Old 01-18-2024, 07:32 PM #1
aa010175's Avatar
aa010175 aa010175 is offline
Real Name: Dave
aa010175 is on a distinguished road
aa010175's Avatar
Real Name: Dave
P0300, P0301 and P0306 with relay cycling. Fuel pump fail possibility.
Help needed please. Last year I did a head job at 250,000 miles. Replaced almost all parts that should be renewed. The other day I started up the car and I heard a relay cycling back forth under the dash or hood. I started the car and it would barely run because it was missing so bad. Tripped a p0300, p0301 and a p0306. I now have a thumping sound come from the left rear when the power is turned on. I have never heard that before. The tank is 1/2 full. Could it be a fuel pump starting to stumble? It has very little power going up a hill. I also pulled the EFI and 20A EFI fuse and the thumping did not stop.
aa010175 is offline   Reply With QuoteReply With Quote
Old 01-19-2024, 03:52 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
What year is your 4Runner?
How many miles do you have now?
What other work have you done on it recently?
Old 01-20-2024, 12:24 AM #3
aa010175's Avatar
Real Name: Dave
aa010175's Avatar
Real Name: Dave
It’s a 2000 V-6. Update on my problem. The thumping was the rear wiper motor running. I Reset the check engine light. This time only P0301 tripped. Pulled the number 1 plug and found it to be badly beat up. No compression in number one plug. I’m in the process of pull the head that was rebuilt 12 months ago. I think one valve failed.
Old 01-20-2024, 10:02 AM #4
We’re you driving it with the check engine light flashing?
Old 01-20-2024, 10:54 AM #5
98&me 98&me is offline
98&me is on a distinguished road
I think u are on the right track. I don’t like the sound of the spark plug being messed up. That may entail a piston, spark plug and valve replacement. Hopefully just a spark plug and valve. I am interested in what you find in cylinder 6 if anything.
98&me is offline   Reply With QuoteReply With Quote
car , heard , p0301 , power , started
New Codes: P0300 and P0301 DWilliam 3rd gen T4Rs 7 02-19-2024 08:55 AM
P0301 Misfire - Fuel Pump on the Way Out? beefsix 3rd gen T4Rs 33 01-28-2020 03:13 PM
P0300 P0306 Misfire fixed - fuel injector '99 4Runner Leebo 3rd gen T4Rs 41 07-14-2019 11:48 AM
Help! P0300, p0301, p0302 Chandler_Ross 3rd gen T4Rs 2 06-04-2013 11:22 PM
