3RZ 4WD 1999 4Runner. I’m trying to locate the correct part number for the u joint at the rear diff. Seems to be about three different part numbers floating around in the parts lookup sites and the related threads. Can anyone steer me straight?
Are all 3rd gen rear u joints the same? If not what makes them different?
Stock u-joints are greasable. I do them every other oil change.
I do not grease the slip yoke though as the zerk fitting doesn't do squat to actually lube the splines. Best bet is to take it off, clean it out, and manually brush on the grease. I only do that once a year and it seems to be fine.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
