Old 08-15-2019, 09:49 PM #1
19994Runner5spd 19994Runner5spd is offline
19994Runner5spd is on a distinguished road
To much boat for my 4Runner?
Hi all. I purchased a clean 2001 Chaparral 196SSi with the 5.0 this past weekend. Very well maintained and only used on lakes. 531 hours. My question is this. I have a 99 Toyota 4Runner with the 3.4 V6, 4x4 and a manual. Vehicles weights 3400 lbs. Max tow rating is 5000 lbs. I have trailered and launched my buddyís 16 ft center console a handful of times and no issues. That boat is 1700 lbs though vs this one being about 4600 with fuel, trailer and boat.
I am concerned about two things, one getting pulled into the water/sliding in and two being able to pull this boat out of the water. I think in 4 low I will be ok.
I have wheel chocks for the front and rear tire and obviously will use my e-brake and put it in first gear when I unload.
Do I need to upgrade to something heavier ASAP to launch this boat? I towed it home 70 miles and had no issues.
Looking a few local GXs tomorrow that have the 4.7 and are about 1000 lbs heaver.
Current:
1999 4runner SR5 5 Speed 4x4 99 tall springs w/ 265/75/16 BFG KO2's
2003 4Runner Limited 4x4 4.7 V8
Past: 1990 4Runner SR5 22RE 4x4 Auto -- 2007 4Runner Limited V6 4x4--
2012 4Runner Limited V6 4x4 3" OME 285/70/17's
19994Runner5spd is offline   Reply With QuoteReply With Quote
Old 08-15-2019, 10:00 PM #2
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree has a spectacular aura about thezentree has a spectacular aura about
thezentree's Avatar
Originally Posted by 19994Runner5spd View Post
Hi all. I purchased a clean 2001 Chaparral 196SSi with the 5.0 this past weekend. Very well maintained and only used on lakes. 531 hours. My question is this. I have a 99 Toyota 4Runner with the 3.4 V6, 4x4 and a manual. Vehicles weights 3400 lbs. Max tow rating is 5000 lbs. I have trailered and launched my buddy’s 16 ft center console a handful of times and no issues. That boat is 1700 lbs though vs this one being about 4600 with fuel, trailer and boat.
You need a half ton truck if you're gonna tow that boat regularly.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 08-15-2019, 10:19 PM #3
toyotaspeed90 toyotaspeed90 is offline
toyotaspeed90 is on a distinguished road
If you're looking at GXs consider a 100 series LX instead....
6500lb tow rating, throw on some air lift in the rear and you're good to go.
Some new half ton trucks have a tow rating under 5k lbs.... so I wouldn't trust that blanket recommendation.
toyotaspeed90 is offline   Reply With QuoteReply With Quote
Old 08-15-2019, 10:31 PM #4
I appreciate the post. I am looking at the GXís as Iím trying to stay the same length as my 99. If so it should be easy for my wife to drive. I really donít want to go much bigger if I can help it. I figure with the 4.7 and the extra weight it should tow and stop the boat without issues. Am I off base here?
Current:
Old 08-16-2019, 04:38 AM #5
tvpierce's Avatar
tvpierce tvpierce is offline
tvpierce will become famous soon enough
tvpierce's Avatar
Nice boat!
How far do you tow to get to the body of water in which you plan to use it?
Does the trailer have brakes?
tvpierce is offline   Reply With QuoteReply With Quote
Old 08-16-2019, 07:29 AM #6
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is a jewel in the rough LittleCaesar is a jewel in the rough LittleCaesar is a jewel in the rough
If the ramp is less than two miles away and not steep you may be OK. But the Tundra brake upgrade would be a must.
Either the 470 or 460 would make your life much easier, or a 4th gen with the 2uz. It is hard to substitute for the raw power of the V8 as well as the hitch distribution.
Enjoy the boat, looks like fun.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 08-16-2019, 08:25 AM #7
thegipper's Avatar
thegipper thegipper is offline
thegipper has a spectacular aura about thegipper has a spectacular aura about
thegipper's Avatar
As long as the boat launch is paved, your truck in 4lo should pull it out no problem.
My boat and trailer are probably 2500ish lbs and towing it definitely sucks, so I could imagine towing a 4600lb setup would REALLY suck. Something with a 2UZ and bigger brakes would definitely be much better.
Like others have said, if you plan on using it at nearby lakes, you may be ok (I would still do the TBU) but if you plan on towing this thing all over the county/state, I would consider getting something with some more ponies.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 08-16-2019, 08:27 AM #8
Originally Posted by tvpierce View Post
Nice boat!
