Old 12-13-2019, 05:34 PM #121
No worries on the starter then. Starters are easy to change on the 2WD's...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 12-15-2019, 02:03 AM #122
STI_MECE's Avatar
STI_MECE STI_MECE is offline
STI_MECE will become famous soon enough
STI_MECE's Avatar
She pures like a kitten. Way quieter than my old engine.
Gave me a scare for the first two starts she was running really rough. Killed it after five seconds on the first two starts. Thought it was a bad egg. Checked everything again and again everything was correct.
And boom the third start up she was purring away.
And before all of that i manually primed the engine with oil. Turned the crank quite a few times after putting 5.5 qts of oil in. Then k stomped the gas closed the injectors and cranked engine for three 2 second intervals.
On to the next project ;)
224,480 Miles on 2000 Body
144,000 Miles on 1999 Engine
2000 SR5 4x2 Resto/Maintenance
STI_MECE is offline   Reply With QuoteReply With Quote
Old 12-15-2019, 08:49 AM #123
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
On to the next project ;)[
Congrats. Glad it running again
Old 12-29-2019, 01:25 PM #124
STI_MECE's Avatar
STI_MECE's Avatar
Got a present for the NoRunner
Sent from my Pixel 3 XL using Tapatalk
Old 12-29-2019, 03:23 PM #125
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
So this is the vaccuum leak cause under heavy deceleration? Or are you hoping this is?
You bought a brand new 3rd member for your runner?
Old 12-29-2019, 11:08 PM #126
STI_MECE's Avatar
STI_MECE's Avatar
It solved my noise issue.
And yes I bought a brand new one. I got employee pricing on it.
I had the money to blow so no biggie.
Old 12-30-2019, 09:30 AM #127
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
At least you know what rear end warn bearings and gears sounds like now and it solved your problem. Glad she is fixed. Great job!!
Old 01-03-2020, 06:37 AM #128
STI_MECE's Avatar
STI_MECE's Avatar
New goodies for the truck.
Solder my harness together. The harness in the truck before hand was down right chicken shit
And finally got my stick welding machine going that I got for my birthday. 20% duty cycle at 210 DC amps for 459. Hobart 210i. I know all the runs aren't the best, that was intended. I had a awkward table I was trying to get comfortable on.
Gunna start designing a few things for the truck. I got connections on a steel mill and can get a varietyt of stock pieces for dirt cheap
Old 01-04-2020, 12:45 AM #129
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I seen people's radio harness alot worse then that before. That at least had the connections covered with insulation. I seen people leave the connections not covered before.
Granted it's not the greatest. Your looks alot better with the soldered connections and heat shrink over the solder joints.
Old 01-04-2020, 12:46 AM #130
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
You practicing??
Old 01-06-2020, 03:22 PM #131
I find when I leave the harness that long that it is a hassle to fit it back behind the stereo. Now, when I do radio harnesses, I cut about 2/3 off each side and make much shorter patch harnesses. Otherwise, good work!
Old 01-06-2020, 05:11 PM #132
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
time to do a 2uz-fe swap along with 4wd now that you have a welder!
APhelps is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 05:30 PM #133
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I leave them long like that so I can recycle the radio harness about 3 to 5 times on different vehicles.
I cant see that being an issue on a 3rd gen as there is plenty of room behind it. ;)
Old 01-06-2020, 05:46 PM #134
Ha, yeah. There's room for an extra amp in the OEM setup, so there is room on the 3rd gen. Many other vehicles are pretty limited behind the radio (or, like my Camry, have other aftermarket stuff back there too).
Old 01-28-2020, 08:34 AM #135
STI_MECE's Avatar
STI_MECE's Avatar
(Maybe) Writing the final chapter on this book
So the noise came back shortly thereafter putting a new 3rd member in. But, I did figure out what is causing the noise, its my pinion angle. Along with the fact that my slip yoke was not fully engaged on the output shaft of my transmission.
How did I figure this out? I had about 500lbs worth of steel in the trunk, and to my amazement the noise went away. I did have subtle drive-line vibrations but I feel like that is small beans compared to what noise I had before.
Adjustable upper rear links should fix this. I would have honestly rather replaced the rear springs though but its still no guarantee.
And I got inspired to start working on another vehicle, its going to take more coin to build.
But I am going to be (possibly) selling this one in a few weeks but will not sell it till my drive-line issue is 100% resolved. Probably 8k is what my asking price will be....that is the amount I have just in parts alone on this thing lol If it had working AC it would be slam dunk, luckily I still get heat lol
Live and learn folks. and boy did I learn.
cars , drive , engine , lift , thing
89 sr5 4runner 3.0 on going resto raynyc Classic T4Rs 9 01-17-2017 01:21 PM
1988 First gen resto-mod Toyotafan03 Classic T4Rs 37 11-07-2015 04:45 PM
Status of 2014s? MidwestJ 5th gen T4Rs 4 08-17-2013 07:18 PM
my 86 resto/buildup jason in tn Classic T4Rs 29 06-11-2013 02:30 AM
Runner resto? vol4runner 3rd gen T4Rs 0 02-07-2011 02:12 PM
