Old 08-10-2019, 12:05 PM #1
4rFrog's Avatar
4rFrog 4rFrog is offline
Real Name: Totyota
4rFrog is on a distinguished road
4rFrog's Avatar
Real Name: Totyota
Power windows working intermittently, need help
My drivers and passenger power windows work most of the time, but sometimes they go dead. Then in a minute or two, boom! They are working again, I pulled the drivers side master witch regulator and checked that the plugs were all tight and they were.
Has anyone experienced this or have any solutions?
2002 limited 4runner, Supercharged/7th injector/2.2 Pulley, Level 10 bulletproof transmission, 3" lift with 2.5 Fox Coilovers up front, Fox 2.0 reservoirs in the back, Toytec 3" springs in the back, Rokman lower links, Frontrange upper links, 285/75R16 Wildpeak ATW3's, SRQ Retrofits, Flowmaster 50 series SUV, New leather seats and steering wheel wrap, 4xinnovations bumper up front.
4rFrog is offline   Reply With QuoteReply With Quote
Old 08-10-2019, 04:57 PM #2
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
I've had this happen on my Hyundai, Sentra and T4R!
I don't know how to explain it best but I'll try (First make sure all connections are snug):
I removed the main cluster of switches (driver door) and carefully dissembled the culprit switch: it's a "rocker" on the inside that wears out or the grease/dirt combo gunks up the works.
I've successfully cleaned and re-lubed those switches on all 3 vehicles.
BUT: the Hyundai got so bad I bought a new cluster with new switches just because I didn't want to deal with it.
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 08-14-2019, 11:01 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I would say that it is one of 2 things:
1) The buttons are extremely warn and no longer making contact.
if the case is black underneath possible cause.
2) You have broken wires in the drivers doors and they are making intermittently.
This is my issue in my 91 Camry. I pulled the harness out of the connector in the side pillar and tested the wires with an ohm meter. They always break in the rubber boot between the door and the pillar and you can splice the bad section out with another wire.
When I replaced the rusted doors I replaced the wire harness with one with good wires.
Old 09-04-2019, 02:00 AM #4
4rFrog's Avatar
Real Name: Totyota
4rFrog's Avatar
Real Name: Totyota
Thanks for the reply guys!
drivers , power , pulled , windows , working
All Power Windows not working - 2014 decker1 5th gen T4Rs 14 08-22-2021 02:45 PM
Power windows stopped working achha64 3rd gen T4Rs 5 12-09-2014 10:42 AM
1st gen power windows not working? thatoneguy Classic T4Rs 5 08-19-2014 08:47 PM
Power windows aren't working. Help? KYMUDD 3rd gen T4Rs 4 11-19-2013 11:46 AM
AC and power windows stopped working MikeBuzzsaw 5th gen T4Rs 10 07-08-2012 09:19 PM
