Originally Posted by t4rFL
Wow I always buy my batteries from Autozone, never had a problem. Usually 30 minutes or so
thats a pretty short warranty
I would suspect contacts or bad grounds. Bad grounds are easy to check, just pull and clean where they mount to the body etc.. there is one behind the engine not so easy to get to. some people do the big 3....that gives bigger better grounds and power. However a friend just ran an extra ground from the body ( fender bolt if I remember) to the alternator mount. this gave him another engine ground incase the one behind the engine goes bad
also while some people like the original Toyota battery connections, I don't and have had issues with them, however still running them, just need to really clean and make sure they are tight, I had to remove a rubber spacer in mine to get them to tighten around the terminals.
But that's another project when I find some I like, but not in a hurry
