Old 08-18-2019, 11:02 AM #1
Last Man Standing Last Man Standing is offline
Last Man Standing is on a distinguished road
New York President CB Antenna
Morning All,
I installed my New York CB Antenna yesterday and found the coax cable to be too short for proper placement on the rear of the roof rack. I chose this spot due to it's appearance as though it is a common AM/Fm radio antenna. So if anyone is considering installing one you will need an extension of 3-6 feet depending on where your CB unit is being installed. I ran the remainder of the coax cable behind the passenger side trim and then under the rear of the front seat to where the floor heat run has an opening in the carpet as my unit is installed on the passenger side next to the shift lever. The unit was to large to install in the dash sadly!
Here is the unit I am describing:
President New York CB Antenna | Right Channel Radios
As I wanted the wire connecting it as inconspicuous as possible I went with
the rear position so I could thread it thru the back hatch door and I have added a picture of the wiring for the center top panel that has the light and when you remove this panel it has many layers of plastic that needs to be trimmed so that you do not pinch the coax cable. I used wire holders so that the cable does not come in contact with hold points and those are readily available on Ebay / Amazon. Also, the cutting tool in the picture I used is readily available at Lowes / HD.
Hope this helps anyone considering this option for their 4Runner!
New York President CB Antenna-dsc_0077-jpg  New York President CB Antenna-dsc_0078-jpg
Last Man Standing is offline   Reply With QuoteReply With Quote
Old 08-18-2019, 03:31 PM #2
Chris98t4r's Avatar
Chris98t4r Chris98t4r is offline
Chris98t4r is on a distinguished road
Chris98t4r's Avatar
Looking good
Chris98t4r is offline   Reply With QuoteReply With Quote
cable , coax , installed , rear , unit
**NO LONGER AVAILABLE** FS: 2016 4Runner Trail OEM Wheels (New York, New York) - $375 moorei2 For Sale: Suspension/Wheels/Tires 11 10-10-2018 05:56 AM
Best U.S. President CXS Off Topic 15 06-15-2014 08:18 PM
If you were the president, what would you do? MikesToy Off Topic 19 10-19-2009 08:40 PM
What do you think about the new president? MikesToy Off Topic 72 03-23-2009 11:34 PM
Who's the next president? MikesToy Off Topic 521 12-04-2008 12:03 AM
