Old 09-03-2016, 02:43 PM #1
nissanh nissanh is offline
Toyota Denso AC Compressor bearing and Idler bearing replacement
This is for demonstration purposes only.
For safety: Apply park brake and have the A/T shifter in park. Choke all 4 wheels in front and back.
AC compressor bearing: 30BGS10DST2 (UPDATE after 7000 MILES: AVOID CHINESE BEARINGS. I BOUGHT the replacement chinese brearing from ebay and it is shot)
OD: 52 mm
Depth: 22 mm
Remove the front skid plate
Loosen 12 and 14 mm bolts holding the AC idler bearing.
Remove the belt
Remove the idler bearing. There is a bushing behind the bearing, be ready to note its orientation on the bolt
1st picture: You can press out the bearing to replace the new.
Idler bearing number 6301 Nachi/NTN
Removal of the compressor bearing
There is NO NEED to empty freon or remove the compressor off the vehicle. (I DID THIS THREAD ON A COMPRESSOR that was removed from a truck)
2nd picture: Remove the 10 mm bolt: impact gun is the best: It will spin just like how the crank bolt spins so be ready to hold the clutch. [HINT: BEFORE you remove the belt, have the ignition ON (engine NOT running), turn the ac on to engage the compressor clutch and then remove the 10 mm bolt)
3rd picture: 10 mm Bolt off
4 Picture: Using a 12 mm bolt to puller the clutch from the compressor: IMPORTANT: There is a 1.5 mm thick washer and keep an eye on where it goes.
5 Picture: clutch removed
6 Picture: 1.5 mm washer shown
7 Picture: Lock click removed
8 Picture: Pulley pulled out. It should come right out with gentle pull.
If you want to remove the clutch coil pack, remove the circlip
shown inside and then remove the wires attached to the coil pack
Toyota Denso AC Compressor bearing and Idler bearing replacement-dscn3306-jpg  Toyota Denso AC Compressor bearing and Idler bearing replacement-dscn3308-jpg  Toyota Denso AC Compressor bearing and Idler bearing replacement-dscn3309-jpg  Toyota Denso AC Compressor bearing and Idler bearing replacement-dscn3312-jpg  Toyota Denso AC Compressor bearing and Idler bearing replacement-dscn3314-jpg  Toyota Denso AC Compressor bearing and Idler bearing replacement-dscn3315-jpg  Toyota Denso AC Compressor bearing and Idler bearing replacement-dscn3316-jpg  Toyota Denso AC Compressor bearing and Idler bearing replacement-dscn3317-jpg
Old 09-03-2016, 02:54 PM #2
continued
9 picture: Compressor pulley bearing pulled out: Note the dust shield collar. It will fall out with the bearing (not a tight fit). Reuse it with the new bearing
10: Picture: other side of the pulley
11 Picture: dust shield back in
12 picture: Bearing installed
Use a wise to drive the bearing's last few mm's (prevent damaging the dust shield)
13 Picture: Bend the tabs to secure the bearing
14 Picture: Pulley ready to install
15 Picture: Pulley installed
16 Picture: C-clamp installed
Toyota Denso AC Compressor bearing and Idler bearing replacement-dscn3319-jpg  Toyota Denso AC Compressor bearing and Idler bearing replacement-dscn3321-jpg  Toyota Denso AC Compressor bearing and Idler bearing replacement-160903_0006-jpg  Toyota Denso AC Compressor bearing and Idler bearing replacement-160903_0008-jpg  Toyota Denso AC Compressor bearing and Idler bearing replacement-160903_0010-jpg  Toyota Denso AC Compressor bearing and Idler bearing replacement-160903_0011-jpg  Toyota Denso AC Compressor bearing and Idler bearing replacement-160903_0013-jpg  Toyota Denso AC Compressor bearing and Idler bearing replacement-160903_0015-jpg
Old 09-03-2016, 02:59 PM #3
Continued
17 Picture: Thickness of the washer that goes between the clutch and the pulley
18 Picture: Washer
19 Picture: Washer on the compressor shaft
20 Picture: Clutch going in
21 Picture: Space between the clutch and pulley (if you didn't installed the washer, you will not see this space)
22 Picture: 10 mm bolt back on
Now it is time to put back the idler bearing and the drive belt:
Toyota Denso AC Compressor bearing and Idler bearing replacement-160903_0016-jpg  Toyota Denso AC Compressor bearing and Idler bearing replacement-160903_0017-jpg  Toyota Denso AC Compressor bearing and Idler bearing replacement-160903_0018-jpg  Toyota Denso AC Compressor bearing and Idler bearing replacement-160903_0020-jpg  Toyota Denso AC Compressor bearing and Idler bearing replacement-160903_0022-jpg  Toyota Denso AC Compressor bearing and Idler bearing replacement-160903_0023-jpg
Old 09-03-2016, 11:55 PM #4
nobb nobb is offline
nobb is on a distinguished road
Thanks for the post! I just replaced the AC idler bearing as it was starting to go bad, never thought about the AC bearing itself. I don't think I've read about anyone having this fail, but this is good info to have.
nobb is offline   Reply With QuoteReply With Quote
Old 05-21-2017, 03:32 PM #5
Tyler James Inc's Avatar
Tyler James Inc Tyler James Inc is offline
Tyler James Inc will become famous soon enough
Has anyone actually done this with the pump installed?
