Old 10-30-2019, 06:52 PM #16
mesooohoppy mesooohoppy is offline
mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about
thank you for that info @UnderFire . it looks like the 121 hub has the same exact smooth backside as i have. how did you wire in a horn?
i think i might be able to make something work, but its going to require me to completely butcher the clockspring and drill a small hole in my steering wheel hub. a QD is also a great security tool. i also have had the same personal wheel for close to 10 years now, so im trying to keep the leather in as good of shape as possible. when i had the personal wheel on my other cars in the past, i bought it in during the summer due to the excessive heat and UV rays.
can someone please confirm that the black/white wire below is for the horn ground/horn? i cant find any wiring manuals.
thank you in advance
99 4runner limited; imperial jade mica
IG: mesooohoppy
mesooohoppy is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 01:50 PM #17
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
I've not hooked up the horn or any kind of airbag resistor on mine, I never use the horn anyways and the light doesn't bother me so I'm little to no help. I've seen online some people buying a little flap the rides against the hub's contact, I believe it came stock on a Honda if I remember right but it's been a long time since I read about it.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 11-01-2019, 11:55 AM #18
thank you, is this what you are talking about? specifically step 5?
How-to wire JDM horn | Honda Integra DIY
i think i may be able to make that work and it would be a nicer way to do it then what i had in mind. now i just need to find a wiring manual to confirm the white/black wire is the horn/horn ground.
IG: mesooohoppy
Old 11-01-2019, 10:09 PM #19
UnderFire's Avatar
UnderFire's Avatar
Yep looks like it. Black wire is going to be ground anyways, so I'd just stick a wire in it and ground it out see if the horn goes off.
Old 01-14-2020, 10:55 AM #20
run-matsuo run-matsuo is offline
run-matsuo is on a distinguished road
Here is a useful guide on an IS300.
https://www.youtube.com/watch?v=ZV-PIBQczWM
I've installed dozens of wheels over the years and am about to install my old Nardi Classic on my 3rd gen. I'll make sure to take pictures and do a little write up. Getting the horns to work isn't hard after you do it the first time.
run-matsuo is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 02:59 PM #21
how close is this to a 3rd gen? i see he has two wires for the horn? i only have one? the clockspring looks the same.
i acutally ordered pre wired resistors that are supposed to just plug into the female airbag clip, so i dont need to butcher or mod anything. it has to come from euro land, so ive been waiting for those to come.
underfire is on to something regarding the honda shoe horn. unfortuneatly the honda forum link he provided doesnt work anymore. but the contact piece is part number: 35259-SH3-A02.
it looks like this:
(its the brass looking piece)
please update with your findings, and i will do mine once i get my resistors. here is what i bought:
Universal airbag resistor kit 6pcs | eBay
(sellers name is str-pcb if that listing goes down)
IG: mesooohoppy
Old 01-15-2020, 04:10 PM #22
The Nardi Classic I have has a hub attached (looks like HKB). It came off a Toyota Mark II I owned back in the day in Japan. I looked at it this morning and it definitely won't work with the clock spring, which I don't want to remove just to install my Nardi.
Jumped on the HKB Japan site and looked up the part number for the 185 Hilux Surf here:
?????? ????????/????/????/HKB SPORTS/????????/??
With airbag and "monitor lamp" the part number is OT-202. Did some Yahoo JP searching and this is the hub the Surf guys are using and not having to pull the clock spring. It also comes with the resistor for the air bag light and connector for the horn.
I ordered one off Yahoo Auctions for $60. As soon as it gets here I'll get my Nardi installed and post up the results. Here is a link to HKB OT-202s on YA:
ヤフオク! -HKB OT-202の中古品・新品・未使用品一覧
Old 01-21-2020, 04:02 PM #23
quick little update. my resistors came in from europe, but they are far too small to just plug into my airbag plug:
the very helpful video that is linked in post 20 shows the guy just push a single resistor into the clip. i cant find any 2 ohm resistors locally, so i bought 2 one ohm resistors before i broke down and bought the pre made ones from europe. this leaves me with a couple of options for the airbag light:
-attempt to push both resistors in and see how they fit (i will likely do this first). although i am not sold on this and i think they may come loose over time. if this works it will be awesome and means i dont need to cut the clip off
-create a harness for the super small resistors and cut the clip off on the harness and join with spade clips. this is what i will probably end up doing if the first option does not work.
-i could always cut off the clip and solder the resistors inline on the car. i have done this in the past and its a PITA and looks terrible (even though you cant see it). i am going to avoid this option and just spring for #2 if i need to do soldering.
finally, i still need to order the shoe horn. will do it sooner than later.
IG: mesooohoppy
3rd , gen , nrg , thread , wheel
Replacing steering wheel with another Toyota/Lexus model steering wheel LexusFTW 3rd gen T4Rs 20 03-04-2021 12:24 AM
XUJI leather steering wheel cover install. Goodbye plastic steering wheel. OEM? Kelbad 5th gen T4Rs 24 05-19-2019 03:51 AM
Front End Work Estimate : LCA, CVs, Wheel hubs Dylan 4th Gen T4Rs 16 03-05-2019 11:12 PM
Wheel Spacers for First Gen/auto hubs jreask Classic T4Rs 5 07-01-2012 09:14 PM
4x front wheel hubs SwiftRunner Classic T4Rs 5 09-05-2011 08:16 AM
