Old 09-01-2019, 12:31 AM #16
jason275 jason275 is offline
jason275 is on a distinguished road
Originally Posted by 4x3Lander View Post
REALLY cool to see jason275! Having your daughter part of the building, cleaning, working and then eventually enjoying the 4Runner will make for so many positive outcomes in her life and of course yours.
Where in Cali are you?
Torrance, CA
Originally Posted by 2TH4IST View Post
Awesome! That cleaned up nicely! Good thing about oil leaks: no rust and all bolts under the leak should* not be seized due to oil. But I'd recommend replacing the rack bushings as the oil kills them quickly.
*some still might be rusted tight ie alignment cam sleeves.
I ordered some Polyurethane bushings for the rack and rear sway. Front sway is going away, Going OEM LBJ and JBA UCA's.
Been driving it around, here's some observations:
  • It feels like the suspension bottoms out too frequently and struggles to keep the truck stable. Under hard braking she nose dives hard to the driver side, once off the brake, she recollects herself and recenters lol, totally sketchy. Bilsteins/Springs, LBJ, UCA ordered to hopefully remedy this.
  • It came with two keys when I got it, I dont think there are any OEM locks on this truck at all. I'm going to replace the ignition cylinder temporarily until I can get a set of OEM keys/tumblers set for the whole truck
  • Gauge cluster lights are so dim, can't see anything at night on the dash. SuperBrightLed's to the rescue!
  • Radio works, but the speakers are blown, there might be one speaker in decent shape. Headunit / Speakers on the way for these issues.
  • A/C & Heater work great, but the vent closest to the driver door has very little air flow, like its clogged. I'll have to keep this in mind when I rip into the dash to install new things.
and Thanks to @Dezert4Runner for the super fast shipping on the arm rest!
Arm Rest
I found these on CL:
4.30 Front Diff
4.30 E-Locker Rear Diff
Only if I didn't need to replace so many things, I would have gotten those instead
Have a great Labor Day Weekend everyone
jason275 is offline   Reply With QuoteReply With Quote
Old 09-08-2019, 11:59 PM #17
Weekend Update, Kiddo wasn't around this weekend, Had too much homework unfortunately
Started by replacing the IACV, I did try to clean it out first, didn't work. Went cheap aftermarket on Amazon.
Untitled
Then started to replace the worn/cracked suspension bushings
Untitled
I kinda wish I hadn't, but then again I'm glad I did...
Noticed an oil leak...
Untitled
Yup, Rear main
So I began the teardown right away, overnighted the parts so I can knock it out on the weekend (that was the hope anyway)
Untitled
Got all the bits out (Kinda like legos! Except I dont wanna play)
Untitled
A view I'd rather not see, unless fun modifications call for it:
Untitled
All for this little guy
Untitled
I failed and did not complete the task, Still have to put everything back together.
Old 09-09-2019, 12:54 AM #18
4x3Lander's Avatar
4x3Lander 4x3Lander is offline
4x3Lander is on a distinguished road
4x3Lander's Avatar
Wow, that's impressive jason275! You go all in when you start digging through it all. Really cool work to see.
I too, will replace all my rear end bushings in the next two weekends. Mine look about like or worse than yours.
Don
4x3Lander.com
info@4x3lander.com
2002 4Runner Sport Edition - 4WD auto / 3” lift / 33” tires
4x3Lander is offline   Reply With QuoteReply With Quote
Old 09-09-2019, 12:55 PM #19
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a spectacular aura about JZiggy has a spectacular aura about
JZiggy's Avatar
@jason275 Are you planning to speedi-sleeve the crank where the seal rides? Or just R&R the seal and call it good?
"Check out that four by four, that thing is hot!" - Marty McFly
1999 4Runner 3RZ/W59/4WD Turboencabulator
JZiggy is offline   Reply With QuoteReply With Quote
Old 09-09-2019, 08:24 PM #20
Thanks, I like to be thorough. As much as possible, I try to do it right, and do it right the first time (but we all know shit happens lol)
I have not even heard of this speedi-sleeve you mention, I seems interesting though. I just replaced the seal.
Old 09-09-2019, 08:42 PM #21
tukes mountain man's Avatar
tukes mountain man tukes mountain man is offline
Real Name: Craig Thompson
tukes mountain man is on a distinguished road
How fun is that. It's great that your passing on knowledge to your daughter. She will never forget the time spent with her father. Have fun.
