Old 08-12-2019, 08:44 PM #1
thegipper's Avatar
thegipper thegipper is offline
thegipper will become famous soon enough
thegipper's Avatar
Need a muffler and tail pipe, what to buy...
When I got my 4runner a few years ago, the exhaust was shot.
I replaced everything from the cat back (Walker).
Today on my way home, my tail pipe decided to fall off. I had no other signs it was leaking or about to break.
Upon further inspection, the muffler is also starting to rot out around the seams.
I could replace the tail pipe and muffler with Walker brand parts again with the assumption I will only get 2-3 years before it rots out again.
Is there another "cheap" brand that I should try? Or should I just go the Walker route again. If anyone has any links to some good deals, that would be awesome also. Even the "Bosal" brand cat back kit is 230 bucks shipped (not cool).
My truck is getting pretty rusty and in all honesty, I think she may only have a couple years left in her. Otherwise, I wouldn't be opposed to buying a higher quality system.
Thoughts?
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 09:16 PM #2
Kanoe Kanoe is offline
Kanoe will become famous soon enough
I've been trying to figure out what to do also. Mine needs doing. The walker reviews are not great. Thanks for confirming.
I'm leaning toward finding a better tail section at a wreckers and welding a borla 40664 into the muffler section. Seems to be about the best bang for the buck. Good muffler and stock configuration still. Likely get away under 200.
Sadly, the 3rz has a smaller diameter piping so my options are more limited than yours. Not sure if going up to V6 size piping would have any affect on things.
-1996 4Runner. 3RZ 5-Spd. 4x4 Base model. OME2906 rears with 2004 Tacoma Dual Rate Fronts on Bilstien 4600s.
-1993 Corolla Wagon 7AFE
Kanoe is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 10:04 PM #3
brillo_76 is on a distinguished road
MY GARAGE
MY GARAGE
Nothing seems to last like the original OEM systems on these rides...I did a walker and it rusted off 3 to 4 years after installation well the tail pipe fail off first.
So I got a Chinese stainless steel one.
Tail pipe
Stainless Steel Direct Fit Tail pipe Exhaust Fits 1996 - 2002 Toyota 4 Runner | eBay
Muffler
Stainless Steel Exhaust Center Muffler Resonator Pipe fits: 1996-2000 4Runner | eBay
Tailpipe and Muffler Kit
Stainless Steel Exhaust System Kit fits: 1996-2000 Toyota 4Runner 3.4L | eBay
I have the tailpipe only on one of my rides, However, I am going to put the cat back on my 5 speed when I finish the frame repair. The only drawback I seen so far is the flanges are normal steel. So they will rot off in time.
Old 08-12-2019, 10:19 PM #4
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough
MY GARAGE
MaineRunna's Avatar
MY GARAGE
Bosal muffler and tail pipe will last a few years
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, RCI skid plate, SPC UCA's & rear LCA's, Tundra brakes, BFG 255/85R16 Mud Terrain T/A's 224,000 miles
MaineRunna is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 11:17 PM #5
19963.4lsr5 will become famous soon enough
Iím happy with my Napa Cat back. Alumized steel system. Itís around 6 years old now and around 15,000 miles on it.
Old 08-13-2019, 08:16 AM #6
thegipper's Avatar
thegipper's Avatar
Tail pipe
Muffler
Thanks for the link. I might as well go the SS route since its the same price on ebay as buying a regular exhaust from bosal/walker kit through rock auto.
2011 Camry SE V6
Old 08-13-2019, 11:20 AM #7
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout is on a distinguished road
Reinout's Avatar
Real Name: Reinout
If you're rusting out after a few years i don't think a 409 grade stainless will do it. While it is indeed "stainless" it has the LEAST amount of additives to allow it to be called "stainless".
I'd suggest, even if it costs a pretty penny, looking at higher grade such as 304 which has more additives to the metal to make it more resistant.
Every search unfortunately didn't turn up a 304 SS exhaust for our vehicle: fortunately I live in Washington and I'm on the original exhaust at just under 370k ☺
BUT: It would be worth it to do it right and do it right once.
1997 4Runner SR5- ~366,000 Miles and counting - 5 Speed E-Locker - Blue and Grey Wire mods - Wet Okole Covers - Wood rear deck for the dogs with LED underlighting - Yakima Custom track rack with wide bars for two Skybox 16s side by side - 1.5" Daystar rear coil spacer - Skyjacker 7022 shocks - Centric front and rear SS braided Brake lines - Stoptech(Centric) drillled front rotors
Reinout is offline   Reply With QuoteReply With Quote
Old 08-13-2019, 11:43 AM #8
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C will become famous soon enough Ed_C will become famous soon enough
Ed_C's Avatar
Real Name: Ed
Tail pipe
Muffler
That's where my Walker Quiet Flow rotted away, the flange where it bolts to the tailpipe broke off and is now part of the tailpipe assembly. I installed the muffler section 5 years ago but kept the OEM tailpipe since it was still in good shape...in fact I'll be reusing the tailpipe again, haven't decided on a muffler yet but I want it quiet like the Walker.
I just looked up exhausts on Napa and it their current systems are actually Walker Quiet Flows, same part numbers and the warranty sheet says Tenneco (Walker's parent company).
