Old 08-15-2019, 07:03 PM #1
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
Rocker Panel Rust: How to stop it
Purchased 02 SR5 Sport couple months back.
1) Planning to treat the undercarriage/frame with Fluid Film or WD-40 on an annual basis to prevent any FURTHER deterioration due to rust and corrosion but hoping for some input regarding the rust that has started to form on the rockers.
I don’t see any access or drain holes which will allow me to spray inside the rockers.......where the rust actually starts.
Are there any, maybe I’m just missing them?
2) The frame is solid but does have fair amount of surface rust, some areas more than others. Thoughts on going with POR 15 to those areas before starting to treat with Fluid Film/WD-40.
Any suggestions much appreciated.
Pictures are of rust to the rocker in the area where front door meets the fender and the rear area by the rear door as well, just beginning at the seam.
Rocker Panel Rust: How to stop it-efefc6ef-61e5-4bba-9139-8fdbe732fd47-jpg  Rocker Panel Rust: How to stop it-308876c9-260b-439f-a7a6-b6047914cda9-jpg
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 08-15-2019, 08:05 PM #2
heat's Avatar
heat heat is offline
heat will become famous soon enough heat will become famous soon enough
heat's Avatar
rocker drain:
Rocker Panel Rust: How to stop it-drain-jpg
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is offline   Reply With QuoteReply With Quote
Old 08-15-2019, 08:25 PM #3
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
The best access to inside the rockers is under the plastic trim pieces under the doors. The pieces that are under the doors when you open them, between the carpet and rubber seal. Remove the screws and pull the trim plates up.
There are quite a few bigish access holes this way, enough that you can wash out the rockers if you wish and certainly spray inside them. I do mine every 2nd year or so.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 08-15-2019, 08:31 PM #4
Jeckolame Jeckolame is offline
Jeckolame is on a distinguished road
+1
Jeckolame is offline   Reply With QuoteReply With Quote
Old 08-15-2019, 09:41 PM #5
Perfect!!
I was focused on looking for drain holes on the underside, completely forgot to check the topside.
Should be easy enough, just open the doors and remove those sill plates to access those areas and hit them with Fluid Film/WD-40, etc.
Any thoughts regarding the need to apply POR 15 to rusty areas on the frame prior to coating annually with Fluid Film/WD-40?
2002 SR5 Sport 4WD
Old 08-15-2019, 09:42 PM #6
Originally Posted by heat View Post
rocker drain:
As they say, picture’s worth a thousand words!
Thanks!
2002 SR5 Sport 4WD
Old 08-16-2019, 08:28 PM #7
Crowcifier6 Crowcifier6 is offline
Real Name: James
Crowcifier6 is on a distinguished road
Real Name: James
I'm interested in hearing the consensus on the paint before fluid film vs fluid film bare/treated metal. I've been rust busting casually before the New England winter, and have decided to go fluid film on bare metal to simplify things.
The way I see it, painting is an added step and time, where as if I am vigilant with the undercoat (>2 x a year), I can get away with it.
Maybe I'm lazy, but cutting the painting out (and hours of prep), and keeping a nice coat of Fluid film seems the answer to me.
98 Base Model 2.7L
Crowcifier6 is offline   Reply With QuoteReply With Quote
Old 08-17-2019, 12:08 AM #8
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
If you have a sunroof, then that rust isn't stopping no matter what you spray. How do I know? I sprayed oil in that same spot. The sunroof drain exits in the rocker, which is why it is rusting. As such it will wash away whatever oil you use in that spot.
Old 08-17-2019, 12:51 AM #9
bo4osu's Avatar
bo4osu bo4osu is offline
Real Name: Alex
bo4osu is on a distinguished road
bo4osu's Avatar
Real Name: Alex
I completely sealed my sunroof closed. And disconnected power to it. No more leaks
bo4osu is offline   Reply With QuoteReply With Quote
Old 08-17-2019, 02:30 PM #10
My rust bubble was growing. I flooded it with metal prep oil and it seems to have stopped growing. However, I will need to replace that front section of my rocker.
It’s funny how it’s one of the only common places they rust
area , fluid , rocker , rust , treat
Running Board Removal w/o Front Mud Flaps and Rocker Panel Corrosion/Rust 07V8 4th Gen T4Rs 8 09-29-2018 04:46 PM
13 SR5 rocker panel question outkast14 5th gen T4Rs 5 12-10-2017 12:33 AM
Midwest Rocker Panel Rust Tommy Argh 3rd gen T4Rs 1 08-20-2014 10:59 PM
Rocker Panel Dent Dous 3rd gen T4Rs 7 10-28-2012 02:44 AM
rocker panel delete or cut? silversx 5th gen T4Rs 17 05-16-2012 01:31 PM
