06-03-2016, 01:00 AM
Real Name: Dane
Real Name: Dane
What Batteries are you using?
I know there is several threads on this, but none of them are recent.
I've been thinking about doing a dual battery setup, and I'm unsure what batteries to go with.
With redtops being manufactured in mexico and diehard platinums discontinued, I'm at a loss.
Odyssey is a good option I know, but they are a bit pricey.
1997 4Runner SR5
E Locker, Toytec Boss Coilovers, SS 1.2 Rear, Toytec 1 in. BL, ARB Front Bumper, homemade rear bumper w/ swingout, RCI Skids, Stubbs Sliders, KMC Enduro with 285/75/16s.
Build Thread
06-03-2016, 01:42 AM
I don't have dual batteries but I have a duralast platinum that's pretty decent
'96 4runner Limited - Automatic 4wd with factory E-locker - LT265/75r16 BF Goodrich KO2's - Toytech/Eibach front coils and LC 8 wraps with Bilstein 5100s all around - SPC UCAs - AOR Plate Front Bumper - 4xinnovations Rear Swingout Bumper - HD-SKO Sliders
06-03-2016, 01:53 AM
If you want to spend a bit, you could look into Stinger, XS Power or Northstar.
For the lower end of the scale, Interstate is the king, the DCM series are great if you want deep cycles.
'97 3RZ 5 Speed "FrankenRunner" ( Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - ( Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
06-03-2016, 02:06 AM
Just recently plunked down for an Odyssey 34R-PC1500.
Pricey as you say, but I was shopping for utter reliability (reputation and warranty), and AFAIK Sears doesn't do the DieHard Platinums anymore, which was my first pick.
06-03-2016, 02:30 AM
Real Name: Keith
Real Name: Keith
Odyssey PC 1500 group 34R...'R' for reversed terminals. It was worth paying an extra $80 for the battery to avoid the hassle of fabbing reversed cables. The second batt is a slightly older Die Hard Platinum.
06-03-2016, 07:35 AM
X2 Power (Northstar) SLI24F AGM DP 585 Cold crank amps dual purpose. It's a heck of a juice box. Highly recommend Northstar.
.::TRD; no, your jeep can't fallow this.
2000 Black 3.4 N/A 5 speed 4x4, most recent mod: OE e-locker setup with 4.30 gears from an auto. ARB front winch plate bumber in the garage.
She's, starting to be less stock, with about 226,428 miles as of 5/27/16.
06-03-2016, 08:12 AM
Special stereo needs aside, a battery is a battery.
As long as there is 12 volts and lots of CCA (cold cranking amps 8-900) your good to go.
I found that national brands = national retailers like Wal-Marts , Costco etc. translates to an available replacement no matter where you are. And they seem to have the most liberal replacement warranties as well.
I found this out the hard way when I had a special battery in the car .
Battery died after 7 years and of course it was after hours on the weekend.
Couldn't get a replacement until the following Monday. Now the car has a regular battery.
06-03-2016, 08:55 AM
24F Interstate Battery from Costco.
42 month warranty
$82.99
2006 V8 with 180k on the clock.
The battery will outlast my truck...
'01 SR5 3.4 V6 4WD
'04 SR5 4.0 V6 2WD
'07 Tacoma 4.0 V6 4WD
'06 Sport 4.7 V8 4WD
'10 Limited 4.0 V6 4WD
06-03-2016, 09:15 AM
I've had awesome luck with Duralast. Currently rocking a Duralast Gold.
06-03-2016, 09:18 AM
42 month warranty
$82.99
I'm running the same battery from Costco. No issues at all bit I've also only had it for a few months, you can't beat the price/warranty.
06-03-2016, 09:23 AM
Buy the one with the best warranty.
1996 T4R Limited - stock
1997 T4R Limited - stock
2015 TEP w/KDSS - stock
06-03-2016, 09:30 AM
Real Name: Josh
Real Name: Josh
How's that fit with the stock battery mount?
1999 Toyota 4Runner SR5 - Icon CDCV 2.5's, SCS Matte Black SR8 wheels, Audio overhaul (Alpine CDE-HD149BT, Kicker CS65s up front and CS5s in back
My build thread: http://www.toyota-4runner.org/3rd-ge...ack-pearl.html
2015 Toyota 4Runner Trail Premium traded for 2015 Ford F-250 Super Duty
Originally Posted by StreetCreeper
And you also tell him that right before Absalom smokes them on the trail—he skins them first and fashions their dirty lifeless hides into camp-hats to keep warm at nite...
06-03-2016, 10:33 AM
Dual Odessey Extremes.
(EDITED TO PROVIDE MORE DETAIL) The batteries are Odyssey Deep Cycle Battery Group 34... ODY34/78-PC1500DT. They are connected a Blue Sea Automatic Charging Relay, which isolates the batteries when they are drained to a certain level, making sure that you always have enough juice to start the rig with the starting battery if you are using the batteries for a refrigerator, lighting or other needs. The system is monitored with a Victory Dual Battery Monitor, which gives me all the information I need about the status of both batteries. The batteries sit on a custom fabricated dual battery tray made by Mule Expedition Outfitters. The radiator overflow bottle needed to be moved to the other side of the bay in order to fit these in.
06-03-2016, 10:43 AM
Real Name: Alex
Real Name: Alex
I run the Costco/Kirkland battery in whatever the stock size is. It works well, but my winch kicks it's ass even when I am holding the throttle at 2k RPM or so while pulling.
I've have it for 4 years now, I believe. It died on me once after running the stereo for about 30 minutes and I planned to replace it, but with a few days on the Noco charger it seems to be good as new.
2006 Lexus GX 470 Sport- RR Diff Lock, Metal Tech Sliders, RCI Aluminum Skids, Front Runner Slimline II Rack, SCS F5s, 255/80R17 ST Maxx , OME BP-51s, Dirt King UCAs, Metal Tech RR Lower Links
2016 Lexus IS300 F Sport- F-Sport Air Filter RR Racing tuner
06-03-2016, 10:46 AM
I have a conventional 27F battery right now, but about to switch to a group 31 deep cycle or AGM so I can run my fridge longer and not worry about it.
I will have to find some post adaptors and maybe extend the positive and negative sides to work since a group 31 with F or reversed terminals isn't available.
-2005 4Runner Limited V8 AWD - Toytec Boss Suspension, SPC UCAs, 285/70/17 Level 8 MK Wheels (17x8, -10), Tandem Rock Sliders
-1998 LX470 (Stock)
www.KeenanOffroadFab.com
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
