Old 08-04-2019, 06:30 PM #1
amajo75 amajo75 is offline
amajo75 is on a distinguished road
Hard brake line part #
2004 4Runner passenger side front
Hard line from caliper
Anyone know the part number? I am out of country and have very limited service.
Any help is appreciated
Hard brake line part #-487c553e-8a13-4df2-a5a7-be55255323fe-jpg
amajo75 is offline   Reply With QuoteReply With Quote
Old 08-04-2019, 07:28 PM #2
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
Not sure if all '04 are the same, but this looks like the number -
TUBE, FRONT BRAKE, NO.4 47314-35320
4731435320 Toyota TUBE, FRONT BRAKE, NO.4 Price: 2.84$, Weight: 0.029kg - PartSouq - Auto Parts Around the World
TOYOTA 4RUNNERGRN215L-GKAZKA - POWERTRAIN-CHASSIS - BRAKE TUBE CLAMP | Japan Parts EU
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 08-04-2019, 10:38 PM #3
nobb nobb is offline
nobb is on a distinguished road
The 8" pre-made length available at any local parts store also fits. It is extremely easy to bend this front line. Just buy 2 or 3 lines if you are nervous about messing up...it will still be cheaper than buying the OEM part. If you are competent enough to do your own hard brake lines, chances are bending this will be no problem.
nobb is offline   Reply With QuoteReply With Quote
Old 08-05-2019, 08:08 AM #4
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
I just ran into this over the weekend, broke a line doing brakes. Could only find parts store lines with extended bevel on both ends, see the pic on the OEM line has the caliper nut as full thread. So I did install the generic ones from O'reillys but could only catch a minimal amount of thread on caliper. It works but just very barely, so was planning getting a couple oem hard lines. Where are the generic lines available with one side bevel end and one side full thread? Or not sure if full thread both sides would work. I favor oem, but good to know alternative in pinch.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 11-09-2019, 02:16 PM #5
Bdnewyork's Avatar
Bdnewyork Bdnewyork is offline
Real Name: Robert
Bdnewyork is on a distinguished road
Bdnewyork's Avatar
Real Name: Robert
Reviving this thread to seek assistance with rear brake hard lines. I'm doing an elocker upgrade swap and I bought a mint condition bare elocker housing off ebay. To minimize downtime, I bought a junkyard non locker rear. Pretty rusty; but backing plates / axles good. Hard lines not so much. The idea is pull the axles out of the junkyard axle assy, rebuild brakes, do the presswork for new bearings and seals, fully assemble the new elocker and swap the two complete rears.
My 1999 (build date 09/1998) was originally equipped with 15-inch wheels. I don't know what the the donor rear truck was equipped with; but it has the earlier brake config (pre-01) and wheel cylinders have a 1 on them, which makes me think it was from a 16" wheel truck.
OE Toyota hard lines are not too expensive; but I'm now seeing no less than 7 optional part #'s for each side. Does anyone have insight into what the differences could be? I can find only 2 different backing plates part #'s: 08.2000 - 08.2002 & 11.1995 - 08.2000, so I don't think there's any difference whether one had a 15 or 16-inch wheel. So why different part #'s for the lines?
I also don't know what the elocker housing was allocated to. Are their any known housing differences with regard to hard lines? My gut suggests I opt for matching my build date and go for the 16" wheel parts. Looks like what I thought would be an easier plan is the exact opposite. I'd rather avoid having to flare custom lines.
Thanks for any input offered.
Hard brake line part #-screen-shot-11-09-19-11-46-am-png  Hard brake line part #-screen-shot-11-09-19-11-45-am-png
Bdnewyork is offline   Reply With QuoteReply With Quote
hard , limited , line , part , service
front brake hard line OEM part number or equivalent DK327 3rd gen T4Rs 22 04-29-2019 09:55 PM
Help: part number for brake hard line blackfc3s 4th Gen T4Rs 3 11-12-2017 03:34 PM
WTB: Rear axle hard brake line 3rd gen J-money$$$ Want to Buy/Trade 4 11-12-2015 06:46 PM
HELP NEEDED: Front Brake Hard Line? BamaDrewski 3rd gen T4Rs 3 05-05-2015 10:21 PM
Pinched hard rear brake line. Ideas? J-money$$$ 3rd gen T4Rs 8 05-28-2011 12:05 PM