"Pulley will come off with a gentle pull" is definitely not working for me. Been at it for almost three hours now, and the inner race hasn't budged from the pump.
I honestly don't believe this can be done with the pump installed.
Edit-
I would highly recommend not trying to do this on the vehicle!
There is very little room to work, and you're just going to get extremely frustrated.
I took the pump off, and secured it between two 2x4's to get the pulley off-
Then I had to get the bearing out of the pulley- also not easy. Started out by tapping the "stakes" out of the way-
Then getting the bearing out-
Bearings-
It's easy from there Toyota Denso AC Compressor bearing and Idler bearing replacement
My 2001 SR5 Ultimate Thread
My OEM+ '97 Limited Thread *Sold*
Anti-Satoshi Member #1
Tyler James Inc is offline   Reply With QuoteReply With Quote
Old 05-21-2017, 09:09 PM #6
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
what are the tell-tale signs that the bearing needs replacement?
Thanks!
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 05-21-2017, 10:47 PM #7
Thanks!
It sounded like I have a supercharger. That would be awesome, but only if I actually had a supercharger!
Old 05-27-2017, 12:10 AM #8
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Hey guys, I'm going to try to replace this bearing soon. Trying to get my brain around how this stuff comes apart. I see the first step is to remove the small bolt. How does the longer bolt help pull the front of the pulley off?
JZiggy is offline   Reply With QuoteReply With Quote
Old 05-27-2017, 12:35 AM #9
@JZiggy , the pulley is threaded with a larger(8mm vs 6mm) bolt hole. When you thread the larger bolt in, it presses against the 1.5mm washer, and acts as a puller to pull it off. It works really slick!
Old 05-27-2017, 01:05 AM #10
JZiggy's Avatar
JZiggy's Avatar
Thanks for the fast response! Makes perfect sense now.
Old 05-27-2017, 01:14 PM #11
ZionXIX's Avatar
ZionXIX ZionXIX is offline
ZionXIX is on a distinguished road
ZionXIX's Avatar
This thread motivated me to try and remove my AC pulley after giving up on removing the 10mm bolt last time. Got the bolt removed in 2 seconds today after a "light bulb" moment. Then I tried for a good hour to pry off the magnetic clutch. After giving up, I noticed something that killed all my motivation for the foreseeable future.
Sent from my SM-G930T using Tapatalk
__________________________________________________ ________________________
"Island Paradise" 1996 Toyota 4Runner SR5 2WD 235 75r15
ZionXIX is offline   Reply With QuoteReply With Quote
Old 06-07-2017, 06:09 AM #12
Wow!
Look what I found:
I am in Sri Lanka visiting my parents at the moment, also messing with their Diesel Hilux 4x4. A local autoparts store is selling NSK bearing (made in Japan) for this AC compressor application for just $ 8.27!
Attached is the picture: 30BD5222T1XDDUM6 is the number it has and the dimensions are
Inner X Outer X Thickness: 30 X 52 X 22 mm
Toyota Denso AC Compressor bearing and Idler bearing replacement-dscn3988-jpg
Old 12-09-2017, 11:28 PM #13
Topher7 Topher7 is offline
Topher7 is on a distinguished road
I was able to do this repair without removing the compressor. My 4runner was originally from Massachusetts so I expected to wrestle with it a bit...surprisingly, I had this whole job completed in 3ish hours. Luck of the draw with these things I suppose??? Removed the fan clutch, bottom skid plates, and unbolted the fan shroud for some extra room to work. Everything removed easily without special tools (aside from a set of snap-ring pliers). Got the bearing off amazon for $16 delivered. My old one was in pretty bad shape, purrs so quietly now. A few pics of the bearing but I followed the procedures from previous posts and diagrams from the service manual.
Toyota Denso AC Compressor bearing and Idler bearing replacement-img_20171209_133933403-jpg  Toyota Denso AC Compressor bearing and Idler bearing replacement-img_20171209_152352953-jpg  Toyota Denso AC Compressor bearing and Idler bearing replacement-img-20171209-wa0003-jpg
Topher7 is offline   Reply With QuoteReply With Quote
Old 12-10-2017, 09:32 AM #14
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I hope we're going to film this Jordan.
Old 12-10-2017, 10:25 AM #15
I should note the hardest part for me was the snap ring. I spent a lot of time aligning my pliers to the correct location. I had to use my cell phone's camera to find the alignment holes. I snapped off the prong on one of my attachments with misalignment of the pliers. If you leave the compressor in the vehicle you just don't have the angle needed to see the snap ring.
Idler Pulley and Belt Tensioner Replacement Bearing Sizes tjhaf2007 4th Gen T4Rs 29 12-16-2018 04:59 PM
my idler bearing replacement thread jms2112 4th Gen T4Rs 6 07-28-2014 02:26 PM
Idler Bearing or Alternator? Stuck CAPS 4th Gen T4Rs 49 04-12-2014 11:32 AM
Idler pulley (bearing replacement) in '96 3RZ-FE? fazeka 3rd gen T4Rs 1 03-17-2012 04:23 PM
#2 idler bearing replacement..... 77'911 Classic T4Rs 0 11-21-2010 06:09 PM
