08-06-2010, 07:25 PM
Changing shift solenoids
I have a 96 runner that has a PO753 code for the shift solenoids. I'm going to attempt to do this myself. I bought both shift solenoids just to be covered. From what I understand, you drain the fluid, drop the pan, and the solenoids are exposed. Are there any tricks? Any special tools?
Any advice would be appreciated.
Thanks!
08-09-2010, 06:13 PM
No one else has done this? Now I'm scared. lol
08-09-2010, 06:24 PM
my brother did this job for me but I decided to change all 3 of the solenoids, 2 where bad and didn't know which ones so i figured I'll just change them all so I know there all new. It cost about $700+ in parts, $0 in labor with that said it took my bro about 30min-1hr was relatively easy for him.
[1997 Toyota 4runner SR5 4x2 3.4L V6 @ 176,000k miles]
5000k HID's DDM kit. FOG lights. Reverse light mod.
2.5" Spacer front 890 rear coils. 31" BFG A/T KO's Airaid Drop in filter Deckplate mod
NEW [2010 Toyota Tacoma Double Cab Prerunner TRD Sport fully loaded 2WD]
08-09-2010, 06:31 PM
I bought 2 of them. I should have them by this weekend. We'll see. I'm thinking it is pretty easy too. I don't know.
08-17-2010, 02:59 PM
Well, I did it last night. Took me 2 hrs total. Everything seems to be fine so far! The worst part was messing with that stupid gasket goop.
08-17-2010, 04:54 PM
I saw this thread too late, but I was going to say the solenoids are cake, it's the pan gasket that sucks, haha. But you already figured that out!
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
05-16-2011, 01:27 PM
what is the best way to get pan off?
Hi there,
1) I did not see the beginning of the thread, but what were the symptoms, that you decided you change the solenoids?
2) What is the best way to take the pan off, w/o damaging it?
Regards,
Seb
04-21-2016, 04:51 PM
Real Name: Andre
Real Name: Andre
'96 shift solenoids
I did this this morning and it seems to have made my problems worse. Now no OD at all, before it would occasionally refuse to go into OD or shift down while in OD.
04-21-2016, 09:20 PM
Real Name: Woody
Real Name: Woody
Are you sure you put the right solenoids in the right places? Shift solenoid and lock-up solenoid are different.
"Variety is for your mind, not your body " —OS
04-22-2016, 07:29 AM
Real Name: Andre
Real Name: Andre
Shift solenoids
Not 100% sure...The brackets on the #1 & 2 shift solenoids are different than the lock-up solenoid. You can't install one for the other. I read that the shift solenoids are the same, interchangeable. Does anyone know if that's not true?
04-22-2016, 09:24 AM
I had the same code. My solenoids will be in today. My original problem was it not downshifting into 1st gear automatically. Was having to manually shift to L and then 2-D. Went into O/D fine.
What did you use to get the black rtv off?
04-22-2016, 12:54 PM
WoW 700.00 bucks
I found a kit on E-Bay, three shift solenoid's,filter and pan gasket, 168.00 shipped. I did my 01 in March no problem's.
04-22-2016, 01:19 PM
Real Name: Woody
Real Name: Woody
Shift solenoids on mine were interchangeable.
04-22-2016, 01:26 PM
Real Name: Woody
Real Name: Woody
Scrape it. I used a metal and plastic drywall putty scraper along with some weird metal brush "thingy" I found. The metal brush worked well for me especially with getting all the nooks & crannies. I also used the blade of my Swiss Army knife to dig out the gasket around the bolt holes.
I took the time to clean it thoroughly.
04-22-2016, 03:24 PM
Wow that makes me feel better after stumbling into this thread, not that I have any issues, I am just interested in keeping my 4runner like a tank.
Someone above said it cost them $700 in parts.
