Old 07-04-2012, 10:29 PM #1
protist protist is offline
protist is on a distinguished road
Engine loud metallic engine rattle @1800 rpm after sitting in traffic
I have a 1999 Limited V6 4x4 automatic with 122,000 miles.
Over the last year I have had an engine noise that has progressively gotten worse. After I sit in traffic for over 5-10 minutes depending on the temperature outside, hotter=faster, I get a bad engine rattle when accelerating at 1800-2000rpm, particularly uphill, like getting on a onramp to get on the interstate.
If I go on the interstate for a while and come off the interstate then the noise is gone, but in city traffic the noise only goes away only if I go over 2000 rpm for 15-30 seconds. If I start out driving on the interstate for over 15 minutes then I never seem to get the noise.
The noise goes up and down with the accelerator. I find that I am unable to reproduce the noise when parked in neutral and revving to 1800-2000 rpm, but I figure it is engine related because it is accelerator dependent.
Any ideas?
protist is offline   Reply With QuoteReply With Quote
Old 10-29-2012, 04:59 PM #2
Toronto_T4R Toronto_T4R is offline
Toronto_T4R is on a distinguished road
I'd like to give this post a bump. I have a 99 SR5 4x4 and have a very similar situation to what you are describing.
Someone mentioned it could be the lifters.. I frankly have no idea.
Any leads would be a big help.
Cheers,
Andrew
Toronto_T4R is offline   Reply With QuoteReply With Quote
Old 10-29-2012, 05:10 PM #3
Singtoe's Avatar
Singtoe Singtoe is offline
Singtoe will become famous soon enough
Singtoe's Avatar
Sounds like a broken flexplate.
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
Singtoe is offline   Reply With QuoteReply With Quote
Old 10-29-2012, 05:53 PM #4
muddertrucker99 muddertrucker99 is offline
muddertrucker99 is on a distinguished road
My valves rattle when under heavy loads and sometimes after setting in traffic! i was told thats a common problem with 3.4! But mine is pushing 307k on the clock
Nitrous is like a Hot chick with an STD! You wanna hit it but your afraid of the consequences!
muddertrucker99 is offline   Reply With QuoteReply With Quote
Old 10-29-2012, 09:42 PM #5
CdaleR4000si's Avatar
CdaleR4000si CdaleR4000si is offline
Real Name: Vince
CdaleR4000si is on a distinguished road
Real Name: Vince
I had a similar noise. Try lubing the u-joints on the driveshaft.
CdaleR4000si is offline   Reply With QuoteReply With Quote
Old 08-17-2019, 08:04 PM #6
Bugler4 Bugler4 is offline
Bugler4 is on a distinguished road
Hi,
Check the exhaust header brackets that attach to the manifold flange.
Both mine were cracked and rusted through at the flange
Bugler4 is offline   Reply With QuoteReply With Quote
1999 , limited , rattle , rpm , uphill
Engine squeak when sitting at light Phx994Runner 3rd gen T4Rs 2 10-03-2011 05:52 PM
Issue with loud noise coming from engine manzach123 Classic T4Rs 1 12-27-2009 08:11 PM
Loud Engine When First Starting VSG 3rd gen T4Rs 2 07-22-2009 10:58 AM