Old 08-13-2019, 12:10 PM #9
JohnMc JohnMc is offline
JohnMc is on a distinguished road
I jsut had to do a quickie fix on my '99 in the middle of a road trip (in Moab) - Walker aluminized muffler and tailpipe, both replaced about 4 years ago. The pipe and muffler were both still in pretty good shape, but they rusted out where the flanges were welded on, and burnt away the aluminizing. The tailpipe itself rusted loose from the flange first, but the muffler flange wasn't far behind. I just hacksawed off the remnants and used a slip-on repair pipe and a couple of clamps to get it back together for the rest of the trip.
I'd be tempted by the 'Stainless Steel' mufflers above, but it sounds like they really aren't any better than normal. Borla makes a spendy looking system that is made of 300 series SS (T-304) so it might actually last longer. But then it costs around 3, 4 times as much. And at 3 - 4 years lifespan for a regular one, you're talking around 10 years it would have to last, at a bare minimum. to make financial sense.
I guess there's the hassle of swapping it occasionally, but it's about as easy as exhaust work gets on a car. Don't even have to jack the car up to work on it (lol). And I do drag the exhaust on things occasionally while wheeling, it would be a shame to 'invest' $600 in a Borla system, only to crumple it up on some rocks right away.
All in all, I think I'm talking myself into another cheap-n-crappy aluminized steel exhaust.
gray wire/1" body lift/32" tires/'Snowflake' TRD Taco wheels/231mm Tundra brakes/Rola rack
JohnMc is offline   Reply With QuoteReply With Quote
Old 08-13-2019, 04:19 PM #10
AntleredRuin AntleredRuin is offline
Real Name: Daniel
AntleredRuin is on a distinguished road
Real Name: Daniel
I bought this no-name eBay special muffler a few months back. Fit fine, and has held up so far.
A bit louder than stock, though. (Initially it was REALLY loud and I was gonna return it, but I found that one of my exhaust gaskets was leaking).
Now, I've either gotten used to the noise or it's 'broken in' and quieted down. Sounds fine to me. Still noticeable at cold start up and WOT, but not annoying.
1742062240 New Muffler for 4 Runner Toyota 4Runner 1997-2000 | eBay
Another thought, LKQ (and probably other junkyards) sells mufflers for like $25. Might take some digging to find a non-rusty OEM, but that might be a great deal. OEM obviously lasts a lot longer than aftermarket replacements.
No junkyard *legally* sells catalytic converters by themselves, but they might sell an entire exhaust set altogether and turn a blind eye if you're willing to grab it in one piece. Makes no sense to me.
I can buy a used car with a used catalytic converter already included, but when that one dies, I can't get one from a lower mileage wreck due to environmental reasons.
AntleredRuin is offline   Reply With QuoteReply With Quote
Old 08-13-2019, 06:40 PM #11
Iím pretty sure this is what I have on my 97 that came off the 96 when it got totaled. There really isnít even any real rust on it yet.
There is a replacement flange to repair a rusted flange on the cat that the muffler section would bolt to. I bought one Incase I ever need it.
Old 08-13-2019, 07:07 PM #12
gamefreakgc's Avatar
gamefreakgc gamefreakgc is online now
Real Name: Jerod
gamefreakgc is a jewel in the rough gamefreakgc is a jewel in the rough gamefreakgc is a jewel in the rough
Real Name: Jerod
If you were closer, I've got a good stock cat-back exhaust in my backyard with minimal rust. The muffler's a tad bit rusty but the piping is all in great shape. Could just weld in a muffler and be good to go.
'98 4Runner SR5 - 4x4 5VZ-FE Supercharged - 222k miles, JDM engine @ 221k
AEM F/IC 6 Piggyback, 2.1" pulley at 11 PSI, Go-Fast Parts
gamefreakgc is online now   Reply With QuoteReply With Quote
Old 08-13-2019, 09:33 PM #13
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 has a spectacular aura about T4R2014 has a spectacular aura about T4R2014 has a spectacular aura about
T4R2014's Avatar
Tail pipe
Muffler
That system is the facking bees knees. 2 winters later and it hasn't rusted anywhere but the hangers. Sounds just right too. BUY IT!!
Old 08-13-2019, 10:23 PM #14
MY GARAGE
MY GARAGE
I only had this S.S on tailpipe on for 4 to 5 months.. I know the Walkers will just rot away in 3 to 4 years especially in the northeast winters. I wouldn't waste my time with Walkers exhaust. I can report back in time, but I was hoping a few folks were running these on some rides. Seems like a few people are..:-)
Old 08-13-2019, 10:41 PM #15
T4R2014's Avatar
T4R2014's Avatar
Haven't been so impressed with an aftermarket part like I have with this. The price is insane for what you get. Looks and sounds better than my stupid JBA system that was supposed to be a "high quality aftermarket performance part".
brand , muffler , pipe , tail , years
DIY Exhaust Muffler Tail Pipe Replacement 46runner 4th Gen T4Rs 27 05-27-2019 02:30 PM
Any aftermarket oem equivalent muffler and tail pipe that is worth it? shahsmerdis 4th Gen T4Rs 2 05-07-2018 03:11 PM
Gasket between muffler and tail pipe nissanh 3rd gen T4Rs 4 03-30-2017 03:56 PM
Looking for muffler and tail pipe for 2007 4Runner v8 Brooklyn@3260 Free 0 04-27-2016 05:49 PM
Muffler to tail pipe gasket size or part? pb&j 3rd gen T4Rs 2 04-10-2015 02:10 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
