07-30-2019, 04:28 PM
Real Name: Dick
Real Name: Dick
Passenger rear wheel out of alignment??
I took my runner to Firestone to get an alignment since I have their lifetime alignment service (seriously considering switching to discount tire). I just got my vehicle back about 10 minutes ago.
They told me that they could not perform the alignment on the front because the rear passenger wheel's toe angle is -3.35 degrees out of alignment. They didn't offer me any solutions as to what would be the cause of this. They only said, "take it to a frame shop".
I do have a lift installed
Front:
Bilstein 5100 Height Adjustable Shocks (24-248730)
Toytec Front Lift Coil Springs (112-620)
Toytec Differential Drop (TAC-DR)
Rear:
Bilstein 5100 Long Travel Rear Shocks (9602E703)
Stock Land Cruiser 8 Wrap Rear Coils
I will note that I do not have a pan hard drop bracket or an adjustable pan hard bar installed. I am having eimkeith’s pan hard correction kit ( https://www.toyota-4runner.org/for-sale-suspension-wheels-tires/230779-fs-eimkeith-pck-panhard-correction-kits-3rd-gen-$89-4th-5th-gen-$93-50-a.html ) welded in place on the 12th of this month. I have another alignment scheduled for the 13th of this month.
Do you think the pan hard bar could be the cause of this? Upon visual inspection of the wheel, I can clearly see the wheel sitting in the wheel well at an angle. The front of the tire protrudes further out of the wheel well than the rear. I attempted to take a photo of this but I’m not sure how well you can tell.
Are there any other potential causes for this? I am headed outside to take the wheel off and check things out, but I wanted to get this posted up first.
I’ve attached a few pictures and the alignment sheet from Firestone here.
Please let me know what you think. I have family coming into town on the 16th of this month and I really need the runner to be drivable. I will post back with anything I find after getting the wheel off. TIA!
07-30-2019, 04:35 PM
Real Name: Patrick
Real Name: Patrick
Front:
Rear:
I will note that I do not have a pan hard drop bracket or an adjustable pan hard bar installed. I am having eimkeith’s pan hard correction kit (https://www.toyota-4runner.org/for-sale-suspension-wheels-tires/230779-fs-eimkeith-pck-panhard-correction-kits-3rd-gen-$89-4th-5th-gen-$93-50-a.html)welded in place on the 12th of this month. I have another alignment scheduled for the 13th of this month.
Wow! That's a lot of toe! Judging by the total difference in toe (4.08 degrees) you have a bent axle housing. If it were upper/lower control arms out of alignment the axle total toe difference would still be close (usually within a degree). If it were rear wheel bearings it would be more likely to show as camber and would make a roaring noise while driving. A bent axle shaft would be causing a crazy tire wobble that you would be able to see. My $$$ is on a bent axle housing.
07-30-2019, 04:49 PM
Was the truck in an accident before?
07-30-2019, 04:53 PM
Yea, something is way off. How long have you owned it? How long since you installed the lift components? It has to be driving wicked like that!
96' 4x4 5spd-SS1.2
07-30-2019, 05:24 PM
Real Name: Dick
Real Name: Dick
How can I determine if the axle housing is bent?
The truck was rear ended a few months back. This was not a major accident and only the driver side was damaged.
I have owned the truck since 2013. I put the lift on in May of 2018. After the lift I got an alignment and everything was great. I get in it to drive one day (a few weeks ago) and I notice the rear end had significant body roll and in order to drive straight, I have to hold the wheel turned about 1/4 of a turn to the right. Not sure how the alignment got off, but this is why I needed an alignment to begin with.
I assumed the body roll was caused by the pan hard bar needing the correction kit installed so I wrote it off as that. Now that I have visually seen the crooked wheel, I know the body roll is being caused by this.
07-30-2019, 05:48 PM
I think you have a bent frame
07-30-2019, 05:53 PM
Real Name: Dick
Real Name: Dick
No, that’s definitely not it.
07-30-2019, 06:08 PM
Where was the vehicle parked? I bet somebody backed into the tire and bent the axle.
07-30-2019, 06:23 PM
Real Name: Dick
Real Name: Dick
It was parked on the street and it was parked in the same spot for a long time. This is kind of what I’m thinking happened. How hard is it to bend an axle housing? I would think something substantial would have to be hit.
07-30-2019, 09:15 PM
It isn't hard to bend a housing under certain conditions. I owned and operated a Body/Frame Shop for 14 years, and I saw plenty. One of the most common things is getting pushed in to a curb, damage on driver's side but the rear wheel/tire pushed against the curb will bend the axle. That said it isn't super hard to straighten it if you know how, kind of a lost art due to liability issues. I did them for a long time, not anymore. Unless it was mine and I had a good porta power and some chain and possibly some large i beam steel.
Probably easier for you to score a used axle though.
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
07-30-2019, 10:38 PM
Wow. That tires not gonna last long. Agreed that’s its most likely a bent axle housing. I’ve got a rust free non-locker bate housing. And a pair of axles. PM me if you determine you need any of these parts
07-31-2019, 12:38 AM
Real Name: Dick
Real Name: Dick
I appreciate it, but I have an elocker and I don’t have the spare time to modify a non-elocker housing.
07-31-2019, 03:00 PM
Real Name: Dick
Real Name: Dick
I haven't been able to get the wheel off just yet due to living in an apartment complex and having limited tools here (no garage), but at this point, I'm not sure getting the wheel off would show me anything anyway. I believe that the axle housing is bent as you guys have pointed out. I found a complete axle assembly with the factory e-locker locally for $800. To make sure the new rear end gearing matches the front, this price also includes the matching front differential. I also need to install new CV axles while I'm at it and the same person has these as well for $60.
I think I am going to snag this up while it is available. Now my questions about this...
1. What other components should I replace while doing this swap?
a. I am planning to install new bushings in the upper and lower control arms and new bushings on the pan hard bar.
b. My axle seals were leaking before this happened and I already have the parts to replace the seals and the wheel bearings on order.
c. I will be rebooting the CV axles that I buy from this guy and swapping these out.
d. When I installed the lift a year ago, I installed all new tie-rod ends, so I know these are good. I also installed new poly tie rod end bushings and sway bar bushings.
e. I have all of the parts needed to replace the rear brakes. When I attempted this repair is when I noticed my leaking rear axle seals. The rear brakes will be new.
2. Should I have new gears installed in both differentials while they're out and accessible?
3. Should I go ahead and do upper and lower ball joints on the front?
4. Anything else you can think of?
5. Since I live in an apartment complex with no garage, is the truck safe to drive to a location where I can do the repairs, in its current condition?
Reason: #5
08-01-2019, 10:13 PM
Real Name: Dick
Real Name: Dick
Bump
08-01-2019, 11:31 PM
Whether or not it's safe to drive would depend upon how far and how fast you're going to drive it. You could drive 30 mph for a long ways, probably not far doing 80.
