Old 07-29-2019, 09:21 PM #1
kfriede kfriede is offline
kfriede is on a distinguished road
Pro Tip - Key Fob Programming
I have a 99 Limited that I had trouble programming key fobs with. My driver's door actuator is bad and won't cycle enough times to complete the programming. I tried helping the lock out as I was pushing the electronic button and couldn't get it to react.
Finally I found a trick that worked for me. Use the key on the outside of the driver's door to cycle the lock, works perfectly with that.
Just in case anyone else has this issue.
kfriede is offline   Reply With QuoteReply With Quote
Old 07-29-2019, 10:35 PM #2
zcruiser's Avatar
zcruiser zcruiser is offline
zcruiser has a spectacular aura about zcruiser has a spectacular aura about
zcruiser's Avatar
Yeah I always hated doing that, it seemed very abusive to the solenoid. Especially since you had to have almost split-second timing to get it to work. Actually, it took literally split-second timing.
2012 4Runner Limited, Shoreline Blue Pearl / Beige leather, RCI skid, ext rear diff breather, Derale 13504 cooler, 110K
1993 300ZX Cherry Red Pearl with some bling, K&N intake, PowerTrix suspension, 130K
zcruiser is offline   Reply With QuoteReply With Quote
Old 07-30-2019, 12:25 AM #3
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
Yep, key in the outside lock was the only way I managed to program an aftermarket eBay fob a couple weeks ago. No way was the door lock actuators up to the challenge with the interior door lock switch. A couple lock/ unlock cycles and it was already struggling in 70’s weather.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 07-30-2019, 01:56 AM #4
redhot redhot is offline
redhot is on a distinguished road
Has anyone ever tried manually cycling the drivers lock to program the remote? My 4Runner doesn't have a factory remote but I've programmed a few Toyota and Lexus key fobs that use this exact procedure. I always manually cycle the drivers side lock instead of use the power lock/unlock button and it has worked so far everytime.
redhot is offline   Reply With QuoteReply With Quote
Old 07-30-2019, 08:46 AM #5
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
That's literally what the original poster said he did. Almost word for word exactly what he said...
Old 07-30-2019, 10:34 AM #6
ThySenteth's Avatar
ThySenteth ThySenteth is offline
ThySenteth is on a distinguished road
ThySenteth's Avatar
I read that as him meaning just grabbing the little knob at the top of the door panel and using that.
OP is referring to putting your key in the lock on the outside of the door and using that. (which was an option listed in the HOWTO thread of remote programming many years ago and discussed ad nauseam).
ThySenteth is offline   Reply With QuoteReply With Quote
Old 07-30-2019, 04:47 PM #7
OP said to use key in outside lock. I'm saying grab the manual inside lock and pull it up / push it down.
Has always worked for me on other Toyota / Lexus models using this remote programming method. I've never been able to test it on my 4Runner because it didn't come with factory remote so I installed aftermarket remote.
Old 07-31-2019, 12:42 AM #8
The final solution was key on the outside.
The intermediate attempt was grabbing the plunger (?) and moving it up/down while also pushing the power lock/unlock button. That did not work for me.
The first attempt was straight up lock/unlock button. Didn't work because actuator hates life.
cycle , door , drivers , key , programming
Key FOB Programming bpearson 4th Gen T4Rs 37 03-20-2023 04:48 AM
Programming a new key HeyTrent 4th Gen T4Rs 20 02-25-2020 04:54 PM
Key FOB Programming Help! navygse1 3rd gen T4Rs 5 07-31-2015 12:40 PM
Programming new Key? otterball21 Engines / Suspension / Wheels / Tires / Audio / Accessories 11 07-13-2013 12:22 AM
