Old 08-17-2019, 08:41 PM #1
cyrataurean cyrataurean is offline
cyrataurean is on a distinguished road
2002 4Runner Check Engine Light Code P1135
The check engine light came on for the first time since I purchased my truck. The code is P1135...The Bank 1 Sensor 2 air/fuel sensor heater is not functioning properly. Can anyone help me in locate the part as well as replacing it? I would greatly appreciate it.
cyrataurean is offline   Reply With QuoteReply With Quote
Old 08-18-2019, 11:40 AM #2
heat's Avatar
heat heat is offline
heat is on a distinguished road
heat's Avatar
Same problem on mine, like Durk says, front air/fuel sensor fixed it. Replace
only with original Denso part. Make sure there aren't any vacuum leaks first.
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is offline   Reply With QuoteReply With Quote
Old 08-28-2019, 01:46 AM #3
Yes'm, it was the Bank 1 Sensor 2. I did replace it. However, it is now doing the herky-jerky every time I step on the gas after being at a dead stop. Is this normal?
Old 12-30-2019, 01:24 AM #4
ghettoflow21 ghettoflow21 is offline
ghettoflow21 is on a distinguished road
Originally Posted by TheDurk View Post
Are you sure that is P1135? Because that does not exist on a 2002 and is for Sensor 1, not Sensor 2 on trucks with O2 sensors in front. You have an A/F sensor in front.
I suspect you got a P1136. Confirm?
I also just got a P1135 code on my 2002 4Runner and the computer said "Air filter sensor heat circuit malfunction (bank 1 sensor 1) along with a P0300 (random misfire).
Is this the correct part that I should purchase?
Amazon.com: Denso 234-9002 Air Fuel Ratio Sensor: Automotive
ghettoflow21 is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 01:37 AM #5
Bump, any help would be appreciated!
Old 01-06-2020, 02:07 PM #6
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 has a spectacular aura about jgue467 has a spectacular aura about
jgue467's Avatar
Originally Posted by ghettoflow21 View Post
...also just got a P1135 code on my 2002 4Runner and the computer said "Air filter sensor heat circuit malfunction (bank 1 sensor 1) along with a P0300 (random misfire). ...
Well that is the correct A/F sensor.
But I don't know that it will solve the 0300. That could be plugs, wires, coil or other.
Luck and enjoy the Runner.
2001 Limited 4WD - 324K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL, ZERO RUST - StopTech ANGLED rotors - Magnefine trans filter - In series trans cooler, ORIGINAL: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and so on. WooHoo!!
Oh yeah, GO LONGHORNS!
Old 01-07-2020, 02:43 PM #7
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is just really nice TheDurk is just really nice TheDurk is just really nice TheDurk is just really nice
TheDurk's Avatar
I'm sorry, my earlier post was incorrect. (I deleted it). P1135 does apply to the front sensor on a 2002. (Bank 1 Sensor 1) I.m not sure where I was checking when I wrote that but I definitely got it wrong.
From the 2002 FSM:
http://www.teamtoyota4x4.org/archivi...fe/cip1135.pdf
According to Denso, that is the correct p/n for that sensor on all 2002 4Runners. It is an A/F sensor, not an O2.
Find My Part
As to the P0300, those can be a pain. Here is the 2002 FSM diagnostic procedure:
http://www.teamtoyota4x4.org/archivi...e/cip0300p.pdf
My Backyard Frame Swap
Old 04-08-2020, 01:31 AM #8
RaymondHat RaymondHat is offline
Real Name: RaymondHatJQ
RaymondHat is on a distinguished road
1250 ( 1250)
Киосковые Ктп 630ква,Ктп 1000,Ктп 1250,Ктп 1600,Ктп 2500
https://sviloguzov.ru/ktpn-160
RaymondHat is offline   Reply With QuoteReply With Quote
check , code , engine , light , sensor
Check engine light on. OBDII code P1135. lamb 3rd gen T4Rs 11 06-28-2017 08:34 PM
2001 4run, check eng light, code P1135 ???? LAR_414 Problems & Warranty Issues 9 03-24-2016 01:38 PM
Check engine light on: Code 24 and code 31 Clone of the Mean Classic T4Rs 3 06-19-2011 12:12 PM
2002 4Runner- Check engine code P0446 ScottDetroit 3rd gen T4Rs 1 10-09-2008 12:16 AM
2002 4Runner- Check engine code P0446 ScottDetroit Maintenance/Detailing 1 10-08-2008 05:10 PM
