Old 08-07-2019, 03:18 PM #16
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Originally Posted by Zscarlson1 View Post
Yeah you had some good luck. I wish I was that lucky but I am not. I also just don’t need to lift it, which is why I’m not this route. I love the way they look but I’d want to get new wheels and tires which I shouldn’t afford. That’s awesome though!
Well, maybe I can add some luck? I just swapped out my original '99 springs (rear only, haven't done the front yet) with 190k miles and you can have them if you want them. I'm in GA, south of Newnan just outside of Manchester and go to LaGrange about once a week (Thursdays normally), could do Newnan with notice though. Too much effort to ship, but I'll gladly hand them to you in person. If, for some reason, you want all 4, I ought to have the fronts in a couple weeks (going camping this weekend).
I measured the springs at 20.5" from hub center to the bottom of the fender flare (limited flares measure different than the smaller SR5 and chrome trim if you have those). Based on what others have posted of their springs, they haven't sagged much at all but compare to what you have now.
Brian. is offline   Reply With QuoteReply With Quote
Old 08-07-2019, 04:41 PM #17
AntleredRuin AntleredRuin is offline
Real Name: Daniel
AntleredRuin will become famous soon enough
Real Name: Daniel
I've been running '99 Talls Moog rear springs for about 2 years and I'd say they're worth it. Still have a decent rake when unloaded and sit level with the back loaded up with tools and computers for work.
$36 well spent.
AntleredRuin is offline   Reply With QuoteReply With Quote
Old 08-07-2019, 04:59 PM #18
Huskie's Avatar
Huskie Huskie is offline
Huskie is on a distinguished road
Huskie's Avatar
I Just religiously searched crigslist / KSL / facebook every day until I found what I was looking for. Got very lucky with the 881 OME springs although I don't really like them that much.
Huskie is offline   Reply With QuoteReply With Quote
Old 08-07-2019, 09:47 PM #19
Koba Sho Koba Sho is offline
Koba Sho is on a distinguished road
I bought amazon suspension on my brother 4Runner
Been 3 years now with no issue.
I believe they were pretty cheap and it was just a knock off oem part I believe.
Koba Sho is offline   Reply With QuoteReply With Quote
Old 08-09-2019, 05:08 PM #20
Zscarlson1 Zscarlson1 is offline
Real Name: Zach Carlson
Zscarlson1 is on a distinguished road
That's an awesome offer! I did order the Moog/KYB combo all around along with some 2.5" Daystars for the front and rear just because I know I'd want to do it later on. Thank you though! Now to just figure out how to assemble the strut assembly for the front together.
Zscarlson1 is offline   Reply With QuoteReply With Quote
Old 08-10-2019, 10:00 AM #21
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
You made a good choice for what you want to use the vehicle for. You will need a strut compressor to safely assemble the front struts and will need a pair of new strut mounts (tops) also.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 08-10-2019, 11:36 AM #22
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
I picked up a pair of KYB upper mounts from Amazon when I replaced my front struts/springs couple weeks back.
Also picked up a low cost but good quality spring compressor on Amazon which worked out great.
Replace Suspension-83f9b37f-584a-441e-85b8-f1cf219bfe12-jpg
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 08-19-2019, 02:56 PM #23
Thank you! I got them all assembled safely and fine. The only thing now is - over speed bumps, the suspension pops if I go over a reasonable speed (didn't before swapping). Any ideas? I know it's a plethora of things but just wanted any easy fixes. KYB/Moog setup.
Also just made a post involving the 2.5" lift that I had problems with if anyone wants to help me chime in on that issue
Old 08-21-2019, 04:54 PM #24
thehuckster thehuckster is offline
thehuckster is on a distinguished road
I wonder if my loud noise and harsh offroad ride is my front ToyTecs n shocks are shot??? it rides great on the pavement and at slow speeds but has gotten worse at medium speeds over bumps....
thehuckster is offline   Reply With QuoteReply With Quote
buy , don’t , low , rear , suspension
What do I need to replace stock suspension? xwhenximxgonex 4th Gen T4Rs 2 07-30-2017 10:43 AM
Going to replace some suspension parts mplsdunk 3rd gen T4Rs 5 03-13-2015 11:44 PM
suspension: when to replace? Jeremy03Sport 4th Gen T4Rs 7 04-05-2014 02:58 PM
New suspension coming soon! Anything else i should replace? sierra_summits 3rd gen T4Rs 6 11-20-2012 01:14 AM
Need to Replace/Upgrade Suspension Arctic 4x4 Classic T4Rs 4 07-28-2008 02:42 PM
