Similar Problem
This has happened twice, now, so I don't want to ignore it: when I turn the key to the starter, everything goes out - it's like I disconnected the battery. I can jiggle the ground, and everything eventually comes back on.
I know the battery is good. The connectors at the terminals were corroded, so I change them to after-market; but they seem to be connected ok. I didn't want to remove the entire ground wire, as it seems to be wrapped in the harness; so I cut it, peeled the insulation back, and attached it to the connector. It appears to be a good connection, but, as I said, I can jiggle it, and the power comes back on.
If the cable is my problem, how hard is it to replace the ground cable?
