Old 11-15-2019, 04:04 PM #16
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Do you happen to have a few frozen wheel cylinders or stuck pistons in the calipers?
Maybe everything else is good. And your brake calipers are freezing.
However, you would feel warmer wheel hubs and rear drums would be hotter then normal..
I am just thinking and can be wrong here. Just throwing ideas out.
Old 03-23-2020, 11:07 PM #17
rideexileex's Avatar
rideexileex rideexileex is offline
rideexileex will become famous soon enough
@greeney - what's the latest?
2000 4Runner Sport - TRD&AEM SuperCharged
Solo Long Travel & KING 2.5 & bumps, 4th gen rear axle & KING 2.5 12's
F+R ARB's, 4.88 Yukon's, 295 KM3s
rideexileex is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 05:22 PM #18
HiLife HiLife is offline
Greeney left us hanging. Im trying to run down this issue also.
Old 10-27-2020, 05:35 PM #19
ølaf ølaf is offline
ølaf is on a distinguished road
@HiLife - in my case, it ended up being glazed pads and rotors. No idea how/when that happened. Put on a new set of pads and rotors, and I'm back to business. Although, with the ceramic pads, it does take a few stops for them to really bite.
Quick list of all my troubleshooting:
- New OEM Brake Booster
- New OEM Brake Booster Valve
- New Vacuum Hose
- Multiple Brake Bleeds
- New fluid
- Measured and confirmed intake manifold vacuum
ølaf is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 06:22 PM #20
Wow, you went with an oem booster? Going rate for those is $918 alone! It would be the correct way to go though.
My ultra gauge gave me a BIG hint just now, it tripped the p0171 lean code and my fuel trims are up there. Seems to be I have a huge leak/tear with the rubber diaphragm in the booster. I checked and doubt mines is leaking past the bb hose.
Old 10-27-2020, 06:29 PM #21
Hmmmm .... do you really think a leak in the booster could cause a lean air-fuel ratio? How about just plugging that vacuum line or nipple, clearing the code, and see if it trips again?
- olaf
Old 10-27-2020, 07:05 PM #22
I still have to troubleshoot further to confirm that is my issue.
All the air entering the intake has to go through the maf where it is measured by the ecu. Any extra air after the maf gets picked up the the air/fuel o2 sensor and triggers a lean code.
Old 11-02-2020, 03:13 AM #23
Update: it ended up being my brake booster was my hard brakes issue. Replaced with a Toyota unit and all is fine again.
At first, I switched out the booster hose with a toyota one, no change. Switching out the check valve with a toyota one, no change.
My short term fuel trims pegged into the 19s everytime I stepped on my brakes while the rig was moving above 5mph. Let go the brakes and stft went back to normal +/- 2. During all of this rig ran fine. No jump in rpm like you get with a vacuum leak, no rough running.
The bad booster did set a P0171 code, even after I erased it.
Old 03-13-2023, 10:36 PM #24
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Sorry to bump an old thread. Is it possible to remove the check valve and clean it with lets say brake cleaner? Servicing brakes and my pedal is rock hard on a cold morning. I know people like to clean PCV valves when they are clogged but I want to see if this method can be applied to the check valve before I replace it with a new Toyota part.
2000 4Runner Limited 4x4 V6
Old 03-14-2023, 01:22 PM #25
Certainly worth a shot. You can also remove it, and put it into your freezer, then try to suck through it in the right direction, to see if the booster valve is the problem. Most people just swap them out with an OEM one, when they experience your symptoms. It's one of the cheaper parts to throw at the problem. If you do go that route, make sure to get a new grommet as well.
Keep us posted!
- ø
Old 03-14-2023, 01:47 PM #26
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
It is only plastic so yes, definitely something you can do! Can't really hurt it unless you start jamming something through the valve. Best to diagnose and possibly replace the cheap stuff before the more expensive items.
326WHP 347TQ
booster , brake , hard , pedal , vacuum
Strange brake issue - hard pedal Renton4runner 3rd gen T4Rs 22 11-15-2019 04:11 PM
Hard Brake Pedal During Panic Stops - Brake Booster? Friday88 3rd gen T4Rs 23 11-01-2019 04:15 PM
Hard Brake Pedal? Brake Accumulator? beatadrum 4th Gen T4Rs 2 02-17-2018 12:33 AM
Solved my 3rd-generation 4Runner severe brake pedal pulsation at highway speeds mom 3rd gen T4Rs 33 06-20-2016 01:43 PM
