Old 08-19-2019, 01:05 PM #1
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
DIY garage auto trans rebuild
Wanting to do a full rebuild on a spare auto trans I have off of a 99 4wd Runner. Anyone have any tips suggestions etc etc etc etc. Anything from what kit in particular to buy or any special tools required? I'm fairly certain I've got everything and also know what kit I personally want to go with. This isnt out of necessity as its 100% out of fun. Let me know everyone, thanks!
VernySanders is offline   Reply With QuoteReply With Quote
Old 08-19-2019, 05:13 PM #2
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Cant offer any information, but i always wanted to rebuild a trans. Take lots of pics.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 08-19-2019, 07:26 PM #3
det107 det107 is offline
det107 is on a distinguished road
Dollar store large plastic pans of various sizes & plenty of rags LoL
Don't forget a strong magnet to find loose parts. Good luck venturing in uncharted territory-
det107 is offline   Reply With QuoteReply With Quote
Old 08-19-2019, 07:28 PM #4
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
Sub'd. Do you have the FSM?
weekendclimber is offline   Reply With QuoteReply With Quote
Old 08-20-2019, 11:34 AM #5
medic0079 medic0079 is offline
medic0079 is on a distinguished road
Always been scarred to crack one open shop near me is 300 labor including install minus parts. For that amount I just pay
medic0079 is offline   Reply With QuoteReply With Quote
Old 08-20-2019, 12:13 PM #6
pauldub pauldub is offline
pauldub will become famous soon enough
It's not uncharted territory.
From NAXJA:
The AW4 is a fairly simple box - and a "Master" rebuild kit (including clutches, steels, and whatever) goes for about $300 locally, or a "Overhaul" kit (basically a reseal kit and components to renew the valve body) for about $90 - both at the tranny shop up the street from me here.
You will need two "special" tools that I was able to make from bulk stock - there are some very large snap rings (which won't work with standard snapring pliers - I made a part of "chopsticks" using 1/4" aluminum round rod and D&T for #4-40 setscrews) that worked well, and get a decent bit of barstock and some M10x1.5 and M8-something (I don't remember what) and some 1/2-20 allthread to make the bridge puller to pull the planetary sets out. If you need me to, I can probably dig them up and take digipix for you sometime in the next couple days.
Total cost for "special" tools - about $20, all up.
You MUST have a camera capable of giving you pictures straight away for any valve body work - since there seem to be a few revisions of what goes where, and the manual isn't always right. I should have the ATSG AW4 manual around here somewhere as a .pdf (it's the one I used - and I found it online somewhere. Probably at Strokers - groups.yahoo.com/group/strokers) which has everything else correct - I've just never trusted manual pix of valve bodies (and I'm usually rewarded for that lack of trust.)
The three valve body solenoids can be readily checked with an ohmmeter - as I recall, 13 +-3 ohms is nominal. Hopefully, they're fine - they're spendy to replace (and I haven't been able to build up a stock.)
With either renewal kit, you WILL have valve body gaskets left over - it's a kit for all AW4 variants (Celica, Supra, Pickup, Van, XJ, MJ, ...) and you will match the gaskets up against the old ones to select them.
Here's a more detailed how-to:
http://www.fourwheeler.com/how-to/tr...ssion-rebuild/
pauldub is offline   Reply With QuoteReply With Quote
Old 08-20-2019, 12:17 PM #7
Here's a link to a repair manual:
AW4 manual[1]
Old 08-21-2019, 12:18 PM #8
metallitera metallitera is offline
Real Name: Red
metallitera will become famous soon enough
Real Name: Red
Subscribed.
-ReD
Firefighter/Licensed Paramedic
*SOLD* 2000 4Runner Limited 4x4
2020 Ford F-150 3.5L EB
Build Thread
metallitera is offline   Reply With QuoteReply With Quote
Old 08-30-2019, 04:06 PM #9
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Have you figured out where you're getting your parts from? I came across this the other day: A340E Transmission Master Rebuild Kit A340F A341E A343E A340 V4AW3 Stock HD HP Overhaul: Oregon Performance Transmission
Old 08-30-2019, 06:59 PM #10
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
here is the pdf for the
A340F is in there with all the gory details.
A340 Series Repair Manual (RM216).pdf - Google Drive
I have wanted to give a try for a while now but... I just keep pulling decent used ones so... have not had the need yet.
I know ITP has a kit. kind of expensive but they have a pretty good track record.
A340 | AW4 Performance Transmission Rebuild Kit
I have found a couple of decent teardown vids on youtube. I think ITP might even have a build up vid for their kit? you can get a pretty good idea of the special tools you will need.
I think they have a lot more on their channel.
YouTube
Old 09-05-2019, 04:24 PM #11
Real Name: Werner
Real Name: Werner
That's a nice kit! I was looking at a very similar master overhaul kit on rock auto for the same price range! I just bought a 1983 Yamaha yt125 three wheeler so I'm getting that running and then I'll do this trans next.
Old 09-05-2019, 04:26 PM #12
Real Name: Werner
Real Name: Werner
YouTube
WOW thankyou for that info especially the manual! I hit the download button on that very quickly lol
Old 09-05-2019, 04:43 PM #13
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
I think you'll be fine, this stuff isn't that hard. If you have a huge table to lay things out in an order that makes sense (Bell housing) -> tail shaft, take photos and just bag everything as you go. Take some notes and utilize the FSM.
APhelps is offline   Reply With QuoteReply With Quote
Old 09-05-2019, 05:16 PM #14
Real Name: Patrick
Real Name: Patrick
@sleepydad How accurate do you think that manual you posted is? I didn't see any application for our motors in the manual.
Old 09-05-2019, 05:45 PM #15
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
I have done a partial tear down on an A340E and the manual was right on. I did not go all the way so I can't answer for the complete process.
I also believe the valve body description was right on for my 1997
there is going to be differences for sure, the FSM I have is for 1996-2002 and it has lacks descriptions of all kinds of differences that the early trucks had, different driveshaft lengths between limited and SR5/base, different trans pans between emissions types, different body mounts, different power steering pumps and lines between older trucks and newer... totally different braking systems between older and newer.
in general I think it seems pretty accurate. not sure your going to find a free pdf FSM for exactly the trans your working with?
auto , diy , kit , rebuild , trans
Starter rebuild kit 3.0/auto Blind Cleric Classic T4Rs 3 02-06-2018 06:06 PM
FS 3rd gen front end rebuild parts, trans filter Slodrivr For Sale: Suspension/Wheels/Tires 1 10-02-2015 11:18 AM
Wtb auto trans for 2nd gen 4wd 3.0 jrs944 Want to Buy/Trade 0 10-21-2014 11:01 AM
2nd Gen Auto Trans Help???? BCGrown Classic T4Rs 1 09-22-2014 04:23 PM
auto trans wont auto shift jspd234 Classic T4Rs 6 10-29-2012 01:49 AM
