor jack up and around the frame?
Originally Posted by spartacus
Wedge a 2x4x8 or 10 against the frame and a ceiling joist if possible. I vé been reading and admiring your project.
I have tried big ratchet straps, and the problem is the strap interferes with the upper control arm making it impossible to get the arm lined up.
I have also tried a spring compressor, had to grind it down a bit as the fronts are pretty tight and got it crazy compressed. it was about a 1/4" away with this attempt. it also interferes with the upper arm but you can sneak it into each side. I need to cut a chunk of pipe tomorrow so I can get more threads because once I was maxed out the bolt for the spring compressor started to run into the shock tower. sigh.
I don't know I gave up tonight, time for a beer.
it seems these trucks are just born and nobody has ever tried to put a coil into just a frame without an engine/body before.
