Old 07-31-2019, 04:42 PM #1
eurasiaoverland eurasiaoverland is offline
eurasiaoverland is on a distinguished road
Loud knock when manouvering - bad transmission mount?
I have an untraceable heavy knock on my 3rd Gen. It happens when manouvering at low speed, typically when backing into a parking space and turning the steering / moving from forward motion into reverse. It's a depp thud, which sounds like it's going through the chassis. I don't feel it through the steering. It is not coming from the UJs or diff as it does not happen when I take up the drivetrain slack with the clutch (it has a manual transmission). The vehicle is not in 4WD.
It doesn't happen every time, but often enough to annoy me. I keep the vehicle in fine condition and have rebuilt most of the drivetrain over the last few years. Here are a list of things I am 99% sure are NOT causing the noise:
-Upper and lower ball joints new, genuine, nuts correctly torqued
-Upper and lower control arm bushes good, bolts tight.
-Front wheel bearings relatively new, genuine, no play.
-Steering rack has new, genuine inner and outer tie rod ends.
-Rack is not leaking, has a new, updated rack-guide. Slop in the steering is normal.
-Rack bushes relatively new, bolts tight.
-Engine mounts relatively new, genuine.
-Front caliper bolts tight, pads secured with pins.
-All UJs good, backlash in the rear diff fine.
I'm pretty stumped as to what could be causing this noise. It never happens whilst moving at speed, only at low-speed manouvering.
I'm not with the vehicle right now, but the only thing I can think of is that the transmission mount looked to have 'collapsed', i.e. the top part (which bolts to the transmission case) is sitting on the lower part, even though the rubber looks intact. Could this cause a heavy thumping sound??
Thanks
EO
1993 Hilux 2L diesel manual, 450,000 km, mint
1996 Hilux Surf 3RZ-FE manual, mechanically overhauled.
Over 250,000 kilometres around Eurasia in Toyota trucks: http://eurasiaoverland.com/
eurasiaoverland is offline   Reply With QuoteReply With Quote
bolts , genuine , steering , transmission , vehicle
Transmission mount? uncleslam23 3rd gen T4Rs 1 05-16-2013 06:01 PM
Transmission Mount Please HELP!!! gmata 3rd gen T4Rs 18 01-10-2012 01:16 PM
Transmission Mount Uberisfine Classic T4Rs 7 10-17-2011 11:23 PM
Strange Transmission Knock - any ideas? AKABlig 4th Gen T4Rs 1 12-15-2010 12:42 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
