Old 08-19-2019, 01:20 PM #16
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc is a jewel in the rough gamefreakgc is a jewel in the rough gamefreakgc is a jewel in the rough
Real Name: Jerod
Like others said, the only way it can end up in your intake is through the PCV valve or the breather valve on the back of the driver's side valve cover. The only way it can come out of the PCV is if there's so much oil in there it filled up the cylinder heads with either froth or just straight oil. So you most definitely did not run out of oil, you would not have seen a drop in your intake.
Check to make sure the dipstick tube did not find a way out. It's only held in place with one 10mm bolt. If you shine a flashlight near the bottom of the engine block you'll see where the tube goes in, make sure the o-ring is seated completely.
Like others said, drain you oil and then measure it as you fill it. If you don't have the oil bottles, use a milk jug. Should only fill about 1 1/4 milk jugs, I think you'll find you'll be closer to filling two completely.
Also, check your drain plug is seated correctly and you're not losing oil that way. Replace the gasket on the drain plug as well. Check your filter is on tight enough that it does not leak.
'98 4Runner SR5 - 4x4 5VZ-FE Supercharged - 222k miles, JDM engine @ 221k
AEM F/IC 6 Piggyback, 2.1" pulley at 11 PSI, Go-Fast Parts
Old 08-19-2019, 02:49 PM #17
JohnMc JohnMc is offline
JohnMc will become famous soon enough
Did you have the oil changed somewhere? I wonder if it's possible that they inadvertently swapped dipsticks on you. Maybe try measuring the length from where it sits on the top of the tube to the 'full' line. I'm sure someone could measure a 'proper' one to see if that's the culprit.
gray wire/1" body lift/32" tires/'Snowflake' TRD Taco wheels/231mm Tundra brakes/Rola rack
JohnMc is offline   Reply With QuoteReply With Quote
Old 08-19-2019, 04:07 PM #18
alumarine alumarine is offline
alumarine is on a distinguished road
Here you go. 17.75" from where it rests in the tube to the end.
The low mark is .5" from the end and the full mark is 1.25" from the end.
Mystery Machine-crankcase-dipstick-jpg
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 08-19-2019, 04:39 PM #19
apohl17's Avatar
apohl17 apohl17 is online now
Real Name: The Native Explorer
apohl17 has a spectacular aura about apohl17 has a spectacular aura about
MY GARAGE
apohl17's Avatar
MY GARAGE
I can't say I have ever seen this issue before in the multiple 3rd gens I have been around/worked on, but I am going to go with the most recent theory here - you've put wayyy too much oil in the system from a somehow inaccurate reading.
I'd advise not driving the rig until you can figure this out!! The oil in the intake is a bad sign already, and with only 100k on the clock, it would be a shame to put 'er down.
Hope you get it solved soon!
The AventuRunner Build '07 V8 Sport w/ 211k, DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, and more...
The "Iceberg" Build... Natty White 3rd Gen '00 SR5 w/ 225k, broight loights, 4xi armor, squish, tunes, eyes on the back of it head, a patched frame, and more, etc.
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
apohl17 is online now   Reply With QuoteReply With Quote
Old 08-19-2019, 07:01 PM #20
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout is on a distinguished road
Reinout's Avatar
Real Name: Reinout
@jack333 I'm seeing a lot of folks saying that it's over-filled. I sure hope that the oil place didn't drain your transmission: I might just double check that.
1997 4Runner SR5- ~370k Miles and counting - 5 Speed E-Locker
2002 Hyundai Elantra GT- 190k Miles - 5 Speed - It's still alive
2007 4Runner Limited V6- 142k Miles - Automatic
2011 VW JSW TDI- 104k Miles - 6 Speed - Air Lift 1000
Reinout is offline   Reply With QuoteReply With Quote
Old 08-19-2019, 07:14 PM #21
det107 det107 is offline
det107 is on a distinguished road
I recall a 1979(?) Toyota Corolla that had a bad PVC & was letting oil into carbed air filter housing-
det107 is offline   Reply With QuoteReply With Quote
Old 08-22-2019, 02:28 AM #22
jack333's Avatar
jack333 jack333 is offline
jack333 is on a distinguished road
jack333's Avatar
Update #2
All,
i have replaced the PCV, cleaned out the oil from intake to ensure if any other oil is identified in the system that itís not just residual fluid from the first leak. Iíve driven about 50 miles on the new PCV and havenít seen a decrease in oil on the dipstick. Mav sensor isnít leaking any fluid either which was our first clue that oil was in the intake to begin with. It seems that the problem was solved by a 3$ PCV from Oíreillys. These 3rd genís can surprise you. If s**t hits the fan again iíll repost here for more advice. Trying not to get my hopes up.
Thanks
02 Forest Green SR5
jack333 is offline   Reply With QuoteReply With Quote
Old 08-22-2019, 10:39 AM #23
toyotaspeed90 toyotaspeed90 is offline
toyotaspeed90 is on a distinguished road
I'm sorry, but the root problem isn't fixed.
A PCV is just a vent - allowing the pressure of the crankcase to vent to the throttle body. Oil does not normally contact the PCV aside from minor splashing around.
One simple test you should consider - start the truck and, while running, remove the oil fill cap. You should notice a slight change in how it runs, but nothing major. There should be slight pressure, like a light fan blowing, but nothing more.
toyotaspeed90 is offline   Reply With QuoteReply With Quote
Old 08-22-2019, 01:08 PM #24
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail will become famous soon enough dogtail will become famous soon enough
MY GARAGE
dogtail's Avatar
Real Name: Keith
MY GARAGE
Originally Posted by jack333 View Post
All,
Thanks
Did you ever confirm if your oil light on dash is working, or did you get it working by now? Before with all that loss in oil, it should have tripped the light. Or were you overfilled? There's a wire that runs to the low oil pressure sensor/switch in area of the oil filter in the block.
That wire was broken off on a 3rd gen I bought that was running with only 1 quart in the oil pan. So the light was never tripped. I think I recall it was the tab on the switch broke off and I just replaced it from a parts truck I had. Easy to swap out, just unscrews out of block.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*1998 3.4L, 2wd/auto, rust free from south, slated for 4wd/5spd swap from my 2000 parts rig
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 08-24-2019, 09:52 PM #25
jack333's Avatar
jack333's Avatar
Still driving on it and oil hasnít decreased one bit. I really do believe the PCV fixed my problem. Tried your test and sounded like a little fan.
02 Forest Green SR5
drop , engine , miles , oil , quarts
PMC Machine? Griswald Classic T4Rs 4 01-04-2017 06:54 PM
Green Machine 2.0 Robmills72 Classic T4Rs 197 02-15-2015 06:30 AM
Mounting a Machine Gun War Sprout 3rd gen T4Rs 48 11-26-2013 12:14 PM
Machine gun sunroof Spiggie 4th Gen T4Rs 18 05-09-2012 01:44 PM
50 Cal Machine Gun DEKA3 Off Topic 0 02-15-2012 02:30 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