Tukes Mountain Man
2019 4runner TRD Off Road Premium
2007 FJ TRD SE
2003 4runner V8 Limited passed down to our son.
tukes mountain man is offline   Reply With QuoteReply With Quote
Old 09-10-2019, 12:44 AM #22
Its a blast! We are having fun, too much sometimes, there have been some days where very little gets done, but tons of smiles and laughs
Old 09-10-2019, 11:28 AM #23
blarblarjosh blarblarjosh is offline
blarblarjosh is on a distinguished road
Originally Posted by jason275 View Post
Thank you all for the positive support! We really do appreciate it! It's a slow and sometimes aggravating process, but we are enjoying it... so far at least lol
Quick Update.
We gave her a valve cover gasket job along with timing belt / water pump.
I read about this on the forums lol, It barely moved, but enough for me to use a cheater bar with the breaker to fully break the bolt free.
Got 'em
Gave it a little cleaning
So much gunk It's hard to tell what's actually leaking, So I went under for a good hour it felt like trying to clean everything off, so I can get a good assessment of what's actually leaking and from where... who knows what kind of issues I'll find.
IMG_3948
IMG_3947
Like Father, Like Daughter? Snuck in the Tacoma for LBJ replacement
Got her buttoned up, topped up fluids (Will do a drain/fill next) Test drove, No more oil leak, but there is what seems to be an exhaust leak coming from the Crossover pipe It was late, so I'll have to put that on the list of things to do/check
Next to the trusty 2Runner :P
Thank you all again for being such a great community
How exactly did you clean this other than elbow grease? I'm baffled at how clean it came out. I know you're doing some amazing work, but this stands out to me Lol.
blarblarjosh is offline   Reply With QuoteReply With Quote
Old 09-10-2019, 03:04 PM #24
STI_MECE STI_MECE is offline
STI_MECE is on a distinguished road
+1, to me it seems like a pressure washer from a distance, a good bristle brush and degreaser?
I need to do mine
2000 SR5 2x4 Resto/Maintenance
STI_MECE is offline   Reply With QuoteReply With Quote
Old 09-10-2019, 09:07 PM #25
I need to do mine
lol, no pressure washer, I did use a hose though. Just elbow grease really.
Sprayed degreaser (I used simple green semi-diluted, 20% water lol) let it soak a bit, used a brush with a handle to break up the grease chunks, then hose off.
Did that a few times to get a large majority of it off, then a final sweep with a rag and degreaser to finish it off.
It does take time and patience. Large clumps of grease have more sticking strength, so just focus of those areas. Once the clumps are broken apart, they hose off pretty easily after letting the degreaser of your choice do its thing
Old 09-11-2019, 12:29 AM #26
Ryance39 Ryance39 is offline
Real Name: Ryan
Ryance39 will become famous soon enough
Real Name: Ryan
I need to do that same clean up on mine. I’m so not looking forward to the mess...
1962 Mercedes 220S Heckflosse
1999 Toyota 4runner Limited
2001 BMW M5
2013 BMW X3 F25
Ryance39 is offline   Reply With QuoteReply With Quote
Old 09-11-2019, 04:58 AM #27
Chrslefty Chrslefty is offline
Chrslefty is on a distinguished road
Awesome job on getting the underside all cleaned up. I started a similar project with my son we have a 97 also.
Chrslefty is offline   Reply With QuoteReply With Quote
Old 09-11-2019, 03:05 PM #28
det107 det107 is offline
det107 is on a distinguished road
...Kiddo wasn't around this weekend, Had too much homework unfortunately
If I was the teacher, I would be satisfied w/note from "dad" & give kiddo an A+ for tackling real world stuff!!
det107 is offline   Reply With QuoteReply With Quote
cover , daughter , limited , truck , valve
Father and Son Lexus Build TOY2G Lexus GX470/460 1 04-02-2019 08:54 PM
1997 4Runner Build BioHaZarD125 3rd gen T4Rs 7 08-08-2015 03:09 PM
97moneypit's 1997 t4r build 97moneypit 3rd gen T4Rs 6 11-07-2013 01:53 AM
The Father Teaching his Daughter a lesson, Reactions? JohnsD90 Off Topic 96 02-25-2012 10:35 AM
father kills daughter riceandpho Off Topic 4 08-18-2011 12:01 AM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
