Old 07-29-2019, 11:19 PM #1
Huskie's Avatar
Huskie Huskie is offline
Huskie is on a distinguished road
Huskie's Avatar
Scammed on a Denso A/F ratio Sensor.
This here is a cautionary tale for you lads. Last year, just before smog inspection time I got a check engine light for catalyst efficiency on my 2002 sr5 (A.K.A BRUTUS, because I'm sure hell stab me in the back one day when Im not looking).
Managed to bluff my way through inspection, buying myself a few months time but I knew I had to get this thing fixed. Did some forum searching on here and determined that it's far more likely that its the 02 and A/F ratio sensor, my rig being California CARB compliant so decided to order myself replacements.
looked up the correct part numbers off of Denso's website and incorrectly assumed that all parts with the Denso stamp on them are created equal. The correct part number for my upstream was 234-9002 and shopping around I found one for half the price listed on E-bay. Ordered both the sensors but didn't get around to installing them until 2 months back because the rig was running fine.
Once I replaced the sensors (threw away my old A/F sensor, yes I am a highly educated idiot sometimes) I cleared the codes with my OBD2 scanner and started driving. Immediately noticed jerky acceleration as soon as I replaced the A/F ratio sensor. The Cat efficiency code didn't come back but last week, a week before I'm due to register the car again hence smog inspection time, I got a P1135 which is an A/F Ratio sensor code plus the jerky acceleration/idle which I was hoping was an ECU calibration issue never went away so now I'm stuck with limited time in which to figure out where to order a new 234-9002 from and then run the drive cycles to pass SMOG in order to register the car so YEAH.
TlR bought a cheaper Denso part from E-Bay and got screwed.
Huskie is offline   Reply With QuoteReply With Quote
Old 07-29-2019, 11:33 PM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Well you could have gotten screwed Or there really is something to the P1135.
Our beloved FSM says it's one or more of these causes:  Open or short in heater circuit of A/F sensor  A/F sensor heater  ECM
So are you Sure it's not a shorted wire, connector or ECM?
Luck and enjoy the runner.
Old 07-30-2019, 12:05 AM #3
Huskie's Avatar
Huskie's Avatar
A/F sensor heater is whats showing up on the OBD scanner. Since it started as soon as I put in the new A/F ratio sensor, I'm about 60% positive that its the sensor.
Old 07-30-2019, 12:12 AM #4
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
So grab a DVM and check the heater resistance on the sensor.
If it's in spec, problem is in your wiring.
I get my Denso sensors on Amazon, never had an issue and good prices.
My Backyard Frame Swap
Old 07-30-2019, 12:16 AM #5
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
I've bought Denso oxygen sensors from this place several times in the past. They even worked with me when the 'officially recommended' part number had too short of a wire on it.
403 Forbidden Densoproducts.com, a badge of sparkplugs.com.
pluton is offline   Reply With QuoteReply With Quote
Old 07-30-2019, 12:40 AM #6
Huskie's Avatar
Huskie's Avatar
Thank you so much for the advice & suggestions.
I'm looking at Rock auto for 234-9002 @ $125 I've heard that they are a pretty decent source for parts so thinking of going with them. I really wanted to find a 2002 Sr5 in a junk yard around me that I sould just pull the sensor from but the only one within 50 miles had the whole exhaust system cut out plus I have realized that the worse rust and rounded bolts to be found anywhere on these rigs is usually on the exhaust, my own took about a half a can of butane to take off so I shudder to think of that nightmare scenario.
Old 07-30-2019, 11:55 AM #7
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
That sucks. I've had a similar issue with MAF sensors, they are selling on Ebay for like $15, complete with the Denso logo and correct part numbers. I've tried one, and my LTFT numbers went through the roof. I'm convinced they're Chinese fakes.
The problem is how to know you're getting a genuine OEM Toyota or Denso part, unless buying from a dealer?
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 07-30-2019, 01:23 PM #8
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
I don't even trust Amazon let alone ebay for parts. NAPA has denso parts.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 07-30-2019, 01:26 PM #9
RS Dude's Avatar
RS Dude RS Dude is offline
RS Dude is on a distinguished road
RS Dude's Avatar
When I replaced my o2 sensors last year I too bought a pair of universal fit Densos off ebay that ended up throwing an error code. I was able to return them minus a rediculous 20% restocking fee. Then I bought a new pair from Amazon that were specific to my model, and they have been 100% trouble-free ever since.
'96 T4R SR5 V6 Auto 2WD 329,000 miles
RS Dude is offline   Reply With QuoteReply With Quote
Old 07-30-2019, 01:57 PM #10
Huskie's Avatar
Huskie's Avatar
mind throwing a link from your purchase history for the A/F sensor? I want to buy from the specific seller you bought from so I don't get "Fool me once shame on . . . you . . . . thing is, I cant be fooled again".
Old 07-30-2019, 02:17 PM #11
RS Dude's Avatar
RS Dude's Avatar
https://www.amazon.com/Denso-234-416...Toyota+4Runner
https://www.amazon.com/Denso-234-415...0KKH0HTYCN93QN
Old 08-05-2019, 04:55 PM #12
Huskie's Avatar
Huskie's Avatar
Update: Ordered myself a new A/F ratio sensor off of Amazon and it fixed the problem immediately. No more jerky acceleration and the CEL hasn't come back yet. Now I just need to complete all those damned drive patterns and get the monitors ready for Smog check in the next 4 days.
Old 08-05-2019, 10:27 PM #13
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Ebay is shady AF.
Old 08-05-2019, 10:59 PM #14
RS Dude's Avatar
RS Dude's Avatar
When I replaced my sensors, they had 102k miles on them. They didn't throw a code yet, but I was getting some pinging and exhaust fumes through the back window. The new sensors fixed those problems and more.
Old 08-06-2019, 12:32 PM #15
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
even amazon has fake denso, you really have to look and read reviews.
sometimes you have to think too....let me see denso knock sensor...at dealer 120, at napa 90 amazon "denso" 45 ( with reveiws saying not legit) and then ebay denso , 2 for 25 surely the ebay ones must be legit
a/f , part , ratio , sensor , time
Air Fuel Ratio Sensor and o2 Sensor Replacement - P0136 and P2195 Smurray 4th Gen T4Rs 5 02-25-2019 08:21 PM
Denso O2 sensor blairvt 3rd gen T4Rs 18 10-14-2018 12:55 PM
Air-Fuel Ratio (A/F) Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) vipblades 3rd gen T4Rs 33 10-25-2014 11:06 AM
99 4runner: Do I need an Air/Fuel Ratio Sensor or O2 Sensor? SPFCCMT 3rd gen T4Rs 2 08-05-2014 11:59 AM
Denso o2 sensor sigley0527 3rd gen T4Rs 3 06-17-2013 09:48 AM
