Old 08-10-2019, 12:22 PM #1
bdjcl bdjcl is offline
bdjcl is on a distinguished road
'98 Limited, replace seat with manual seat and wire for power?
I have a '98 Limited and the 2 front seats leather are absolutely shot. I think my best option is going to be to find 2 front seats from a junkyard, either cloth or leather, don't really care.
I've found a local junkyard with nice looking cloth seats that are manual. Can I buy those manual seats and simply bolt in my current power seat motor fairly easily? My motors work fine, just the leather is ripped beyond repair.
bdjcl is offline   Reply With QuoteReply With Quote
Old 08-10-2019, 12:37 PM #2
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
How much do they want for the seats? I'm pretty sure, by looking at some parts breakdowns, that what your asking cannot be done without some major modification. Would be easier to take the cloth off the frames and transfer them I think. At that point I would just go on eBay and get a leather or vinyl reupholster kit. That's why I ask how much the seats are. If they are more than $200 then the new covers would be a better solution.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
Old 08-10-2019, 12:54 PM #3
The seat is $50. I guess the major modifications underneath the seat would be the wiring. I assume there's also some physical alterations that differ between manual and electric seats with the tracks, etc.
Old 08-10-2019, 02:07 PM #4
Real Name: John
Real Name: John
Here's a Link to the cloth sport seat track. If you then goto to "VZN185L-GKPGKA" up top and change the characteristic to "LULI" (limited) I think you'll see some major mechanical differences. Wiring would be easier to adapt if that were the only difference.
Old 08-10-2019, 07:30 PM #5
Js'00imited4runner's Avatar
Js'00imited4runner Js'00imited4runner is offline
Js'00imited4runner will become famous soon enough
I swapped my leather seats out with sr5 cloth seats front/rear and ran them for 3 years without plugging them in..I would assume the airbags would still go off even with them unplugged? Only thing I think it controls is the electronic lumbar support/seat belt notification. You could always just swap the plugs from either seat I would assume? I finally found a decent set of leather seats last weekend and swapped back to leather. Personally the manual seats weren't terrible for the time I had them. They were definitely a upgrade from what I bought it with. eBay has the leather replacement pieces for $90 for vinyl or $110 for Leather (bottoms). Depends on the shape your foam is in.
2000 Limited 4wd Millenium Silver Metallic, E rear locker, KYB Monomax All around, '99 tall coils up front with daystar 1" spacer, OME 890's in back, Weathertech Floor and cargo Mats, Track decal shackle Brackets, Satoshi grill mod (wahoo), Diff breather mod, 200k+ and still going strong!
Js'00imited4runner is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 08:06 AM #6
Drew76 Drew76 is offline
Drew76 is on a distinguished road
You can make a hybrid setup by swapping the manual cloth seat cushions onto your power seat frame, and then swap the cloth seat backs/frame as one onto the power seat cushion. I currently have 96-98 cloth seats in my 2000 Limited, the power lumbar in the driver backrest is no longer there (manual lever now) and I may not have something else plugged in on the passenger side but the powered slide and tilt work as normal.
Andrew
Drew76 is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 12:44 PM #7
olhobbler olhobbler is offline
olhobbler is on a distinguished road
why bother with electric, you probably will set it and forget it. I am sorta in the same boat, most leather seats I find in the junkyard are bad.
olhobbler is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 05:06 PM #8
BrianK14 BrianK14 is offline
BrianK14 is on a distinguished road
I would recommend (it’s what I did) finding a passenger seat bottom foam in good shape from the salvage yard to replace your trashed drivers side. Then order the replacement Vinyl/leather seat bottom cover from EBay sellers. That way you retain the leather, and your power seats, no problems.
BrianK14 is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 08:09 PM #9
that's a pretty good idea
Old 08-11-2019, 11:04 PM #10
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
I did this on an old Ford Explorer. I prefer manual adjust seats. They last forever. Electric seats will fail.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
leather , limited , manual , seat , seats
Wiring diagram for 2000 power seat - manual to power seat conversion calnhob 3rd gen T4Rs 3 04-30-2018 01:03 PM
WTB: Drivers seat plastic trim for manual adjustment seat. RPTFE00 For Sale: T4R Items 0 08-19-2015 10:41 PM
manual to power passenger seat swap? RESQLAB 5th gen T4Rs 2 04-22-2015 02:15 PM
Extra Seat Movment??? Power and manual Sad4RunnerOwner 4th Gen T4Rs 0 11-13-2003 05:33 PM
