Old 09-10-2019, 08:02 PM #61
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
FYI; here's the thread about programming the MX. I contacted UG to cancel my original order so I can get the MX.
Ultragauge 1.3 MX Question - Trans Temp??
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 09-10-2019, 08:33 PM #62
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
I was just about to suggest that, good move! The MX makes way more sense for the '99+, an extra $10 for trans temps is well worth it!
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 09-11-2019, 09:04 AM #63
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
What year?
2000 Limited. I have it programmed to see trans temp. I think the thread link is posted earlier in this thread. I ordered mine with the Toyota Tacoma/Tundra CAN pre-programming. I would get the MX 1.4 if I were you. No reason not to in my opinion.
Old 09-11-2019, 10:12 AM #64
BoomerBob's Avatar
BoomerBob's Avatar
Great! I ordered the right one then for my 01. Well; the 1.3 but it should do.
When my engine got trashed due to overheating from a blown off radiator hose; I had no warning other than the temp gauge most of us only look at once in a while unless maybe pulling a long hill or something. At least this way I'll have some kind of warning which brings me to another question about the UG.
Are the over temp warnings only a visual red flashing set of numbers on the UG or is there some kind of sound or both.
One reason I really like the idea of this new mount putting it right in my usual line of sight is that I will see it if it is a red flashing set of numbers only. If it makes a warning sound then that's icing on the cake. Either way I will get enough warning to pull over and shut the rig down before blowing another engine and spending over $4k.
Old 09-11-2019, 10:23 AM #65
Real Name: Leon
Real Name: Leon
UG does have alarms. When a preset alarm goes off, it makes a loud beeping noise. In addition, the screen starts flashing showing you what parameter has been exceeded. I've initially had my coolant alarm set to 215F, which was low enough to set off after a short stop at a rest area. Also the preset RPM alarm of ~4500 went off when I was passing someone. In both cases there was no mistaking the alarms or the source. So it's 99% foolproof.
Old 09-11-2019, 01:50 PM #66
BoomerBob's Avatar
BoomerBob's Avatar
Fantastic!!
Old 09-11-2019, 02:44 PM #67
PatrickStapler PatrickStapler is offline
PatrickStapler is on a distinguished road
1999+
So the UG MX 1.4 programmed for Tacoma will work in a '99 4Runner? Is that what I'm reading here?
Kind Regards,
Patrick
PatrickStapler is offline   Reply With QuoteReply With Quote
Old 09-11-2019, 02:59 PM #68
BoomerBob's Avatar
BoomerBob's Avatar
Yes; 99 to 02.
Old 09-11-2019, 03:49 PM #69
Real Name: Patrick
Real Name: Patrick
It will work on 96 and newer 4Runner. Transmission temps will display on 99 and newer.
Old 09-11-2019, 05:26 PM #70
Cool. Thanks guys. About to order one. Wish I knew of this sooner.
Kind Regards,
Patrick
Old 09-11-2019, 06:40 PM #71
BoomerBob's Avatar
BoomerBob's Avatar
Thanks for that clarification. I think they even say on their website somewhere that the newer the car (starting with ODBII in 96) the more sensors it can read.
Seems like good cheap insurance to me.
Old 09-11-2019, 07:08 PM #72
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about
2TH4IST's Avatar
Just received the scangauge mount today. Perfect fit and finish. Will post pics up in a few after work. Puts it perfectly in view and clears up my cluster.
Also just a FYI, if you destroy the screw removing it, they are the same screws as the rest of the grab handles. So grab a few extra if you go to the junk yard.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 09-11-2019, 07:38 PM #73
2TH4IST's Avatar
2TH4IST's Avatar
here is three pic.
Ultragauge, Scangauge, and 2-1/16" Gauge Mounts-20190911_163422_compress33-jpg
Old 09-12-2019, 12:42 PM #74
Real Name: Leon
Real Name: Leon
In addition to the cheap insurance, my favorite part of these gauges is the "gallons remaining". Once you calibrate the gauge after a fillup, it'll nail how many gallons you have left down to about 0.1 gal, a huge improvement over our fuel gauges that seem to fluctuate by 1/4 tank every few minutes .
Old 09-12-2019, 04:04 PM #75
Real Name: Leon
Real Name: Leon
Good to hear! And yes indeed, kudos to my fab, the only place I trust - I told them that tolerances weren't critical on this job, but he said they'll maintain their standard 0.005" tolerances regardless - gotta love that old school approach!
custom , gen , mounts , production , ultragauge
Let's see the phone mounts Mbiker_101 4th Gen T4Rs 77 03-28-2020 05:48 PM
Custom 3rd Gen Phone Mounts (Clock Location) $20-$40 Itisntevan For Sale: T4R Items 0 02-20-2018 08:32 PM
ScanGauge, TurboGauge or UltraGauge on '04? stevec5000 4th Gen T4Rs 7 01-12-2014 04:00 PM
Scangauge alternative - Ultragauge. Anybody got one on a T4R? Martinjmpr General Discussions 7 10-01-2010 01:56 PM
Cell Phone Mounts midnight runner 4th Gen T4Rs 7 07-12-2009 05:18 PM