Hi, great question, itís about 40 miles each way. It dos have surge brakes that work quite well. Stops better towing this boat than my little utility trailer(5.5x10) does without them.
We are going to look at several GX470s today. I hate to sell my clean third gen but I think the 4.7 would tow it and stop it so much better.
Current:
Old 08-16-2019, 09:20 AM #9
thezentree's Avatar
thezentree's Avatar
Yeah and some are rated for over 10k so I wouldnít recommend that OP entirely discount my ďblanket recommendationĒ either.. Iíve done a lot of towing near or at max towing capacity and it was really, really not fun.
Thatís probably the right call. You could probably do it in your 3rd gen but it would be a little butt puckering. 400lbs is not a lot of margin.
Old 08-16-2019, 09:59 AM #10
I suggested an LX over the GX because of the longer wheelbase which would provide additional stability. The LX is a big vehicle and when parked next to a 3rd gen makes the T4R look small (we have both), I do agree there.
I will say, though, that driving an LX470 doesn't feel like a Tahoe/Suburban in size even though they're very similar. I think it's in part due to how the interior has been well put together where you don't feel like you're driving an empty auditorium down the road.
Old 08-16-2019, 10:12 AM #11
alumarine alumarine is online now
alumarine will become famous soon enough
You don't have to worry about the boat dragging the truck in unless you're backing in too fast.
Most mishaps happen due to driver error.
Once the boat begins to float then it's just the trailer weight left.
4lo will get you up any ramp that's reasonable to launch from.
Well working surge brakes should be ample.
As far as the 40 miles goes it all depends on the terrain how pleasant the tow will be.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is online now   Reply With QuoteReply With Quote
Old 08-16-2019, 11:08 AM #12
3bears 3bears is offline
Real Name: Joshua 3 Bears
3bears is a jewel in the rough 3bears is a jewel in the rough 3bears is a jewel in the rough
while I have pulled small trailers and a 21 foot sjx boat with my 4 runner, and I do have the TBU, pulling out of a boat ramp was no issue. however I would not do this on a regular basis.
I think you r boat is way too much for the 4runner and think the Lexus options are your best bet
2000 SR-5 V6 Auto . Desert Dune, Spectre intake, Borla muffler, Magnafine tranny filter, B&M cooler, Talls, KYB, Airlift 1000, DRL delete, Big 3 wire, full rack, TBU, Swapped in Elocker, some LEDs, PIAA headlights, , Amsoil
Old 08-16-2019, 12:00 PM #13
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a glorious beacon of light T4R2014 is a glorious beacon of light T4R2014 is a glorious beacon of light T4R2014 is a glorious beacon of light T4R2014 is a glorious beacon of light
T4R2014's Avatar
Find a cheap 2001 Sequoia and use it as your beast of burden. They often go for $2500. Less abused than a Tundra would, and less likely to see off roading than an LC. It will dwarf your 4Runner. My towing recommendation.
Old 08-16-2019, 12:18 PM #14
phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold
I think you already have your answer. If it feels fine/safe, go for it.
No trans overheating issues with the manual trans, and you get more HP/TQ to the wheels while driving. The downside will be staying stopped on the ramp (no parking pawl to help the e-brake, but wheel chocks will work) and pulling the boat out with a clutch (though, 4LO should make it plenty easy).
Cheap Sequoias will be 2WD, which won't be any better on a boat ramp, though they will tow well otherwise.
'16 Honda Odyssey
Old 08-16-2019, 01:16 PM #15
Coward's Avatar
Coward Coward is offline
Coward is on a distinguished road
Coward's Avatar
I agree with this statement. If there is not much elevation change during the drive it will do all you need just fine. And so long as the drive is uneventful, your truck will handle the lake trips for what maybe 10 times a year? The issues come into play in the oh crap moments. That much weight even with trailer brakes will make panic stops or swerves more than butt puckering. They could be dangerous.
I agree with the GX or LC or Sequoia ideas.
96' 4x4 5spd-SS1.2
Coward is offline   Reply With QuoteReply With Quote
4runner , boat , issues , lbs , maintained
4Runner and Towing boat bzizzi 5th gen T4Rs 52 07-18-2018 04:33 PM
4Runner and Boat cp99sr5 3rd gen T4Rs 2 11-10-2015 03:04 PM
4runner towing a boat? jfarar 3rd gen T4Rs 14 10-21-2010 02:24 PM
towing a boat with a 2wd 06 4runner?? 064runnerguy 4th Gen T4Rs 6 05-26-2008 05:49 PM
towing 22.5 ft boat with 04 4Runner (v6) vtd 4th Gen T4Rs 50 08-13-2007 11:51 AM
