Old 08-10-2019, 12:43 PM #1
TheShowtime TheShowtime is offline
TheShowtime is on a distinguished road
Antenna question
Hey guys I just bought a new to me 01 4Runner Sport, it has an after market head unit and the antenna only goes down when I take the keys out of the ignition. I don’t want my antenna to get messed up going thru an automatic car wash. So my question is do I have to put the transmission and the transfer case In neutral with the keys out to go thru the car wash safely so my antenna doesn’t get messed up? And is it ok to take the key out the ignition with those settings? Thanks guys
TheShowtime is offline   Reply With QuoteReply With Quote
Old 08-10-2019, 01:19 PM #2
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
What I did is I ordered a switch off off amazon pulled the radio head out there is a wire for power antenna just put the switch inline and mount it where u like. I put mine in the little pocket at the back under the cigarette lighter. The color of the wire maybe marked with a tag on the wiring harness the 3 that i have done were.
plcfcng is offline   Reply With QuoteReply With Quote
Old 08-10-2019, 01:33 PM #3
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
If it is an automatic you won't be able to take the key out unless it is in park, but you can put a 5 spd or the transfer case in neutral with the key out
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 08-10-2019, 02:05 PM #4
Yeah it’s an automatic, so do you guys think my antenna will be fine going thru the car wash while it’s up?
Old 08-10-2019, 05:47 PM #5
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
With the key on, try turning the head unit off and see if the antenna drops. I've never seen one that keeps it's up when powered off. Usually on aftermarket radios, you have to hold the button down for a few seconds until it turns off completely.
With that said, I did the switch thing mentioned above and it was very simple.
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 08-10-2019, 06:18 PM #6
Ghostrider Ghostrider is offline
Ghostrider will become famous soon enough
I had a unit that kept it up all the time. It was ten years ago and made the unit just did not have an antenna powered wire at all. I guess I could have cycled it down with some extra work but I didn;t like to unit so I swapped it out after a year or so.
Ghostrider is offline   Reply With QuoteReply With Quote
Old 08-10-2019, 06:44 PM #7
Ron Helmuth's Avatar
Ron Helmuth Ron Helmuth is offline
Real Name: Uhhh this is my real name
Ron Helmuth is on a distinguished road
don't do it
Don't go through one of those car washes with the slapping straps of fabric-or it will snap the mast.
As Twisted Sid advises-turn the head unit off to have the antenna retract.
06 4th gen V8 4WD of course...
08 Honda Ridgeline RT
05 Scion xB-the toaster-daily driver
my Yota Fanatic photos are on Facebook- here is link:
http://www.facebook.com/album.php?ai...5&l=5795132731
Ron Helmuth is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 06:36 PM #8
plcfcng's Avatar
Real Name: michael
plcfcng's Avatar
Real Name: michael
The other reason to put the switch in is I hate hearing the motor cycle each time i turn the key on. I am listening to Pandora most of the time anyway.
Old 08-12-2019, 10:11 AM #9
toyotaspeed90 toyotaspeed90 is offline
toyotaspeed90 is on a distinguished road
Whether the antenna goes down when powered off, or even by switching sources, will depend on the radio and how it was wired.
Aftermarket stereos have a 12v switched power for the antenna and amplifier. Sometimes these are separate (but not wired as such).
It's too bad that Toyota didn't put the up/down switch (also making it variable height) from the Landcruiser into the T4R. It's an odd switch that's quite useful at times.
I also would suggest... don't take it through car washes.
toyotaspeed90 is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 10:15 PM #10
Ok guys thanks for all the input! Probably going to just get a new head unit because the one that came with the 4Runner is old.
Old 08-13-2019, 06:52 PM #11
plcfcng's Avatar
Real Name: michael
plcfcng's Avatar
Real Name: michael
I really like Crutchfield: Car Stereo, Speakers, Home Theater, Pro Audio, 4k TV prices are excellent support is even better.
antenna , car , keys , messed , question
Replacing head unit: 3 antenna input question & power antenna replacement question Rancho5 3rd gen T4Rs 14 08-24-2018 06:51 PM
Antenna question CVELD77 3rd gen T4Rs 3 07-13-2016 01:22 PM
another antenna question again ! 3bears 3rd gen T4Rs 8 06-07-2015 09:13 PM
4th Gen Antenna Question Grreatdog Engines / Suspension / Wheels / Tires / Audio / Accessories 3 02-06-2013 11:04 AM
antenna question nyvram 3rd gen T4Rs 10 01-16-2013 11:37 AM
