Originally Posted by Bad Luck
1) Since you already have a 4.30 front differential then why swap in another 4.30 front differential?
2)If you're going to re-gear then now would be the time to do it.
3)If they need replacing then replace them. Depends on how old and how hard you've wheeled if you need to replace the LBJ. It's a lot cheaper to do both LBJ's than it is to have them fail on you while driving.
4)Nope
5)Drive slow and avoid highway/freeway.
The main reason I was planning to change out the front differential is that I was contemplating having both of them rebuilt before the swap.
I was more interested in people's opinion of having the differentials rebuilt completely, rather than just changing the gears.
Has anyone had good or bad experiences with rebuild kits? any recommendations on a brand or supplier?
I don't have any plans to run anything larger than 33's so I don't think changing the gear ratio is necessary. Opinions?
