Originally Posted by Bad Luck
2000 Limited. I have it programmed to see trans temp. I think the thread link is posted earlier in this thread. I ordered mine with the Toyota Tacoma/Tundra CAN pre-programming. I would get the MX 1.4 if I were you. No reason not to in my opinion.
Great! I ordered the right one then for my 01. Well; the 1.3 but it should do.
When my engine got trashed due to overheating from a blown off radiator hose; I had no warning other than the temp gauge most of us only look at once in a while unless maybe pulling a long hill or something. At least this way I'll have some kind of warning which brings me to another question about the UG.
Are the over temp warnings only a visual red flashing set of numbers on the UG or is there some kind of sound or both.
One reason I really like the idea of this new mount putting it right in my usual line of sight is that I will see it if it is a red flashing set of numbers only. If it makes a warning sound then that's icing on the cake. Either way I will get enough warning to pull over and shut the rig down before blowing another engine and spending over $4k.
