Old 08-12-2019, 09:33 PM #1
Runrunrunrun Runrunrunrun is offline
Runrunrunrun is on a distinguished road
Leaking Master Cylinder
Greetings.
I'm in the midst of a 4,000 mile road trip with my '97 SR5 2WD 125k 4runner and yesterday my e-brake light came up and i discovered my brake fluid had dropped from the full level to far below the min line, and my brakes had gone squishy.
I topped the reservoir off with new brake fluid to make it another 200 miles and that leaked from Max to Min over the duration of the drive. It seems the leaking is coming from where the Master Cylinder meets the Brake Booster. (Pictures below)
I haven't bled my lines yet because having a visual on the leak I'm assuming it makes sense to swap the Master Cylinder first, but just wanted some input from the board as well.
Thanks in advance!
Runrunrunrun is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 10:32 PM #2
shahsmerdis shahsmerdis is offline
shahsmerdis is on a distinguished road
that doesnt look good, but wipe it down and see if it comes back, but i'd check your the other wheels first that doesnt look like its been weeping that much fluid...
at least you don't have the newer models which seem to cost an arm and leg
2004 limited V8
2002 SR5 V6
shahsmerdis is offline   Reply With QuoteReply With Quote
brake , cylinder , fluid , master , min
Master cylinder leaking....need to fix....help moloss 4th Gen T4Rs 13 08-01-2019 03:18 PM
ABS master cylinder to one ton master swap? dennisuello 3rd gen T4Rs 3 07-16-2018 07:02 PM
Slave cylinder or master cylinder? That is the question. ieatelk Classic T4Rs 8 07-14-2012 04:54 PM
master cylinder leaking... mjbuzby Maintenance/Detailing 1 06-30-2010 08:00 AM
Master Cylinder, Slave Cylinder Issue bomhour Classic T4Rs 6 01-10-2010 09:14 PM
