Old 05-30-2021, 07:18 PM #1
stoney stoney is offline
stoney is on a distinguished road
brake part numbers for 2000 4runner limited
Hi,
Does anybody have the OEM part number for the 2000 4runner limited brake pads, rotor and caliper?
Currently I have:
brake pads: 0446535240
rotor: 4351235210
caliper: Front 47730F4020 (right) 47750F4020 (left)
Did I get the correct OEM part numbers?
Thanks,
--stoney
stoney is offline   Reply With QuoteReply With Quote
Old 05-30-2021, 09:16 PM #2
spartacus's Avatar
spartacus's Avatar
Originally Posted by stoney View Post
Hi,
Currently I have:
rotor: 4351235210
Thanks,
--stoney
The rotors are correct for 16 inch wheels The caliper part numbers that I have.
LH 47750-35120, RH 47730-35110. Might as well throw in new pins and anti rattle front brake kit 04947-60080 and shim kit 04945-35040.
Old 05-31-2021, 04:12 AM #3
Thank your for your response.
The calipers with part number you listed are much more expensive. So yours are the correct ones?
--stoney
Old 05-31-2021, 08:36 AM #4
spartacus's Avatar
spartacus's Avatar
--stoney
Oem parts are generally quite expensive,The part numbers I have are for 2000 with 16 inch wheels.The caliper part numbers, you posted are not for 3rd Gen 4runner. Why are you replacing calipers? You can easily rebuild them.
Old 05-31-2021, 12:46 PM #5
I am going to replace just the front rotors and pads. I am just collecting the part numbers for calipers in case I need to replace them in the future.
As for rebuilding the calipers, how can it be done? Is it just to replace the wore parts with the same OEM parts on the calipers? Will you kindly share the idea or related OEM part numbers? Thanks again.
--Stoney
Old 06-01-2021, 08:48 AM #6
spartacus's Avatar
spartacus's Avatar
--Stoney
Most folks on here upgrade to tundra brake calipers and rotors but there are numerous rebuild kits, Rock auto has some options, so does amazon.
Here is a video of 2003 tundra brake caliper rebuild but the process for 3rd gens would be about the same.
https://www.youtube.com/watch?v=qoQlAW4DPnA&feature=youtu.be
Old 06-01-2021, 07:07 PM #7
genie genie is offline
Real Name: 97 2wd 4cyl 5sp manual
genie is on a distinguished road
Can that Tundra upgrade work on 15" wheels too?
genie is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 07:27 PM #8
spartacus's Avatar
spartacus's Avatar
AFAIK it won't also 16 inch six spoke oem wheels. some 16 inch wheels require hubcentric spacers or a little grinding off of the calipers.
Which Wheels/Rims Fit the Tundra Brake Upgrade (13WL 231mm rotors) on a Tacoma? (or 3rd gen 4Runner) – ADVENTURETACO
Also the following thread is long but good info.
Hard to find Specs, Info & Measurements on 231mm 13WL Tundra Calipers & Rotors
Old 06-01-2021, 07:27 PM #9
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
The part numbers for the brake pads and rotors are correct.
However, the part numbers for both calipers are NOT for the 2000 Toyota 4Runner. These are for the Toyota C-HR.
Hi,
Currently I have:
rotor: 4351235210
Thanks,
--stoney
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
brake , caliper , numbers , part , rotor
3rd Gen 4runner Oem Coil Spring Part Numbers Wikano 3rd gen T4Rs 4 04-05-2022 09:33 PM
REAR Brake Part numbers needed tb-av 5th gen T4Rs 3 02-07-2019 09:56 PM
Rear Brake Napa part numbers for 2008 Sport 4wd V8 AZ4runner08 4th Gen T4Rs 3 09-15-2014 03:10 PM
Limited Part Numbers Vortec4800 4th Gen T4Rs 5 07-11-2004 12:36 AM
