Old 07-30-2019, 08:43 PM #1
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
Brake drum backing plate replacement
Need a quick sanity check - can I replace the brake drum backing plates without having to press off the ABS tone ring and retainer? The dust ring on the perimeter that rides over the edge of the drum is rusted through on one side and beat to shit on the other.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 07-30-2019, 10:28 PM #2
BrianK14 BrianK14 is offline
BrianK14 is on a distinguished road
Nope. Snap ring removed, then tone ring and retainer must be pressed off. And the bearing has to be pressed out of the old backing plate, or replaced.
BrianK14 is offline   Reply With QuoteReply With Quote
Old 07-30-2019, 11:31 PM #3
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
Technically yes. You'll have to cut the old one off, and cut the new one to fit back on. Not the best method, but others have done it.
Mike
MStudt is offline   Reply With QuoteReply With Quote
Old 07-31-2019, 05:46 AM #4
thezentree's Avatar
thezentree's Avatar
Why you do me like this, Toyota? This axle swap just doubled in cost....
Thanks y'all.
Old 07-31-2019, 09:36 AM #5
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
It's easiest to keep an eye on the local pick and pull place and get 2 whole new half shaft assemblies for like $25 each, if you can find a clean set with bearings that look ok.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 07-31-2019, 11:53 AM #6
Mike
Not on the rears. Bearing is pressed into the backing plate
Old 07-31-2019, 12:12 PM #7
thezentree's Avatar
thezentree's Avatar
Just realized you’re local to me - have you done all this before?
Old 07-31-2019, 02:14 PM #8
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
You're 100% correct. You can only do it on the front dust shields.
Mike
backing , brake , drum , ring , rusted
5th gen brake backing plate? Terminator03 4th Gen T4Rs 8 11-01-2018 07:53 AM
Front Backing Plate Replacement Mbaue825 4th Gen T4Rs 3 04-18-2018 02:12 AM
Rear Brake Backing Plate Sheild Rebuild cferry7 Classic T4Rs 5 11-26-2015 05:49 PM
Rust rot on rear drum backing plate. Suggestions? hamiltonshmamilton 3rd gen T4Rs 2 09-14-2014 11:39 PM
Rear axle/Drum backing plate replacement jsmith7 3rd gen T4Rs 4 04-15-2014 02:42 PM
