Old 08-17-2019, 08:41 PM #1
cyrataurean cyrataurean is offline
cyrataurean is on a distinguished road
2002 4Runner Check Engine Light Code P1135
The check engine light came on for the first time since I purchased my truck. The code is P1135...The Bank 1 Sensor 2 air/fuel sensor heater is not functioning properly. Can anyone help me in locate the part as well as replacing it? I would greatly appreciate it.
cyrataurean is offline   Reply With QuoteReply With Quote
Old 08-18-2019, 11:40 AM #2
heat's Avatar
heat heat is offline
heat will become famous soon enough heat will become famous soon enough
heat's Avatar
Same problem on mine, like Durk says, front air/fuel sensor fixed it. Replace
only with original Denso part. Make sure there aren't any vacuum leaks first.
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is offline   Reply With QuoteReply With Quote
Old 08-28-2019, 01:46 AM #3
Yes'm, it was the Bank 1 Sensor 2. I did replace it. However, it is now doing the herky-jerky every time I step on the gas after being at a dead stop. Is this normal?
Old 12-30-2019, 01:24 AM #4
ghettoflow21 ghettoflow21 is offline
ghettoflow21 is on a distinguished road
Originally Posted by TheDurk View Post
Are you sure that is P1135? Because that does not exist on a 2002 and is for Sensor 1, not Sensor 2 on trucks with O2 sensors in front. You have an A/F sensor in front.
I suspect you got a P1136. Confirm?
I also just got a P1135 code on my 2002 4Runner and the computer said "Air filter sensor heat circuit malfunction (bank 1 sensor 1) along with a P0300 (random misfire).
Is this the correct part that I should purchase?
Amazon.com: Denso 234-9002 Air Fuel Ratio Sensor: Automotive
ghettoflow21 is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 01:37 AM #5
Bump, any help would be appreciated!
Old 01-06-2020, 02:07 PM #6
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Originally Posted by ghettoflow21 View Post
...also just got a P1135 code on my 2002 4Runner and the computer said "Air filter sensor heat circuit malfunction (bank 1 sensor 1) along with a P0300 (random misfire). ...
Well that is the correct A/F sensor.
But I don't know that it will solve the 0300. That could be plugs, wires, coil or other.
Luck and enjoy the Runner.
Old 01-07-2020, 02:43 PM #7
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
I'm sorry, my earlier post was incorrect. (I deleted it). P1135 does apply to the front sensor on a 2002. (Bank 1 Sensor 1) I.m not sure where I was checking when I wrote that but I definitely got it wrong.
From the 2002 FSM:
http://www.teamtoyota4x4.org/archivi...fe/cip1135.pdf
According to Denso, that is the correct p/n for that sensor on all 2002 4Runners. It is an A/F sensor, not an O2.
Find My Part
As to the P0300, those can be a pain. Here is the 2002 FSM diagnostic procedure:
http://www.teamtoyota4x4.org/archivi...e/cip0300p.pdf
My Backyard Frame Swap
Old 04-08-2020, 01:31 AM #8
RaymondHat RaymondHat is offline
Real Name: RaymondHatJQ
RaymondHat is on a distinguished road
1250 ( 1250)
Киосковые Ктп 630ква,Ктп 1000,Ктп 1250,Ктп 1600,Ктп 2500
RaymondHat is offline   Reply With QuoteReply With Quote
check , code , engine , light , sensor
Check engine light on. OBDII code P1135. lamb 3rd gen T4Rs 11 06-28-2017 08:34 PM
2001 4run, check eng light, code P1135 ???? LAR_414 Problems & Warranty Issues 9 03-24-2016 01:38 PM
Check engine light on: Code 24 and code 31 Clone of the Mean Classic T4Rs 3 06-19-2011 12:12 PM
2002 4Runner- Check engine code P0446 ScottDetroit 3rd gen T4Rs 1 10-09-2008 12:16 AM
2002 4Runner- Check engine code P0446 ScottDetroit Maintenance/Detailing 1 10-08-2008 05:10 PM
