Old 09-25-2019, 02:00 AM #31
4x3Lander's Avatar
4x3Lander 4x3Lander is offline
4x3Lander is on a distinguished road
4x3Lander's Avatar
So cool to see all of the continued progress and with your daughter
I bought those exact jack stands last weekend. Now I need to buy the same floor jack.
Don
4x3Lander.com
info@4x3lander.com
2002 4Runner Sport Edition - 4WD auto / 3” lift / 33” tires
4x3Lander is offline   Reply With QuoteReply With Quote
Old 09-25-2019, 03:52 PM #32
nissanh nissanh is offline
nissanh will become famous soon enough
Since you know all these, you can now run a 3rd gen 4runner and 1st gen tacoma workshop.
Old 09-25-2019, 06:12 PM #33
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is online now
Real Name: Evan
Dezert4Runner will become famous soon enough Dezert4Runner will become famous soon enough
Real Name: Evan
I’m glad the console lid went to a good home. It’s awesome you and your kid have a 3rd gen to restore and build together. My 14 yr old has no interest in offroad capable vehicles, when the time comes she wants a compact like a Smart car or Mini Cooper or Fiat because they’re “cute”
2000 Black Sport 4WD 5spd-2.5" SAW • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 285/75/17 BFG KO2 on 5th gen SR5 wheels • 231mm TBU / Wheelers SS lines • MStudt extended quick disco links • Satoshi • Weathertechs • K&N FIPK w/ AFE dry filter • Spidertrax • Stubbs HD-SKO sliders • Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Borla Pro XS • Any 7 fab gas tank skid
Dezert4Runner is online now   Reply With QuoteReply With Quote
Old 10-17-2019, 09:58 PM #34
jason275 jason275 is offline
jason275 is on a distinguished road
Finally got the fronts in!
59165625749__19CBEBE5-A1DB-408C-9D68-46FDFEE3887C
Installed! New rotors and pads as well
IMG_4298
Lookin' good, if I do say so myself
IMG_4326
Sitting right, just not so pretty at the moment
RenderedImage
Kiddo did a headunit and speaker upgrade
IMG_4284
IMG_4286
While I got to install the alarm... yay
AA2D26F2-E5AA-4B60-8154-ECB9D0A93E4E
Let there be light!
IMG_4366
LED's are awesome, the light is actually usable now lol. But I have a problem with the Passenger Dome light not switching on when a door is open It works fine when I switch it to ON. The Trunk Light functions no problems under the Dome setting.
Got myself a new tool cart and organized a bit
IMG_4353
Thanks for reading
jason275 is offline   Reply With QuoteReply With Quote
Old 10-18-2019, 12:18 PM #35
phattyduck is a glorious beacon of light phattyduck is a glorious beacon of light phattyduck is a glorious beacon of light phattyduck is a glorious beacon of light phattyduck is a glorious beacon of light phattyduck is a glorious beacon of light
Thanks for reading
Does the door open indicator on the dash work? If not, its the door switch(es), if it does, clean the contacts on the dome light.
I'm having the opposite problem - my hatch doesn't turn on the cargo light (and doesn't turn on the door-open indicator on the dash). Still haven't torn it apart though.
'16 Honda Odyssey
Old 10-18-2019, 02:54 PM #36
Yes the door open indicator on the instrument cluster works as intended. And I have checked each door switch to test it.
I have been doing some researched and what I've found is that the wiring for the Dome lights are a little different. They are a switched ground or something along that line. So I'm thinking there's a bad ground somewhere.
Old 10-18-2019, 03:53 PM #37
I just peeked at the '97 wiring diagrams I have... the 'door' connection for the dome light does route back to the integration relay, not directly to the door switch circuit. Of course, the way it is drawn in the diagrams, the light would be ON all the time in the "DOOR" position, so there is some error in the diagrams.
At least it isn't the black box that is the '99+ lighting system, controlled by the gauge cluster, of all things (as are the headlight auto-off and a bunch of other things).
'16 Honda Odyssey
Old 10-18-2019, 08:02 PM #38
HiLife HiLife is offline
HiLife will become famous soon enough
Safety first. Glad you took your safety seriously and got some jack stands.
Great thread! Keep it going. Your daughter will be the smarter one as she gets older because of your involvement. She is getting hands on knowledge how parts go together and function. And hopefully watching on how you troubleshoot when parts are not working.
She will thank you if she ever steps into a repair shop/parts store alone.
Old 10-18-2019, 11:39 PM #39
That is the idea with this project, but ultimately with everything right? Teach them what we know so they are just as independent and capable as ourselves
I did some wire cleanup today.
The previous owner definitely had some electrical done. I found what looks like previous splices for an alarm with an aux kill switch, and the truck had aftermarket aux lights at one point.
There were some wires that seemed like they were cut accidentally, Nothing spliced to them, just cut and reconnected. I even saw one with bare wire just hanging there lol
So I looked for all these mysterious cuts and found a couple that were not reconnected, I didn't have a wiring diagram for reference, so I just traced the wires to find it's matching colored end and connected them.
There were two red w/ white stripe wires by the driver kick panel that I reconnected. They both came from the wire loom coming from the floor.
Sorry I said I was terrible at electrical my description probably confused you more than anything, I don't know what I reconnected but the Dome light works as intended now which is great.
Old 10-21-2019, 12:53 PM #40
Glad to hear it is working. That Red-White wire is probably the connection from the back hatch door switch (though there are other Red-White wires in the truck that do other jobs).
Front driver's door is a Blue wire, the other three doors are Black-White.
'16 Honda Odyssey
cover , daughter , limited , truck , valve
Father and Son Lexus Build TOY2G Lexus GX470/460 1 04-02-2019 08:54 PM
1997 4Runner Build BioHaZarD125 3rd gen T4Rs 7 08-08-2015 03:09 PM
97moneypit's 1997 t4r build 97moneypit 3rd gen T4Rs 6 11-07-2013 01:53 AM
The Father Teaching his Daughter a lesson, Reactions? JohnsD90 Off Topic 96 02-25-2012 10:35 AM
father kills daughter riceandpho Off Topic 4 08-18-2011 12:01 AM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
