Originally Posted by weekendclimber
I've watched a few videos recently and it was interesting to learn that A340E variation to this particular transmission was used in the Supra's. Maybe that was common knowledge around here, but I had no idea.
look at the wiki... not sure how much to trust it but... it lists all kinds of stuff this trans was in
Toyota A transmission - Wikipedia
the one thing I found very interesting was
"OEM with 2JZ-GTE twin turbocharged engines only. This is the twin turbo only heavy duty version with some internal mods. The main case is similar to the common A340E but not interchangeable, the bell housing has "J3" cast into the upper surface, and is larger diameter to accept the larger torque converter and special flex plate. Maximum power using the stock internals should be limited to 500 (significantly higher than the standard A340E used with the 2JZ-GE normally aspirated engine)."
