Old 08-19-2019, 02:52 PM #1
Zscarlson1 Zscarlson1 is offline
Real Name: Zach Carlson
Zscarlson1 is on a distinguished road
Problem with Daystar Lift
I was installing, well trying to install, a 2.5" Daystar Spring Lift with new KYB/Moob Springs (yes I know they will probably fail on me eventually). I had a problem when the LCA was pushed down enough to fit the strut, the UBJ shroud would hit the spring. I tried turning it around 180 degrees (the spring) and it did the same thing. Was I doing something wrong? I tried doing it with the UBJ attached and detached along with all of the brake line brackets and didn't have any luck. Am I missing a step? I returned it because I didn't want to not be able to return it by the due date but I can reorder it. I never knew anyone having this kind of issue and everything said it was straight forward but I was battling it for hours on end to get it to work properly.
Any suggestions or help? Other than angle grinding the UBJ shroud away.
Zscarlson1 is offline   Reply With QuoteReply With Quote
Old 08-19-2019, 03:08 PM #2
There are more choices for spring direction that 180* apart. It took a few tries to find an orientation that clears in the front when I did my lift in the front (different spring and shock choices, but same issue).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-19-2019, 03:11 PM #3
Man, that's a lot of spring compressing to get it to work sadly.
daystar , problem , shroud , spring , ubj
F/S New 3rdGen Daystar 2.5" Front Lift/30mm Rear Lift-NJ thaemcee2 For Sale: Suspension/Wheels/Tires 3 10-07-2015 07:16 PM
Daystar 2.5/1.5 lift problem. Front wheel hop in reverse. charvey 4th Gen T4Rs 1 10-16-2014 01:11 PM
Daystar problem bvc 4th Gen T4Rs 12 03-27-2013 10:27 AM
Daystar 2.5/1.5 lift (newer easy version) - exact height of lift? BigEd 4th Gen T4Rs 1 05-06-2011 11:10 AM
Major problem installing Daystar spacer lift ZandT4R 4th Gen T4Rs 30 07-22-2009 11:14 PM
