08-16-2019, 04:18 PM
#16
I have used Mann filters in the past.
08-16-2019, 08:22 PM
#17
Real Name: 3 Bears
Real Name: 3 Bears
Originally Posted by T4Rscott
I wouldn’t drink Starbucks if my life depended on it. They are an anti- American company. Same with Levi’s and Nike.
did I miss something in this fuel filter thread ?
maybe someone should be driving a bronco instead of a Japanese 4runner
08-17-2019, 05:31 PM
#18
Toyota has a diverse supply chain to support its business operations. In Japan, Toyota buys directly from 200 component suppliers. Based on data from Toyota's headquarters, the 200 suppliers account for 2 billion units of which 150,000 types are purchased monthly.
Kyosan Denki is a Denso Group member, hell the 3.4 got ND and NGK plugs ..fuel filter isn't super special.
08-17-2019, 05:51 PM
#19
Or you can do what toyota recommends and not replace it. They are supposed to be lifetime filters.
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
03-18-2021, 01:06 PM
#20
lifetime meaning like 10-15 years or so. I think spending $20-$40 and replacing it is a good call on a rig like mine with 215k miles... even if the only real benefit is the satisfaction of wrenching and having my engine bay have one less rusty old part in it
03-18-2021, 08:57 PM
#21
Real Name: Samuel
Real Name: Samuel
I slapped a wix on mine and reused the bracket. Wix makes good filters, and if you're going to go aftermarket, then it's best to try to use the quality parts. As for me, nothing has exploded yet soooo...
03-19-2021, 03:30 PM
#22
I don't believe in anything "lifetime" like the ATF on the newer BMW's.
2000 4Runner Limited 4x4 V6
03-19-2021, 04:48 PM
#23
Real Name: Andy ಠ_ಠ
Real Name: Andy ಠ_ಠ
Land Rover claimed the ATF in the ZF trans on mine was lifetime. Turned out ZF put out a service bulletin clearing stating the fluid should be changed under normal use @ 120K, under heavy use @ 80K.
lifetime != forever, you got that right on.
03-19-2021, 05:57 PM
#24
lifetime = just past the drivetrain warranty period.
1999 SR5 V6 manual trans 4x4 - Lifted on 35's - Build thread
03-22-2021, 11:41 PM
#25
Ready for this?
Originally Posted by Brian.
I had to replace mine last weekend. Got mine from a 2009 Honda Accord V6 with 45k miles on it ahhaahahaha $25 bucks from junk yard! It is just a fuel pump. It drives so much better. Got more fuel going to the rails and all that good stuff.
I got
Current: 1999 4runner Limited 2wd (Desert Trooper) 170k miles! - WIP!
- s13we brake upgrade
New: 2001 4runner SR5 2wd (Silver Surfer) 213k miles! - WIP (looking for engine)
New: 1999 4runner Limited 2wd (KiTT) 577k miles!!!!!!!! - WIP!
Sold: 2000 4runner Limited 2wd 220k miles (idiot! i know)
03-23-2021, 09:28 AM
#26
Originally Posted by mtbtim
I guess everyone is different, but for such a small savings, why use aftermarket? The clear cut choice to me is to use an OEM fuel filter and try to save money somewhere else in your life if money is tight. Don't buy your Starbucks triple mocha latte for a couple days. Eat at home instead of going out to eat. In my opinion, the peace of mind you're buying by going with OEM is worth it. We know OEM fuel filters can give you 100's of thousand trouble-free miles. Will the Wix or other aftermarket filter do the same? Nobody probably knows because they haven't been able to put 200-300k on a Wix or other aftermarket fuel filter. Go with the proven OEM filter and call it a day.
Yeah, for something that you change every 200k or so why bother cheaping out. Especially on something that can leave you stranded it if collapses etc.
05-15-2021, 03:40 PM
#27
Reusable Bracket
How did you get the bracket off the original? 10 mm wrench? I've been soaking the bolt / nut with Kroil and can't get it loose. The nut appears to be tack-welded to the frame so I am assuming the bolt comes out.
I also ordered Wix not realizing it didn't come with bracket. I've also now ordered an OEM with bracket but would hold the OEM if I could get the bracket onto the Wix. Thanks.
James
2001 4Runner SR5 4WD - 231 mm TBU, B&M 70264 external transmission cooler, Magnefine external transmission filter
05-15-2021, 06:17 PM
#28
There is no trick to it, just loosen the bolt and the bracket will slide off the filter. If it is too rusty to get the bolt out then I guess that is another issue. Cut and replace the bolt?
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
05-19-2021, 05:25 PM
#29
Real Name: Samuel
Real Name: Samuel
Oh man, I'm pretty sure I was able to pry it enough to slip the old one out, or maybe i did just unbolt it, can't quite remember.
05-20-2021, 09:52 PM
#30
I replaced my fuel filter last weekend and it was more work than I thought. Saw online videos and thought it would be easier than an oil change. But on the 3rz-fe vehicles the filter is under the intake manifold.
