Old 08-17-2019, 08:41 AM #1
Crowcifier6 Crowcifier6 is offline
Real Name: James
Crowcifier6 is on a distinguished road
Real Name: James
Anything to consider when replacing front struts/coilovers?
I'm prepping to replace my front coilovers. For time, cost, and convenience, I've decided to go with a quick strut, fully assembled from NAPA. They are half the price of Toyota OEM ($150/side vs $300).
Other than the steering rack, I've gone through and replaced most of the front end suspension with OEM (UBJs, LBJs, ITRs, OTRs).
Is there anything else that should be considered when I go in to replace the coilovers?
98 Base Model 2.7L
Crowcifier6 is offline   Reply With QuoteReply With Quote
Old 08-17-2019, 08:46 AM #2
4restGump 4restGump is offline
4restGump is on a distinguished road
Brakes?
4restGump is offline   Reply With QuoteReply With Quote
Old 08-17-2019, 09:37 AM #3
Real Name: James
Real Name: James
Thanks forgot to mention I put new pads on not too long ago.
98 Base Model 2.7L
Old 08-17-2019, 10:11 AM #4
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Bushings?
Old 08-17-2019, 12:10 PM #5
Real Name: James
Real Name: James
Which bushings are you referring to?
98 Base Model 2.7L
Old 08-17-2019, 12:15 PM #6
ajskowron ajskowron is offline
ajskowron is on a distinguished road
UCA/LCA bushings if you’re into it. Quick strut should come with new bushings
Just did front 5100s yesterday from 10+ year old shocks and the top nut gave me trouble. Didn’t help my Harbor Freight spring compressors are on their way out
Quick struts will certainly be easier
ajskowron is offline   Reply With QuoteReply With Quote
Old 08-18-2019, 09:47 AM #7
Real Name: James
Real Name: James
I'll look into the control arm bushings, thanks.
98 Base Model 2.7L
Old 08-23-2019, 12:57 PM #8
Real Name: James
Real Name: James
Decided to stay with my springs that are probably stock, and putting in OEM tokickos.
I’m not sagging in front but believe the shocks are going bad....afraid new Napa springs will be to high or low.
Anyone know what comes with the front shocks from Toyota, or if I’ll need to order any hardware with them?
98 Base Model 2.7L
Old 08-23-2019, 03:54 PM #9
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
As in Landcruiser Tokico's with stock height springs?
Old 08-23-2019, 05:31 PM #10
Good choice, since you have a lighter 4-cylinder truck... And the OEMs will last another 20 years, unlike any quick struts out there.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-23-2019, 10:25 PM #11
Real Name: James
Real Name: James
No, I'll basically just replacing the front shocks within the coils, with the stock Tokicos, That's what the rear were, anyway.
I like the idea of using OEM as much as possible, that's why these trucks last so long right? I'll use aftermarket for wear items like brake pads, fluids, etc., but Toyota knows how to make parts that last. Worth it to spend a bit more on crucial parts.
98 Base Model 2.7L
Old 08-23-2019, 10:34 PM #12
Real Name: James
Real Name: James
Thanks, I never considered the weight dif between the 4 and 6 cylinders, but it makes sense.
Way I see it, if the springs wind up getting tired down the line, it will be a good excuse for an all around suspension lift...
98 Base Model 2.7L
Old 08-23-2019, 10:36 PM #13
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
May want to consider replacing upper strut mounts as they definitely deteriorate based on age & mileage.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 08-24-2019, 07:47 AM #14
Real Name: James
Real Name: James
Thanks, they look to be in good shape. The truck was garaged for most of its life, 1 previous owner was an elderly driver, so I’m lucky, not a lot of rust under there.
Anyone know which shocks I need? My model number is RZN185-L, and Toyota lists two different parts....
98 Base Model 2.7L
Old 08-29-2019, 07:01 AM #15
Real Name: James
Real Name: James
Found on the McGeorge Toyota parts site that apparently one shock is for a 16 wheel, the other is "W/O 16" rim.....why are these shocks almost $200/piece?
Spring compressor came in the mail the other day, just have to scratch a little more cash together to get the shockingly priced shocks
98 Base Model 2.7L
coilovers , front , oem , replace , ubjs
Replacing Heim Joints in Front Struts LD4R Engines / Suspension / Wheels / Tires / Audio / Accessories 0 05-25-2015 11:53 AM
Replacing Original Struts, Springs with "Quick Struts" azcat90 3rd gen T4Rs 4 06-13-2014 06:06 PM
For Sale - OEM 2011 4Runner Trail Edition Front Struts/Coils/Coilovers SOcalTRAIL For Sale: Suspension/Wheels/Tires 0 10-10-2011 06:24 PM
1998, replacing front struts! Fol 3rd gen T4Rs 5 04-01-2011 08:57 PM
Front struts replacing GoHideTheAsian 3rd gen T4Rs 2 11-09-2009 03:55 PM
