Old 08-13-2019, 02:39 PM #1
Temple90 Temple90 is offline
Temple90 is on a distinguished road
ABS Light on after axle swap/rear end build
I currently have my 1999 4runner at a shop that swapped my axle housing and rebuilt the rear. They were unable to salvage old ABS sensors and ordered new aftermarket sensors. After installing the sensors they cannot get the ABS light to go off.
Anyone have any suggestions as to why the abs would stop working after swapping sensors?
Temple90 is offline   Reply With QuoteReply With Quote
Old 08-13-2019, 04:11 PM #2
JohnMc JohnMc is offline
JohnMc will become famous soon enough
Some possibilities:
- ABS sensors are not the correct type (too far from the tone ring)
- ABS rings were installed on the axle shaft in the wrong position (along with the axle seal - there's an annoying air gap between them and the bearing when pressing things on)
- ABS rings installed don't have the correct spline counts
- ABS sensors have a wrong resistance and it is triggering fault detection on the ABS ECU
gray wire/1" body lift/32" tires/'Snowflake' TRD Taco wheels/231mm Tundra brakes/Rola rack
JohnMc is offline   Reply With QuoteReply With Quote
Old 08-13-2019, 06:15 PM #3
3bears 3bears is offline
Real Name: Joshua 3 Bears
3bears is a jewel in the rough 3bears is a jewel in the rough 3bears is a jewel in the rough
Originally Posted by JohnMc View Post
Some possibilities:
what he said. if a shop your paying money too cant figure it out...wrong shop or someone claiming to be a shop...is not
2000 SR-5 V6 Auto . Desert Dune, Spectre intake, Borla muffler, Magnafine tranny filter, B&M cooler, Talls, KYB, Airlift 1000, DRL delete, Big 3 wire, full rack, TBU, Swapped in Elocker, some LEDs, PIAA headlights, , Amsoil
Old 08-14-2019, 09:19 AM #4
Some possibilities:
Thank you for the suggestions!
Old 08-14-2019, 09:20 AM #5
I am starting to figure out now that it was not the best shop. They are considered one of the best 4x4 shops in the area so I am very surprised I am having this issue.
Old 08-14-2019, 10:16 AM #6
If you unbolt the ABS sensor, you should be able to look down into the hole and see the ABS tone ring. If it's off to one side or another, that's a problem. The sensor needs to sit right over the ring.
If it's more or less centered in the hole, then try to carefully measure how far down it is from the mounting face of the sensor on the axle to the top of the teeth - where the sensor would sit. Then carefully measure how far the tip of the sensor extends down from the mounting surface as well. The sensor needs to be pretty close to the tone ring to work - somewhere between .5 and 1mm.
With a good multimeter, try checking the resistance. I'm not sure what the 'correct' reading for a rear ABS sensor is, but just check that it's not an open circuit, or a short circuit. if your multimeter has an A/C current voltmeter setting, you could try spinning the wheel and seeing if you get a reading. It passively generates alternating current as the splines pass the sensor tip. It's not a great test that everything is 'correct', but just a good enough test to see if it's dead or not.
And then just look at the wiring on the sensor, and on the car where it plugs in.
abs , aftermarket , axle , light , sensors
Axle swap, Lockers, Gear Info for my new build SunPilot 4th Gen T4Rs 29 02-22-2019 06:41 PM
Cougar House Garage 17' 5Th Gen Limited 4Runner Solid Axle Swap Build Cougar House 5th gen T4Rs 60 09-25-2018 12:16 PM
02' rear axle swap to put an elocker in. . stir_fry_boy 3rd gen T4Rs 32 05-03-2018 08:43 AM
Rear Axle swap 99yota4 3rd gen T4Rs 7 07-27-2010 12:48 PM
Rear Axle Swap GEN2 '90->'93 ???? captwalker87 Classic T4Rs 9 11-17-2005 11:18 PM
