Old 08-07-2019, 12:21 PM #1
Zscarlson1 Zscarlson1 is offline
Real Name: Zach Carlson
Zscarlson1 is on a distinguished road
Replace Suspension
I’m riding on all stock suspension after 265k miles but my budget is low. I don’t want the whole “save for this” and whatever. I am trying to get front and rear done, mainly the rear, in my 99 Limited at stock height but don’t want to buy crap parts or buy a bunch of money. Any recommendations? I don’t crawl, this is only a daily driver for a few more years. I don’t have a specific budget but trying to keep it low.
Zscarlson1 is offline   Reply With QuoteReply With Quote
Old 08-07-2019, 12:26 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Cheapest route I've looked into is Bilstein 4600's on all 4 corners and moog springs front and rear.
Old 08-07-2019, 12:30 PM #3
iruninca's Avatar
iruninca iruninca is offline
iruninca is on a distinguished road
iruninca's Avatar
I'm in the same boat, and I think I'm looking at Bilstein 4600 or 5100 shocks and the OEM 99 Highlander springs. I think those springs are the best bang for your buck, you'll get OEM ride quality and an inch of lift as an added bonus. This thread has a ton of good info that has been helping me a lot: 3rd Gen 4Runner Lift Information and FAQ's
iruninca is offline   Reply With QuoteReply With Quote
Old 08-07-2019, 12:31 PM #4
If your budget is low and doing it yourself and can afford some extra down time... KYBs. Only buy the shocks, then replace whatever else you find in poor shape once you do disassembly. If your budget is a bit higher, you may want to replace other things preventatively (say, if you live in a rusty area).
Also consider new OEM lower ball joints - they are a safety issue at this age/mileage.
edit: No need for new springs unless your rear has sagged a bunch.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-07-2019, 12:34 PM #5
I’ve done LBJs within the past 2 years. I have been eyeing the moog springs for the rear (I know not the best) and then some sensen shocks as well. Any thoughts or other recommendations? OEM shocks are a tad more than I care to spend.
Old 08-07-2019, 12:37 PM #6
Avoid anything 'below' KYB for shocks. (Monroe, Gabriel, etc.) The extra $10 per corner will be very much worth it. Save $$$ by keeping the original springs. If the ride height is ok, the springs are still fine.
Old 08-07-2019, 12:42 PM #7
jkoni426 jkoni426 is offline
Real Name: Joe
jkoni426 is on a distinguished road
Real Name: Joe
KYB Gas-a-Justs give a stock ride and are cheap. I've been happy with mine and it looks like they're running a rebate/promotion on rockauto right now.
'99 T4R SR5 V6 4WD Imperial Jade Mica | 199mm TBU
jkoni426 is offline   Reply With QuoteReply With Quote
Old 08-07-2019, 12:43 PM #8
It’s sagging, the main reason I am replacing it all.
Old 08-07-2019, 12:46 PM #9
They aren’t air shocks right? Just regular ones? And with what springs.
Old 08-07-2019, 01:01 PM #10
Huskie's Avatar
Huskie Huskie is offline
Huskie is on a distinguished road
Huskie's Avatar
Upgraded my 2002 sr5 (Brutus) suspension last year on an ultra low budget with the goal of increasing clearance in order to be able to navigate some gnarlier forest roads /tracks
I found a guy parting out an old Landcruiser (I forget what year but there's threads on here with compatible model years and paint codes) and bought the front springs off of him to use as my rear springs, provided me with 5-7 inches of lift in the rear which was ideal for me as I wanted my rig to sit level when fully loaded (bedbox/ camping gear in the back) Cost me $30 for the pair.
Went with new Tockiko Landcruiser shocks to pair those with in order to maintain the full travel of the landcruiser springs (love that part about this setup) Bought I believe from AMAYAMA.com or camelback toyota (good parts resources right here) set me back < $100 and change for the pair If I remember correctly
Found a local guy selling OME 881 springs for the front on craigslist, Picked those up for $40
Paired with 2 New Bilstein adjustable 4600's in the front for roughtly 2.5" - 3" of lift. These were the most expensive component in my setup.
Misc components included a cheap ~$20 1" diff drop kit off of Ebay to keep my front CV's happy and additional brake lines for the rear to accomodate the additional couple of inches of travel with the new suspension.
You dont HAVE to do the below but I did.
I took this opportunity to redo all my front bushings(LCA, steering rack, sway bar) and replaced with poly bushings (energy suspension) , replaced Lower ball joints and tie rod ends/steering rod ends + a general derusting/repaint. I had Brutus up on jack stands for a good 20 days to do all this I must admit as I was learning as I went along. I have a massive rake when I'm unloaded but I was never one to care about looks. Handling didn't deteriorate too much, fuel consumption went up by about 1-2 MPG but small price to pay for the additional versatility. Can now navigate the rockier tracks I needed to to go flyfishing/camping at the tougher spots.
Huskie is offline   Reply With QuoteReply With Quote
Old 08-07-2019, 01:09 PM #11
Yeah you had some good luck. I wish I was that lucky but I am not. I also just don’t need to lift it, which is why I’m not this route. I love the way they look but I’d want to get new wheels and tires which I shouldn’t afford. That’s awesome though!
Old 08-07-2019, 01:23 PM #12
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
Exactly what Charlie says, nothing below KYB’s in terms of quality.
I just finished installing KYB struts up front ($56 each) and KYB shocks in the rear ($34 each). I also had some rear sag as well as a broken front coil spring so I replaced all 4 corners with Toyota factory springs (Rears $86 a piece & fronts $145 a pop).
I chose to replace the upper strut mounts in front (KYB $27 each) just to make the install a bit easier.
Total parts cost not including the strut mounts just under $650.
Did the install myself so no labor.
Truck rides great now, major improvement as original setup had 180K miles.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 08-07-2019, 01:42 PM #13
I just ordered the rear KYBs. I can’t afford to do the fronts yet and then some MOOG springs that I may return but free shipping so may be able to not use them even though my springs are factory ones still.
Old 08-07-2019, 01:53 PM #14
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
For stock height, your choice of shocks people have recommended above, and rear springs could be either cheap Moogs or a 1.5” Daystar spacer (under $50 shipped) to keep factory rake and give the frame bump stops some room to prevent bottoming out. Front coils could do Moogs if in the budget or if not leave them be, as long as they don’t have major rust or sag issues they should get you by until you’re ready to upgrade down the road.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 08-07-2019, 02:08 PM #15
For use as a dedicated DD I’m real happy with the KYB’s.
Was going to go with a Bilsteins but figured I would put the extra $$$ saved towards the springs.
2002 SR5 Sport 4WD
buy , don’t , low , rear , suspension
What do I need to replace stock suspension? xwhenximxgonex 4th Gen T4Rs 2 07-30-2017 10:43 AM
Going to replace some suspension parts mplsdunk 3rd gen T4Rs 5 03-13-2015 11:44 PM
suspension: when to replace? Jeremy03Sport 4th Gen T4Rs 7 04-05-2014 02:58 PM
New suspension coming soon! Anything else i should replace? sierra_summits 3rd gen T4Rs 6 11-20-2012 01:14 AM
Need to Replace/Upgrade Suspension Arctic 4x4 Classic T4Rs 4 07-28-2008 02:42 PM
