Old 08-16-2019, 10:12 AM #1
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
Exhaust bolt size question
I have a new muffler and tail pipe to install.
Does anyone happen to know the size nuts you need for two o2 sensor studs?
I believe they are M8x1.25? I want to stop at the hardware store on my way home from work and get some stainless nuts.
Also, I forgot to measure the flange bolt hole size this morning before work. I also want to get some stainless bolts/nuts.
I called my wife and had her measure the ID of the bolt holes on the two flanges (muffler to cat, muffler to tail pipe) and she got a reading of about "1/2" with my digital caliper.
Does that sound right? If so, should I get 1/2" bolts or does someone know for sure what size bolt to use.
BTW, like an idiot, I bought another Walker muffler/tail pipe and fully anticipate on replacing it again in 2.5 years assuming my truck has rusted in half before then.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 08-16-2019, 04:13 PM #2
nissanh nissanh is offline
I measured the diameter of a new bolt that goes into the flange and it is 9.91 mm (0.39 inches)
Length of the threaded part of the bolt is 36 mm (1.417 inches)
25.4 mm = 1 inch
Socket is 14 mm
Bolt flange = 90080-10064
Nut: 90080 - 17187
Old 08-17-2019, 01:16 AM #3
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
25.4 mm = 1 inch
Socket is 14 mm
Nut: 90080 - 17187
That would be an M10x1.25. If the first two digits of the second half of the p/n are 10 or 08, say, then those are M10 or M8. Same for many nuts and washers. Toyota only uses one thread pitch for each diameter:
6mm diameter - 1 mm pitch (iso course) - requires 10 mm wrench to fit head / nut
8 mm diameter - 1.25 mm pitch (iso course) - requires 12 mm wrench to fit head / nut
10 mm diameter - 1.25 mm pitch (iso fine) - requires 14 mm wrench to fit head / nut
12 mm diameter - 1.25 mm pitch (iso other) - requires 17 mm wrench to fit head / nut
14 mm diameter - 1.5 mm pitch (iso fine) - requires 19 mm wrench to fit head / nut
16 mm diameter - 1.5 mm pitch (iso fine) - requires 22 mm wrench to fit head / nut
My Backyard Frame Swap
bolt , muffler , pipe , size , work
Exhaust Spring bolt size dave4242 4th Gen T4Rs 4 06-11-2019 02:34 PM
Bolt size? Cow_doc.308 3rd gen T4Rs 10 11-21-2016 10:14 PM
Help with bolt size... mikey's2010SR5 5th gen T4Rs 10 01-21-2014 08:09 PM
Nut & Bolt size question -Trev- 5th gen T4Rs 5 01-03-2014 03:37 PM
Bolt size question Huskey 4th Gen T4Rs 8 03-31-2012 05:58 PM
