08-11-2019, 12:25 PM
Real Name: Leon
Real Name: Leon
Ultragauge, Scangauge, and 2-1/16" Gauge Mounts
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
08-12-2019, 02:08 PM
Show some scangauge mount pictures please.
08-12-2019, 08:18 PM
Real Name: roGer
Real Name: roGer
looks super slick man! unfortunately i've found it impossible to remove that damn screw on the a-pillar handle bar!
2002 Toyota 4[thedog]Runner Limited BFGoodrich KO2's | Taco whip | Paranoid Fabrications switch panel | full length roof rack | Tundra brakes with SS lines | ARB Awning | ARB compressor and f/r lockers | ToyTec lift (ugh) upgraded to Kings | Total Chaos UCAs | WARN winch | 4xInnovations armors | Method Grids | KC Roof Lights | Lotus Development CV Axles | Whiteline Bushings | Spidertrax spacers | SnoMaster Fridge | ReadyLight | holy shit this adds up fast
Insta: wkendnomad | this is where the adventure begins
08-12-2019, 08:27 PM
Real Name: Leon
Real Name: Leon
That screw can be a bear to remove, no doubt. I bought a hammer impact driver set ahead of time, just in case:
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
But as it turned out, my trusty Makita cordless impact driver with a JIS bit loosened it up with no problems.
08-12-2019, 08:53 PM
Real Name: Leon
Real Name: Leon
Still haven't finalized the design, but it'll look something like this:
08-12-2019, 08:57 PM
Real Name: Leon
Real Name: Leon
08-14-2019, 08:48 AM
This looks awesome! As far as the grab handle bolt goes, I ended up having to drill off the head of one of them to allow the handle to slide over. Then I grabbed the nub of the screw that was left with vice grips and unscrewed it. Then I used 6pt bolts as a replacement.
I wonder if an iPad mini would fit there?! How would the weight be and would there be any vibration issues?
2000 Limited. Lifted....finally!
www.OverlandNV.com
08-14-2019, 09:49 AM
Real Name: James
Real Name: James
I’m interested. What do they cost?
98 Base Model 2.7L
08-14-2019, 10:33 AM
I'm very interested. Would like to get the scangauge off mt steering column. What is the price range do you think these will be in?
Edit - I'm starting to like the UG instead of the scangauge. Wonder if I should switch over?
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
08-14-2019, 11:44 AM
Real Name: Patrick
Real Name: Patrick
Join us on the darkside I've got an UltraGauge MX1.3 in my 2000. I like that it shows more data at once than a scangauge (including trans temp if available on your year) and I didn't mind the extra size.
08-14-2019, 12:21 PM
Real Name: Leon
Real Name: Leon
I'm starting out with Ultragauge and Scangauge mounts first, but I do have conceptual designs for phone mounts. But I think the iPad mini would be too large, rather than too heavy.
One thing I am considering is making similar mounts for the passenger side, where there is more room and no steering wheel and instrument cluster. Perhaps that can be used for the ipad min?
The UG mount is currently priced at $29.50. The SG mount will be a $10 more because it'll require an additional piece to be made (I decided to make it two piece, rather than one piece).
Yeah, I'm not a fan of the common steering column mounting - it blocks some of the warning lights. This will be way sturdier, and it won't block any of your view.
Same here, but of course it's a personal choice. The one thing I hate about the UG is the buttons on the back. But I'm working on a design to make it "touchscreen", where you mount it with velcro against a flat plate, and push on the corners to actuate the three buttons (this is not my idea, it's all over Youtube).
08-14-2019, 12:37 PM
Real Name: Leon
Real Name: Leon
One thing I want to emphasize - I am a nut for keeping my eyes on the road, not having anything block my view, and having things be sturdy.
Most of the other mounts I've seen fail in one or all of these criteria. Suction cups (ahem) suck; steering column mounts block some warning lights and require you to look down; radio-area mounts really make you take your eyes off the road. And the recent idea I saw here of mounting the SG up in an FMU console overhead is neat, but requires you to modify the SG, and does not work with UG. And for those of us with aging eyes, refocusing from the road to the overhead console is less than ideal.
My mounts are designed to be located precisely where you can always see them without taking your eyes off the road; they will not block anything unless you want to admire your a-pillar ; and they are within easy reach with your hands still on the wheel.
08-14-2019, 12:44 PM
Have you given any thoughts for offering a mount for this location? I made my own crude metal brackets which utilize the stock ashtray mount screws, but a more refined version would be welcomed. I don't really like my interior looking like a gaugefest, so I'm not really a fan of the grab handle mount location personally. This location has worked out well so far, and keeps the cable totally hidden behind the center console stack.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
08-14-2019, 02:49 PM
Paranoid Fabrications makes a mount for that location (and a switch panel, for those interested...).
1st Gen Tacoma Ashtray ScanGauge ll holder
– Paranoid Fabrications
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
08-14-2019, 06:05 PM
Real Name: Leon
Real Name: Leon
I had a scangauge mounted in that location initially. It's convenient from the standpoint of mounting, but I did not like it all from the standpoint of usability (for my needs).
You have to take your eyes off the road to see the gauge down there, and you have no peripheral vision of the road when you are looking down at the ashtray. So unless you're only looking at at the gauge when you're stopped, I think it's too scary. I have a trans temperature gauge mounted in that vicinity, and I find it very hard to monitor the temperature during driving, because I hate taking my eyes off the road. So I prefer to have critical gauges in my line of sight, which my mounts are designed to do.
Besides, as Charlie pointed out, someone already makes a SG mount for the ashtray location .
