Old 08-09-2019, 08:18 PM #1
4runnerChippy 4runnerChippy is offline
4runnerChippy is on a distinguished road
P0171 code
So when I bought my 99 4runner it had a leaky fuel injector so I replaced the oring. Leak stopped but I’ve been having high idle issues since. The erratic idle stopped but I get a high idle 12-1300 until it’s warms up. It’s running rich, I can tell by smell, and now has the P0171 code. I’ve replaced fuel filter, checked for vacuum leaks, cleaned MAF. I’m about to tear it back down and check that injector and replace all vacuum hoses and gaskets. I bought a scanner and the results of the freeze frame when code triggered are
Load: 13.7%
Coolant temp: 187
Short term fuel: -1.6%
Long term fuel: 37.5%
4runnerChippy is offline   Reply With QuoteReply With Quote
Old 08-10-2019, 09:46 AM #2
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
The high idle at cold start up is normal. Usually when you have a system lean code combined with high fuel trims, rich smelling exhaust, chugging, bad fuel mileage, etc it is a false lean issue causing the ECM to compensate for a non-existent lean condition. Check your O2 sensors
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 08-10-2019, 04:01 PM #3
Should I swap 02 sensors?
Old 08-10-2019, 07:23 PM #4
Js'00imited4runner's Avatar
Js'00imited4runner Js'00imited4runner is offline
Js'00imited4runner will become famous soon enough
I battled a mystery check engine light on and off for 2 years then when it shined its ugly head again I got it scanned and turned out it was the downstream O2 sensor. I cleaned the MAF sensor 3 times over a 2 year period, took all the plumbing apart up to the throttle body and cleaned it all out. Now that I replaced it my high idle is gone during start up, and my check engine light hasn't come on since. (knock on wood!). It was also the p0171 code. If it does end up being a bad O2 sensor get the denso OEM number and order it from ebay/rockauto. I paid $50 shipped no tax, and parts stores wanted $100 for the same part.
denso is the OEM manufacturer for toyota sensors/some electronics. Hope you get it figured out.
2000 Limited 4wd Millenium Silver Metallic, E rear locker, KYB Monomax All around, '99 tall coils up front with daystar 1" spacer, OME 890's in back, Weathertech Floor and cargo Mats, Track decal shackle Brackets, Satoshi grill mod (wahoo), Diff breather mod, 200k+ and still going strong!
Js'00imited4runner is offline   Reply With QuoteReply With Quote
Old 08-10-2019, 08:28 PM #5
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
So, just throwing this out there, I had the 171, and replaced a LOT of shit.
Turned out to be a partially clogged injector.
I bought an injector tester and ultrasonic cleaner off amazon, and haven’t had the code back in 2 years.
YMMV.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
code , fuel , idle , p0171 , replaced
P0171 code Bt08231 3rd gen T4Rs 42 06-20-2022 07:19 AM
P0171 Code Brilliant 3rd gen T4Rs 15 08-25-2015 02:15 AM
Code P0171 , need help..... jhueter 3rd gen T4Rs 2 03-11-2013 02:51 PM
Code p0171 BaseRunner 3rd gen T4Rs 6 07-25-2012 02:55 PM
P0171 OBD II code 4RunSTL Problems & Warranty Issues 1 04-18-2008 08:13 PM
